香蕉派 BPI-M4 Zero
产品介绍
M4 Zero是M2 Zero的后续型号,在性能上有着巨大提升,SOC升级为H618, CPU频率提升25% 。内存升级为DDR4, 容量翻4倍,新增8G eMMC。支持5G WiFi, 另外USB接口也升级为type-C,它的外形大小和40-pin接头与Raspberry Pi Zero W相同,它将适合Zero W的大部分外壳和配件。
  • ARM Mali G31 GPU
  • 2.4G/5G WIFI & Bluetooth 4.2
  • 2G LPDDR4 RAM
  • 8G eMMC flash memory
  • 1x USB2.0 Type-C
  • 1x miniHDMI 2.0a
  • 1x 24-pin FPC connector
    • 1x USB2.0
    • 1x 100Mbps Ethernet
快速上手
硬件接口
Hardware Specification of Banana pi BPI-M4 Zero
GPU ARM Mali G31 GPU
Memory 2 GB LPDDR4
Storage 8G eMMC flash
SD card MicroSD card slot, SDIO3.0
HDMI 1x miniHDMI 2.0a (up to 4K@60Hz with HDR10, CEC, DDC, SCDC), HDMI digital Audio output
USB 1x USB2.0 Type-C HOST, 1x USB2.0 Type-C OTG
40-pin header 28 pins GPIO and Power (+5V, +3.3V and GND)
24-pin FPC 0.5mm pitch FPC connector, 1x USB2.0, 1x IR, 1x 100Mbps Ethernet
9 pins GPIO, UART,TWI/I²C, PWM, PCM/I²S
Buttons Reset, FEL
Power 5V@3A via USB Type-C
Size 65mm × 30mm
Weight
PIN 定义
BPI-M4 Zero 40-pin header
24-pin FPC
24-pin FPC define and GPIO Alternative Functions Assignments
1 GND
2 EPHY_RXN
3 EPHY_RXP
4 EPHY_TXN
5 EPHY_TXP
6 GND
7 PI9 UART3_TX TWI2_SCK
8 PI10 UART3_RX TWI2_SDA
9 PI12 UART3_CTS PWM2
10 PI11 UART3_RTS PWM1
11 3V3
12 3V3
13 PI4 H_I2S0_DIN0 H_I2S0_DOUT1
14 PI3 H_I2S0_DOUT0 H_I2S0_DIN1
15 PI2 H_I2S0_LRCK
16 PI1 H_I2S0_BCLK
17 PI0 H_I2S0_MCLK
18 GND
19 PH10 IR_RX
20 5V
21 5V
22 USB2_DP
23 USB2_DM
24 GND
BPI-M4 Zero Debug UART
1 GND
2 UART0_RX
3 UART0_TX
开发
源码
资源
  • BPI-M4 Zero DXF 文件
  • BPI-M4 ZERO 原理图
Baidu cloud: https://pan.baidu.com/s/1kceiTekfFvYFsXrLiQrxQA?pwd=8888 (pincode: 8888)
Google drive: https://drive.google.com/file/d/1AtKZROqmdPSz2XQzdeQLL4K6wCPerqeu/view?usp=sharing
  • BPI-M4 Zero SBC bench test:
  • Allwinner H618 数据手册
系统镜像
  • 2024-08-19-bananapi-m4zero-android12.zip
Baidu cloud: https://pan.baidu.com/s/1OUJEnathYgcPsmsX5CSj9w?pwd=8888 (pincode: 8888)
Google drive: https://drive.google.com/file/d/1twgJpV4kbHkK-OKiEwhMCIxbnkIw74dF/view?usp=sharing
  • 20240819-Bananapi-Armbian_24.8.0-trunk_Bpi-m4zero_Ubuntu22.04
Baidu cloud: https://pan.baidu.com/s/14d-s9O2cJco9fFsBUcUYoQ?pwd=8888 (pincode: 8888)
Google drive: https://drive.google.com/drive/folders/1-MzSVsduPX8qHKgbAOM3wmcCbwfkffAz?usp=sharing
  • 20240819-Bananapi-Armbian_24.8.0-trunk_Bpi-m4zero_Debian12
Baidu could: https://pan.baidu.com/s/1MFQE8zJVXeUKV9ZHeznWpA?pwd=8888 (pincode: 8888)
Google drive: https://drive.google.com/drive/folders/1Csk5mTyInOaWP6HsZbt_nk8V7dlG6Db0?usp=sharing
购买
  • 速卖通店铺
SINOVOIP Aliexpress shop: https://www.aliexpress.us/item/1005006325178305.html
Bipai Aliexpress shop: https://www.aliexpress.us/item/1005006325280213.html
淘宝店铺: https://item.taobao.com/item.htm?spm=a21dvs.23580594.0.0.4fee3d0dOP5VBH&ft=t&id=754939469582
