Banana Pi BPI-M4 Zero with Allwinner H618 chip
Banana Pi BPI-M4 Zero is the successor model of M2 Zero. It has a huge improvement in performance. The SOC is upgraded to H618 and the CPU frequency is increased by 25%. The memory is upgraded to DDR4, the capacity is quadrupled, and 8G eMMC is added. It supports 5G WiFi, and the USB interface has also been upgraded to type-C.
It has same form factor and 40-pin connector as the Raspberry Pi Zero W, and it can fit most of the RPI Zero W cases and accessories.
Allwinner H618, Quad-core ARM Cortex™-A53 processor
ARM Mali G31 GPU
2.4G/5G WIFI & Bluetooth 4.2
2G LPDDR4 RAM
8G eMMC flash memory
1x USB2.0 Type-C OTG, 5V power supply
1x USB2.0 Type-C
1x miniHDMI 2.0a
1x 24-pin FPC connector
1x USB2.0
1x 100Mbps Ethernet
Hardware Specification of Banana pi BPI-M4 Zero
CPU
Allwinner H618, Quad-core ARM Cortex™-A53 processor, 64-bit, up to 1.5GHz
GPU
ARM Mali G31 GPU
Memory
2 GB LPDDR4
Storage
8G eMMC flash
SD card
MicroSD card slot, SDIO3.0
Wireless
2.4G/5G WiFi and Bluetooth 4.2
HDMI
1x miniHDMI 2.0a (up to 4K@60Hz with HDR10, CEC, DDC, SCDC), HDMI digital Audio output
USB
1x USB2.0 Type-C HOST, 1x USB2.0 Type-C OTG
40-pin header
28 pins GPIO and Power (+5V, +3.3V and GND)
24-pin FPC
0.5mm pitch FPC connector, 1x USB2.0, 1x IR, 1x 100Mbps Ethernet
9 pins GPIO, UART,TWI/I²C, PWM, PCM/I²S
Buttons
Reset, FEL
LED
Power Status and Activity status
Power
5V@3A via USB Type-C
Size
65mm × 30mm
Weight
PIN define
Pin Num
Pin Name
ALT0
ALT1
ALT2
ALT3
3.3V
2
5V
3
PG16
UART2_RX
TWI4_SDA
4
5V
5
PG15
UART2_TX
TWI4_SCK
6
GND
7
PG19
PWM1
8
PG6
UART1_TX
9
GND
10
PG7
UART1_RX
11
PH2
UART5_TX
PWM2
12
PG11
H_I2S2_BCLK
13
PH3
UART5_RX
PWM1
14
GND
15
PG2
16
PG8
UART1_RTS
17
3.3V
18
PG9
UART1_CTS
19
PH7
UART2_RTS
H_I2S3_LRCK
SPI1_MOSI
20
GND
21
PH8
UART2_CTS
H_I2S3_DOUT0
SPI1_MISO
H_I2S3_DIN1
22
PG1
23
PH6
UART2_RX
H_I2S3_BCLK
SPI1_CLK
24
PH5
UART2_TX
H_I2S3_MCLK
SPI1_CS0
25
GND
26
PH9
H_I2S3_DIN0
SPI1_CS1
H_I2S3_DOUT1
27
PG18
UART2_CTS
TWI3_SDA
28
PG17
UART2_RTS
TWI3_SCK
29
PG3
30
GND
31
PG4
32
PG0
33
PG5
34
GND
35
PG12
H_I2S2_LRCK
36
PH4
37
PG10
H_I2S2_MCLK
38
PG14
H_I2S2_DIN0
H_I2S2_DOUT1
39
GND
40
PG13
H_I2S2_DOUT0
H_I2S2_DIN1
24-pin FPC
24-pin FPC define and GPIO Alternative Functions Assignments
Pin Num
Pin Name
ALT0
ALT1
GND
2
EPHY_RXN
3
EPHY_RXP
4
EPHY_TXN
5
EPHY_TXP
6
GND
7
PI9
UART3_TX
TWI2_SCK
8
PI10
UART3_RX
TWI2_SDA
9
PI12
UART3_CTS
PWM2
10
PI11
UART3_RTS
PWM1
11
3V3
12
3V3
13
PI4
H_I2S0_DIN0
H_I2S0_DOUT1
14
PI3
H_I2S0_DOUT0
H_I2S0_DIN1
15
PI2
H_I2S0_LRCK
16
PI1
H_I2S0_BCLK
17
PI0
H_I2S0_MCLK
18
GND
19
PH10
IR_RX
20
5V
21
5V
22
USB2_DP
23
USB2_DM
24
GND
BPI-M4 Zero Debug UART
GND
2
UART0_RX
3
UART0_TX
Baidu Cloud: https://pan.baidu.com/s/1yMlLXauxZywujH8WkYqEcQ?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/drive/folders/1qQxQik4GJjOF1aEOs9a1YVFxJBPlyFnc?usp=sharing
Baidu Cloud: https://pan.baidu.com/s/1Mjpa8V_rm9S_advARWvzKA?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/file/d/1HBTiiMwU5mz2ogGsBUwHz2idkqJpXCNB/view?usp=sharing
BPI-M4 ZERO Schematic diagram
Baidu Cloud: https://pan.baidu.com/s/1KPAf3tz_-h-9PWv-6VcAJg?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/file/d/1WUFn_GItB6fBIt0C-ejdyu3FwznuGmCr/view?usp=sharing
BPI-M4 Zero SBC bench test:
2024-01-14-bananapi-m4zero-android12-box.img.
Baidu Cloud: https://pan.baidu.com/s/1HRiOLLBwdrLehv_z2sksfA?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/drive/folders/15XDTLd5VqZxfgmv7tlqDBHrgOGvaBofU?usp=sharing
Baidu Cloud: https://pan.baidu.com/s/1rNXZc_OKJHyUVOPXtCixcQ?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/drive/folders/18ZvhcAMIOWyAZxHcxNGJmKVjZidYqGtW?usp=sharing
20240314-Bpi-m4zero_1.0.1_debian12_bookworm_desktop_xfce_linux6.1.31
Baidu cloud: https://pan.baidu.com/s/1QJ0wFHxLMvaJgiCkk_NBpw?pwd=8888 (pincode:8888)
Google drive: https://drive.google.com/file/d/1OKrAm2fX8pLpiYM6GcQOIyNdcgQh9_bH/view?usp=sharing
20240314-Bpi-m4zero_1.0.1_debian12_bookworm_minimal_linux6.1.31
Baidu cloud: https://pan.baidu.com/s/1oGq-HaHJoiUsUqIQwp72_Q?pwd=8888 (pincode:8888)
Google drive: https://drive.google.com/file/d/1dNkG1sbh2EkKD9UUmUhT9LtdbfF3rT_c/view?usp=sharing
20240315_Bpi-m4zero_1.0.1_debian11_bullseye_desktop_xfce_linux6.1.31
Baidu Cloud: https://pan.baidu.com/s/1mkjxqcDDyDXDQ-ZJ_7Dcag?pwd=8888(pincode:8888 )
Google Drive: https://drive.google.com/file/d/1RyIC-1AsVUk9i8aL6c37uDcB3VIBQJwk/view?usp=sharing
20240315_Bpi-m4zero_1.0.1_debian11_bullseye_minimal_linux6.1.31
Baidu Cloud: https://pan.baidu.com/s/1x2ByNdQJHRxRxRIo5Ui1lA?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/file/d/19BjUfWAH8pQdVtxN1Ow6QERlSm5o5g5e/view?usp=sharing
20240314-Bpi-m4zero_1.0.1_ubuntu24.04_jammy_desktop_xfce_linux6.1.31
Baidu Cloud: https://pan.baidu.com/s/1GigN7INJarQnqJL5pQNK4g?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/file/d/1AhQqo54W4QOS36ek9lxoMnewk0F5nIoX/view?usp=sharing
20240314-Bpi-m4zero_1.0.1_ubuntu24.04_jammy_minimal_linux6.1.31
Baidu Cloud: https://pan.baidu.com/s/1nV6AJUayGSmLsUhIrMq9IQ?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/file/d/1CttN-hCD1PWImalYPh8QuxWsa2BPEyz-/view?usp=sharing
SINOVOIP Aliexpress shop: https://www.aliexpress.us/item/1005006325178305.html
Bipai Aliexpress shop: https://www.aliexpress.us/item/1005006325280213.html
Taobao Shop: https://item.taobao.com/item.htm?spm=a21dvs.23580594.0.0.4fee3d0dOP5VBH&ft=t&id=754939469582
OEM&ODM, please contact: [email protected]
