BPI:bit for Webduino
Overview: BPI-Bit
BPI-UNO32 with ESP32 design
About webduino
Webduino working model
  • 1 use WebComponents integration Breakout.
  • 2 use WebSocket(Firmata) to interacting with the server.
  • 3 Server use TCP/IP(Firmata) to control webduino terminal.
item compared Webduino Arduino Micro:bit
development language HTML/JavaScript C/C++ Python/JavaScript
development environment WEB browser Arduino IDE JavaScript Blocks
Simulator Webduino Simulator Third-party support Microsoft MakeCode
graphical programming Wbduino blockly Third-party Scratch Blockly
Cloud Server webduino cloud N/A N/A
attended mode WiFi USB USB
Update the program web online update USB burn USB disk
Webduino source code on github
More webduino function now is open source , and code update to github.
https://github.com/webduinoio
How to power the Bit:bit board
Board a total of three power supply, you can choose one
  • 1,USB cable power supply, bit board design has a Micro USB interface, in daily life wire is relatively common, it is quite convenient to use.
  • 2,Power is supplied through 2Pin battery socket, which can supply power to the board through lithium battery, battery pack, etc. The interface has anti-stay design, and there is no need to worry about the problem of inverting the power supply
  • 3,Through the goldfinger power supply, the lower end of the board goldfinger contains a power interface, while both input and output functions, compatibility is very high.
Webduino firmware programming
How to burn webduino firmware
bpi:bit has been programmed Webduino firmware by default. Only when you reprogram the flash with other firmware, will you need to program Webduino firmware again.
How to : Webduino firmware programming
Webduino OTA Cloud upgrade
BPI:bit for webduino support OTA cloud upgrade , it is easy to use this function to update newest version.
power on bit ,Press the A button when flash white light, unpress A booton when when the green light is on, so start to update.
Initialization of Webduino Bit
Initialization of Webduino Bit:https://www.webduino.com.cn/site/en/docs/setting.html
if you can connect BPI:Bit to internet ,so you can use webduino blockly to use webduino all functions.
Webduino Blockly and simulator
  • Webduino Blockly and simulator
Webduino online Blockly (english): https://bit.webduino.com.cn/blockly/?lang=en
Webduino online Blockly (chinese) https://bit.webduino.io/blockly/?lang=zh-hant
Quick start BPI:bit with Webduino Blockly and simulator
http://www.webduino.com.cn/site/en/tutorials.html
Get to know Webduino Blockly Bit
Get to know Webduino Blockly Bit :https://www.webduino.com.cn/site/en/docs/blockly.html
Webduino Cloud
https://cloud.webduino.io
webduino refer to the tutorial
  • BPI:bit Through the photosensitive resistors built into Webduino Bit on the left and right sides, it is easy to determine which side the gesture comes from
  • Using Webduino Bit nine shaft sensor "attitude Angle" + full color dot matrix, simple implementation ~ ^_^ interesting effects
Online tutorials
