9. Make a compass
Revision as of 02:12, 20 February 2019 by Sinovoip (talk | contribs)
1 Get the development suite
2 Wired connection board
3 Try burning the board
4 Hello, World!
5 Light up all kinds of LED
1 Auto series one key burn
2 ESPBlocks Beginner's only
3 Mpfshell details
4 Pycharm IDE programming
1. Panel scrolling text
2. Panel display images
[[File:Micropython2.png|thumb|[[3 Bottom IO port control] ]] [[File:Micropython2.png|thumb|4 Panel key detection ]]
5 Gets the board temperature
6 Play MIDI music
7 Photosensitive gesture
8. MPU-9250 9-axis sensor
9. Make a compass
10 Free to define gestures
11 Random number generator
12 S2m Scratch2
13 Codelab Scratch3
compass
This module gives you access to the built-in electronic compass (mpu). The compass should be calibrated before use, otherwise the reading may be wrong.
note:The alignment compass causes the program to pause until the alignment is complete. Calibration consists of a small game, by rotating the board in the air to complete the circle calibration.
Function of compass
  • compass.calibrate()
Perform this function to start the calibration process, you will receive a has a guiding significance to the information, then we need to rotate the board and in the air to draw a handstand '8' or circle, (this movement can refer to your mobile phone, mobile phone function of compass will have a calibration steps before use), the calibration process will take about 1 minute of time, you can't perform other procedures during calibration
Notice message
  • compass.is_calibrated ()
Returns True if compass calibration is successful, or False otherwise
  • compass.get_x ()
Returns a reading of the strength of the magnetic field on the X-axis, which is a positive or negative integer, depending on the direction of the magnetic field.
  • compass.get_y ()
Returns a reading of the magnetic field intensity on the Y-axis, which is a positive or negative integer, depending on the direction of the magnetic field.
  • compass.get_z ()
Returns a reading of the z-axis magnetic field intensity, which is a positive or negative integer, depending on the direction of the magnetic field
  • compass.heading()
The compass heading calculated from the above readings is an integer between 0 and 360, representing a clockwise Angle of 0 at 12 o 'clock
  • compass.get_field_strength()
Returns the size of the magnetic field around the device, which is an integer.
sample code
  compass.py
   Creates a compass.
   The user will need to calibrate the compass first. The compass uses the
   built-in clock images to display the position of the needle.
from microbit import *
# Start calibrating
compass.calibrate()
# Try to keep the needle pointed in (roughly) the correct direction
while True:
   sleep(100)
   needle = ((15 - compass.heading()) // 30) % 12
   display.show(Image.ALL_CLOCKS[needle])
In this sample code the first step is to calibrate the electronic compass (mpu). After the calibration, we can see that we have a compass on the led panel. No matter how we turn the board, it always points to the south. Right
