Banana Pi BPI-M7
Banana Pi BPI-M7 with Rockchip RK3588, 8/16/32G,RAM 64/128G eMMC,wifi6 support . 2x2.5G port ,1xHDMIout ,2x USB3.0,2xTYPE-C,2x MIPI CSI interface and 1x MIPI DSI interface, 1x M.2 KEY M interface,40 PIN GPIO ,Mini size just 92x62mm.
- PI-co ITX form factor(2.5 inch, 92 x 62mm)
- RK3588 powered, 8nm manufacturing process
- Quad A76 2.4Ghz + Quad A55 1.8Ghz
- Mali G610MC4 GPU(up to 5 channel 4K UI)
- 6T NPU
- 8K 10bit decoder, 8K encoder
- Support WiFi 6 and BT5.2
- Support PCIe 3.0 x4 NVMe SSD
- Triple display support(with HDR)
- One HDMI 2.1 up to 8K@60FPS
- One USB C with DP up to 8K@30FPS
- One MIPI DSI up to 4K@60fps
- Two 2.5G Ethernet
- 2x USB 3.0 interface
- 2x MIPI CSI camera interface
- Offer 8GB/16GB/32GB(LPDDR4x) ram options and 64/128 eMMC options
HardWare Specification of Banana pi BPI-M7 | |||
SOC | RockChip RK3588 | ||
CPU | RK3588 Quad-Core Cortex-A76@ 2.4GHz+Quad-CoreCortex-A55@ 1.8GHz,8nm process | ||
GPU | GPU Mali-G610 MP4 (4x256KB L2 Cache) Supports OpenGL ES3.2/OpenCL2.2/Vulkan1.1 | ||
NPU | 6 TOPS@INT8(3 NPU core) | ||
Supports INT4/INT8/INT16 mixed computing | |||
Supports frameworks like TensorFlow, MXNet, PyTorch, Caffe, Tflite, Onnx NN, Android NN, etc | |||
VPU/Codec | Hardware Decode: 8K@60fps H.265/VP9/AVS2、 8K@30fps H.264 AVC/MVC、 4K@60fps AV1、1080P@60fps MPEG-2/-1/VC-1/VP8 | ||
Hardware Encode:8K@30fps H.265 / H.264 | |||
ISP | Integrated 48MP ISP with HDR&3DNR | ||
RAM | 8GB/16GB/32GB(max 32GB )64bit LPDDR4/LPDDR4x,default 8GB LPDDR4x | ||
Flash | 32GB/64GB/128GB eMMC,default 64GB eMMC,Supports MicroSD card expansion | ||
PCIe | 1x M.2 Key M (PCIe 3.0 4-lanes). Expandable SSD support for 2280/2260/2242/2230 M.2 SSD cards, default 2280 | ||
Networking | 2x 2.5G Ethernet | ||
Onboard IEEE 802.11a/b/g/n/ac/ax WIFI6 and BT5 (AP6275P) | |||
Video Out | 1x HDMI 2.1, supports 8K@60fps | ||
1x MIPI DSI up to 4K@60fps | |||
1x DP 1.4 up to 8K@30fps | |||
Video In | 2x 2-lane MIPI CSI, up to 2.5Gbps per lane | ||
Audio | 1x HDMI audio out | ||
1x HP audio out | |||
1x Type-C 3.1 (DP1.4) audio out | |||
USB | 1x USB 3.0 (USB 3.1 Gen 1), equivalent to USB 3.2 Gen 1/USB 3.0, up to 5Gbps | ||
1x USB Type-C 3.1(DP1.4/OTG) | |||
1x USB 2.0 High(480Mbps)/Full(12Mbps)/Low-Speed(1.5Mbps) modes | |||
40-pin | Fully compatible with Raspberry Pi 40-pin header for connecting abundant add-on modules | ||
Supports UART/SPI/I2C/I2S/PWM/ADC/5V Power/3.3V Power | |||
Other | 1x 5V fan interface | ||
1x battery connector for low power RTC chip HYM8563TS | |||
2x LEDs - blue LED blinks on system start, red LED user controllable | |||
Power Input | USB Type-C PD 2.0, 9V/2A, 12V/2A, 15V/2A | ||
Buttons | 1x PWRON button for sleep/wake,1x Reset button for reboot,1x Maskrom button for maskrom burn-in mode | ||
OS Support | Official: :Android 12.0,Debian11,Buildroot | ||
3rd Party:Armbian,Ubuntu 20.04,Ubuntu22.04,Kylin OS | |||
Dimensions | 92 mm x 62mm | ||
Operating temperature | 0℃ ~ 80℃ |
Case design
- Rockchip RK3588 datasheet :https://drive.google.com/file/d/1ewQwywq19Zh2M6MFVgsMJUCaBTOEo8rl/view?usp=drive_link
- BPI-M7 GPU and CPU performance test:https://www.youtube.com/watch?v=C4ofIZLixpM
- BPI-M7 Rockchip RK3588 open source SBC run istoreos demo:https://www.youtube.com/watch?v=I2SSCT1Xj_U
- BPI-M7 SBC ubuntu20.04 Linux system adaptation is complete:https://www.youtube.com/watch?v=60XQlSF3_20&t=10s
