Banana Pi BPI-W3
- ARM Mali-G610 MP4,
- NPU for AI : 6Tops@INT8
- 8G RAM and 32G eMMC flash onboard
- 2.5Gbps Ethernet
BPI-3588-LGA Core board
BPI-3588-LGA core board uses the Rockchip RK3588 flagship chip,integrating a 6Tops NPU and a high-performance quad-core Mali-G610 MP4 GPU. It adopts LGA 506pin package method, which can expand a variety of display interfaces and industrial application interfaces. With open baseboard design materials and open-source SDKs, it can be efficiently developed. It supports multiple operating systems such as Android, Ubuntu, Debian, and Buildroot. It provides robust, stable, reliable, and expandable product support for various AI application scenarios, and is widely applicable to fields such as edge computing, artificial intelligence,cloud computing, VR/AR, blockchain, smart security, intelligent industrial control, and smart home.
BPI-3588-LGA spec
SOC | Rockchip RK3588 | |
CPU | Quad Core Cortex-A76@2.4GHz +Quad Core Cortex-A55@1.8GHz, 8nm | |
GPU | ARM Mali-G610 MP4 GPU,Support OpenGL ES3.2 / OpenCL 2.2 / Vulkan1.1 | |
NPU | 6 TOPS@INT8,Support INT4/INT8/INT16 mixed operation Support framework switching of TensorFlow/MXNet/PyTorch/Caffe | |
ISP | 48-Megapixel ISP,It implements a lot of algorithm accelerators, such as HDR, 3A, LSC, 3DNR, 2DNR, sharpening, dehaze, fisheye correction, gamma correction and so on. | |
Encode&Decode | Decode:8K@60fps H.265/VP9/AVS2,8K@30fps H.264 AVC/MVC, 4K@60fps AV1, 1080P@60fps MPEG-2/-1/VC-1/VP8
Encode:8K@30fps H.265 / H.264 | |
RAM | 4GB/8GB/16GB(up to 32GB)64-bit LPDDR4/LPDDR4x, Defalut LPDDR4x 8GB | |
Flash | 16GB/32GB/64GB/128GB/256GB eMMC, support MicroSD card slot, Defaut eMMC 32GB | |
Operating Systems | Android 12.0, Ubuntu 20.04, Ubuntu 22.04, Debian11, Buildroot, Armbian, Kylin OS | |
Power supply | 4.0V | |
Interface Type | LGA 506pin | |
Size | 45mm×50mm×4.5mm(top: 2.2mm+PCB: 1.2mm +bottom: 1.1mm) | |
Operating temperature | 0℃ ~ 70℃ | |
Storage temperature | -20℃ ~ 70℃ |
Function parameter
Category | Function | quantity | parameter | |
Video Input Interface | MIPI DC(DPHY/CPHY) combo PHY | 2 |
Support camera input combination:
MIPI CSI DPHY | 4 |
DVP | ≤1 |
HDMI RX | 1 |
Display interface | HDMI/eDP TX interface | ≤2 |
DP TX | 2 |
MIPI DSI | 2 |
BT.1120 video output | ≤1 |
Audio Interface | I2S | ≤4 |
SPDIF | ≤2 |
PDM | ≤2 |
Network interface | GMAC | ≤2 |
Connectivity interface | SDIO | ≤1 |
USB 2.0 Host | 2 |
SATA | ≤3 |
Combo PIPE PHY0 support one of the following interfaces
Combo PIPE PHY1 support one of the following interfaces
Combo PIPE PHY2 support one of the following interfaces
USB3.1 Gen1 | ≤3 |
PCIe2.1 | ≤3 |
PCIe3.0 | ≤4 |
SPI | ≤5 |
I2C | ≤9 |
UART | ≤10 |
CAN | ≤3 |
Others interface | GPIO | Multiple |
ADC | ≤8 |
PWM | ≤16 |
BPI-W3 Hardware spec
SOC | RockChip RK3588 |
CPU | Quad Core A76+ Quad Core A55 ,use 8nm , 2.4GHz |
GPU | ARM Mali-G610 MP4 GPU,Support OpenGL ES3.2 / OpenCL 2.2 / Vulkan1.1, 450 GFLOPS |
NPU | 6 TOPS,Support INT4/INT8/INT16 mixed operation,Support framework switching of TensorFlow/MXNet/PyTorch/Caffe |
Encode&Decode | encode:8K@60fps H.265/VP9/AVS2、8K@30fps H.264 AVC/MVC、4K@60fps AV1、1080P@60fps MPEG-2/-1/VC-1/VP8 ,decode:8K@30fps H.265 / H.264 |
Ram | 4GB/8GB/16GB(up to 32GB)64bit LPDDR4/LPDDR4x/LPDDR5,Defalut LPDDR4 8GB |
Flash | 16GB/32GB/64GB/128GB/256GB eMMC,support MicroSD card slot,Defaut :32GB |
M2 Key M | The interface supports extension SSD |
network | 2.5G network port(RLT8125BS) |
video output | 2 x HDMI2.1(just one support 8K@60fps or 4K@120fps,other support 4K@60fps),1 x MIPI-DSI(4K@60fps),1 x DP1.4(8K@30fps), |
video input | 1 x 4Lanes MIPI CSI / 2 x 2lanes MIPI CSI,1 x HDMI RX2.0 |
Voice | 2 x HDMI voice output ,1 x DP1.4 voice output,1 x headphone (es8316) |
Wireless | M2 E key interface support sdio、pcie、usb BT&wifi(AP6256,Intel AX210) |
USB | 2 x USB3.1,2 x USB2.0,1x USB-C(DP1.4(8K@30fps)/OTG/PD fast charging) |
Others | Fan、RTC、LED、debug |
Button | Power Button、Reset Button、 Recovery Button、Root Button |
GPIO | 40 x GPIO(UART、SPI、I2C、I2S、PWM、ADC、 GPIO、 5V power 、3.3V power) |
Power | DC 12V/2.5A bore diameter 2.5mm,support USB Type-C PD 2.0 ,9V/2A, 12V/2A, 15V/2A,Support 12V POE power supply |
System | Android 12.0、Ubuntu、Debian11、Buildroot、Kylin Linux |
Size | 148 mm × 100.5mm |
operating temperature | -10℃ ~ 70℃ |
storage temperature | -20℃ ~ 70℃ |
40 PIN GPIO
GPIO number | Function8 | Function7 | Function6 | Function5 | Function4 | Function3 | Function2 | Function1 | Pin# |
+3.3V | 1 | ||||||||
139 | I2S1_SDO2_M0 | I2C7_SDA_M3 | UART8_CTSN_M0 | PWM15_IR_M1 | CAN1_TX_M1 | GPIO4_B3 | 3 | ||
138 | I2S1_SDO1_M0 | I2C7_SCL_M3 | UART8_RTSN_M0 | PWM14_M1 | CAN1_RX_M1 | GPIO4_B2 | 5 | ||
115 | SPI1_CS1_M1 | I2C8_SDA_M4 | UART7_CTSN_M1 | PWM15_IR_M0 | GPIO3_C3 | 7 | |||
GND | 9 | ||||||||
113 | SPI1_CLK_M1 | UART7_RX_M1 | GPIO3_C1 | 11 | |||||
111 | SPI1_MOSI_M1 | I2C3_SCL_M1 | GPIO3_B7 | 13 | |||||
112 | SPI1_MISO_M1 | I2C3_SDA_M1 | UART7_TX_M1 | GPIO3_C0 | 15 | ||||
+3.3V | 17 | ||||||||
42 | SPI0_MOSI_M2 | UART4_RX_M2 | GPIO1_B2 | 19 | |||||
41 | SPI0_MISO_M2 | GPIO1_B1 | 21 | ||||||
43 | SPI0_CLK_M2 | UART4_TX_M2 | GPIO1_B3 | 23 | |||||
GND | 25 | ||||||||
150 | SPI3_CLK_M0 | I2C0_SDA_M1 | PWM7_IR_M3 | GPIO4_C6 | 27 | ||||
63 | UART1_CTSN_M1 | PWM15_IR_M3 | GPIO1_D7 | 29 | |||||
47 | SPDIF_TX_M0 | UART1_RX_M1 | PWM13_M2 | GPIO1_B7 | 31 | ||||
103 | PWM8_M0 | GPIO3_A7 | 33 | ||||||
110 | I2S2_LRCK_M1 | UART3_RX_M1 | PWM13_M0 | CAN1_TX_M0 | GPIO3_B6 | 35 | |||
37 | |||||||||
GND | 39 |
Pin# | Function1 | Function2 | Function3 | Function4 | Function5 | Function6 | Function7 | Function8 | GPIO number |
2 | +5.0V | ||||||||
4 | +5.0V | ||||||||
6 | GND | ||||||||
8 | GPIO0_B5 | UART2_TX_M0 | I2C1_SCL_M0 | I2S1_MCLK_M1 | 13 | ||||
10 | GPIO0_B6 | UART2_RX_M0 | I2C1_SDA_M0 | I2S1_SCLK_M1 | 14 | ||||
12 | GPIO3_B5 | CAN1_RX_M0 | PWM12_M0 | UART3_TX_M1 | I2S2_SCLK_M1 | 109 | |||
14 | GND | ||||||||
16 | GPIO3_A4 | 100 | |||||||
18 | GPIO4_C4 | PWM5_M2 | SPI3_MISO_M0 | 148 | |||||
20 | GND | ||||||||
22 | SARADC_IN4 | ||||||||
24 | GPIO1_B4 | UART7_RX_M2 | SPI0_CS0_M2 | 44 | |||||
26 | GPIO1_B5 | UART7_TX_M2 | SPI0_CS1_M2 | 45 | |||||
28 | GPIO4_C5 | PWM6_M2 | I2C0_SCL_M1 | SPI3_MOSI_M0 | 149 | ||||
30 | GND | ||||||||
32 | GPIO3_C2 | PWM14_M0 | UART7_RTSN_M1 | I2C8_SCL_M4 | SPI1_CS0_M1 | 114 | |||
34 | GND | ||||||||
36 | GPIO3_B1 | PWM2_M1 | UART2_TX_M2 | 105 | |||||
38 | GPIO3_B2 | PWM3_IR_M1 | UART2_RX_M2 | I2S2_SDI_M1 | 106 | ||||
40 | GPIO3_B3 | UART2_RTSN | I2S2_SDO_M1 | 107 |
MIPI CSI
0.5mm FPC Connector
Pin# MIPI-CSI Description 1,4,7,10,13,16,19,21,24,25,26,27,32,33 GND Power Ground & Signal Ground 2 MIPI_CSI0_RX_D3N MIPI RX Lane3 iuput N 3 MIPI_CSI0_RX_D3P MIPI RX Lane3 iuput P 5 MIPI_CSI0_RX_D2N MIPI RX Lane2 iuput N 6 MIPI_CSI0_RX_D2P MIPI RX Lane2 iuput P 8 MIPI_CSI0_RX_CLK1N MIPI RX Clock iuput N 9 MIPI_CSI0_RX_CLK1P MIPI RX Clock iuput P 11 MIPI_CSI0_RX_D1N MIPI RX Lane1 iuput N 12 MIPI_CSI0_RX_D1P MIPI RX Lane1 iuput P 14 MIPI_CSI0_RX_D0N MIPI RX Lane0 iuput N 15 MIPI_CSI0_RX_D0P MIPI RX Lane0 iuput P 17 MIPI_CSI0_RX_CLK0N MIPI RX Clock iuput N 18 MIPI_CSI0_RX_CLK0P MIPI RX Clock iuput P 20 MIPI_CAM3_CLKOUT 1.8V, CLock ouput for Sensor 22 MIPI_CAM1_CLKOUT 1.8V, CLock ouput for Sensor 23 MIPI_CSI0_PDN0_H(GPIO1_B0) 1.8V, GPIO 24 I2C3_SCL_M0_MIPI 1.8V, I2C Clock, pulled up to 1.8V with 2.2K on w3 25 I2C3_SDA_M0_MIPI 1.8V, I2C Clock, pulled up to 1.8V with 2.2K on w3 26 MIPI_CSI0_PDN1_H(GPIO1_A7) 1.8V, GPIO 27 CM_RST_L(GPIO4_A0) 3.3V, GPIO 28,29 VCC_RX 3.3V Power ouput 30,31 VCC_5V0 5V Power ouput
MIPI DSI
0.5mm FPC Connector (J23)
Pin# MIPI-DSI Description 1,4,7,10,13,16,27,33,34 GND Power and Signal Ground 2 MIPI_DPHY1_TX_D0N MIPI1 TX Lane0 ouput N 3 MIPI_DPHY1_TX_D0P MIPI1 TX Lane0 ouput P 5 MIPI_DPHY1_TX_D1N MIPI1 TX Lane1 ouput N 6 MIPI_DPHY1_TX_D1P MIPI1 TX Lane1 ouput P 8 MIPI_DPHY1_TX_CLKN MIPI1 TX Clock ouput N 9 MIPI_DPHY1_TX_CLKP MIPI1 TX Clock ouput P 11 MIPI_DPHY1_TX_D2N MIPI1 TX Lane2 ouput N 12 MIPI_DPHY1_TX_D2P MIPI1 TX Lane2 ouput P 14 MIPI_DPHY1_TX_D3N MIPI1 TX Lane3 ouput N 15 MIPI_DPHY1_TX_D3P MIPI1 TX Lane3 ouput P 17 LCD_PWM (PWM2_M2/GPIO4_C2) 1.8V, GPIO/PWM 18,19 VCC3V3_LCD 3.3V Power ouput 20 LCD_RESET (GPIO2_C1) 1.8V, GPIO 21 /NC No Connection 22 LCD_BL_EN (GPIO3_A1) 3.3V, GPIO 23 I2C6_SCL_M0 1.8V, I2C Clock, pulled up to 1.8V with 2.2K on w3 24 I2C6_SDA_M0 1.8V, I2C Data, pulled up to 1.8V with 2.2K on w3 25 TP_INT (GPIO0_D3) 1.8V, GPIO 26 TP_RST (GPIO0_C6) 1.8V, GPIO 28,29 VCC5V0_LCD 5V Power ouput 31,32 VCC_1V8 1.8V Power ouput
Debug UART
3.3V level signals, 1500000bps
Pin# Assignment Description 1 UART2_RX_M0 intput 2 UART2_TX_M0 output 3 GND 0V
PoE In
1.25mm Connector
Pin# Assignment Description 1 VC1 TX1 2 VC2 RX1 3 VC3 TX2 4 VC4 RX2
PoE Out
2.0mm Connector
Pin# Assignment Description 1 VDD_POE 12V Power ouput 2 VDD_POE 12V Power ouput 3 GND Ground pin 4 GND Ground pin
Fan
1.25mm Connector
Pin# Assignment Description 1 VCC_5V0 5V Power ouput 2 VCC_5V0 5V Power ouput 3 PWM1_M0/GPIO0_C0 1.8V, PWM/GPIO
- Banana Pi linux-5.10.110 kernel BSP Source code on github :https://github.com/BPI-SINOVOIP/BPI-W3-BSP
- Armsom github source code :https://github.com/ArmSoM/armsom-w3-bsp
- Rockchip RK3588 datasheet
- Baidu cloud: https://pan.baidu.com/s/1GeskKfLFwjgmz0pgt7sICg?pwd=8888 (pincode:8888)
- Google drive: https://drive.google.com/drive/folders/1l1YmUdBaLuDkJma3CYZJWjYug9D-jV_4?usp=sharing
- Banana PI BPI-W3 SCH, DXF, SMD file
- Baidu cloud: https://pan.baidu.com/s/1ETL7U4R54Cd5cDg8usp-JQ?pwd=pb48 (pincode:8888)
- Google drive: https://drive.google.com/drive/folders/1d_vtW5aDH3dPAco-dHIwm16r25JUYWS8?usp=sharing
- Banana Pi BPI-W3 coare board 3588-LGA Core board all pin list file(5.core board (LGA) pin List)
- Baidu cloud: https://pan.baidu.com/s/1ZqDRkk0NVEjpHxsQNHbleQ?pwd=8888 (pincode:8888)
- Google drive: https://docs.google.com/spreadsheets/d/1yj6fLbJET5cLjJG-cD3R5_b7S4umTFXI/edit?usp=sharing&ouid=101692257577438398584&rtpof=true&sd=true
- Banana Pi Core board design for RK3588 : BPI-RK3588 Core board and development Kit
- Rockchip RK3588 datasheet :https://drive.google.com/file/d/1KAq1_kKqPtkq8Vlq-h_yUPUZLrgqSKHI/view?usp=sharing
- Banana Pi BPI-W3 RK3588 NPU6T AI RKNN Toolkit2 and RKNPU2 demo :https://www.youtube.com/watch?v=AEU87YUZz8Y
- BPI-W3 Rk3588 development github blog: https://github.com/ArmSoM/Embedded-Technology-Blog
- BPI-W3 ubuntu20.04 Linux system adaptation is complete:https://www.youtube.com/watch?v=xVDkWv_Q9xY
- BPI-W3_armsom-w3-emmc-android12-rkr12-20231103.img
- Baidu cloud: https://pan.baidu.com/s/1rAfTRARQRDwaZnulPOu0Fg?pwd=8888 (pincode:8888)
- Google drive: https://drive.google.com/file/d/1y_tEuc0rslUtNn4SVZoyPTh9tAqAcKp4/view?usp=sharing
- BPI-W3_armsom-w3-emmc-android12-TV-rkr12-20230525.img
- Baidu cloud:https://pan.baidu.com/s/1p8gOK3gNTN-f0Fxb6c6CFw?pwd=8888 (pincode:8888)
- Google drive: https://drive.google.com/file/d/1knzU875x6FQdYNef3DSaFExbMn6IXjf4/view?usp=sharing
- ubuntu-22.04.3-preinstalled-desktop-arm64-bpi-w3_armsom-w3.img
- Baidu Cloud: https://pan.baidu.com/s/1lKyEvNJXKkf13xwDg1e4Hw?pwd=8888 (pincode:8888)
- Google Drive: https://drive.google.com/drive/folders/162vkWVjWJCsPRG7XjONzCIkdPkro5zY1?usp=sharing
- ubuntu-22.04.3-preinstalled-server-arm64-bpi-w3_armsom-w3.img
- Baidu cloud: https://pan.baidu.com/s/1cqbpgk5ykp_-1uv9ZpxoZg?pwd=8888 (pincode:8888)
- Google drive: https://drive.google.com/drive/folders/1-GxlXelKY11b-sbiNARzA0DZ-bb328l-?usp=sharing
- BPI-W3_armsom-w3-debian-bullseye-xfce4-arm64-20231204.img
- Baidu cloud: https://pan.baidu.com/s/1OB6qzCmwhaXTnabs0_jmeQ?pwd=8888 (pincode:8888)
- Google drive: https://drive.google.com/drive/folders/1E9ynf6LSThnb7HLDC09IqAJDdOo4TWK4?usp=sharing
BPI-W3 Tools
- Baidu cloud : https://pan.baidu.com/s/1SD3shbfQui4N19IVTXpmXQ?pwd=8888 Pincode:8888
- Google drive: https://drive.google.com/file/d/1v1ixTDcjOqBPn6eyiNSH5yOBNWPUA8Ig/view?usp=sharing
- SINOVOIP Aliexpress shop: https://www.aliexpress.us/item/3256805306000586.html?gatewayAdapt=glo2usa4itemAdapt&_randl_shipto=US
- BPI Aliexpress shop : https://www.aliexpress.com/item/1005005492412383.html?spm=5261.ProductManageOnline.0.0.44927197rtt5Zg
- Taobao shop : https://item.taobao.com/item.htm?spm=a213gs.success.result.1.7a637a8674R4AD&id=714475598378
- OEM&ODM:judyhuang@banana-pi.com
