2 Wired connection board
Revision as of 02:06, 20 February 2019 by Sinovoip (talk | contribs)
1 Get the development suite
3 Try burning the board
4 Hello, World!
5 Light up all kinds of LED
1 Auto series one key burn
2 ESPBlocks Beginner's only
3 Mpfshell details
4 Pycharm IDE programming
1. Panel scrolling text
2. Panel display images
[[File:Micropython2.png|thumb|[[3 Bottom IO port control] ]] [[File:Micropython2.png|thumb|4 Panel key detection ]]
5 Gets the board temperature
6 Play MIDI music
7 Photosensitive gesture
8. MPU-9250 9-axis sensor
9. Make a compass
10 Free to define gestures
11 Random number generator
12 S2m Scratch2
13 Codelab Scratch3
1. connect BPI;bit
Connect a board to your computer via a MicroUSB wire, with Windows10 system
2. Check the drive
Enter <device manager> to confirm whether Serial is installed, enter as follows.
  • (right key)This computer -> attribute -> device manager
  • Start menu -> (input) device manager
  • Control panel -> (search) device manager
you can see the device display ** usb2.0-serial **, indicating that ** has not been installed driver **, if the driver has been installed before, you can skip to step 5.
3. install the driver
check here Serial CH341 driver,And follow the instructions below to install the driver
Open the downloaded CH341SER.ZIP ZIP package, enter the CH341SER folder, open setup. EXE, you can see the following figure.
check INSTALL to install driver,Wait a moment to complete the installation。
4. Confirm the serial port
  • Check that the board is connected successfully
You can see that the original usb2.0-serial has disappeared and is replaced by usb-serial CH340(COM3), which means that you have successfully installed the driver and got the name of the board Serial port (COM3). You can view the information coming out of the board of Serial port name (COM3) through various Serial port tools
5. Other System
The board has been successfully connected,Go on to the next section 3 Try burning the board,If it's a Linux or Mac system you have to do your own search, but it's pretty much the same.
