香蕉派 BPI-R2 Pro
Rockchip RK3568 chip
BPI-R2 Pro case same as BPI-R2
BPI-RK3588 Core board and development Kit
File:Baanna Pi BPI-W3 2.jpg
BPI-R2 pro 介绍
  • Mali-G52 1-Core-2EE
  • 2G LPDDR4 SDRAM (option 4G)
  • support 1 SATA interface
  • 1 CSI camera interface
瑞芯微(Rockchip) RK3568芯片介绍
快速上手
Getting Started with R2PRO
BPI-R2 Pro硬件接口示意图
香蕉派 BPI-R2 Pro
CPU主控 Rockchip RK3568 Quad-core ARM Cortex-A55 CPU 2GHz
GPU图形引擎 Mali-G52 1-Core-2EE OpenGL ES3.2 Vu1kn 1.1 OpenCL 2.0
Memory内存 2G DDR3 SDRAM (option 4G)
存储 Onboard 16GB eMMC Flash, Micro SD-Card slot, SATA 3.0 Port,SPI flash
网络接口 5 x 10/100/1000 Mbit/s Ethernet
显示(s) 1 HDMI port, 2 DSI interface(1 DSI can change to LVDS by software)
Camera摄像头 1 CSI camera interfact
Video decoder(s) H.265 HEVC/MVC Main10 Profile [email protected] up to 4096x2304@60fps,H.264 AVC/MVC Main10 Profile yuv400/yuv420/yuv422/@L5.1 up to 4096x2304@60fps
Video encoder(s) H.264/AVC BP/MP/[email protected],up to 1920x1080@100fps, H.265/HEVC [email protected], up to 1920x1080@100fps (4096x4096@10fps with TILE)
Remote IR Receiver (x1)
LED Power Status and 8P8C
GPIO PIN 定义
开发资源
软件源代码
参考文档
镜像发布
Note: the network disk include linux-4.19.xx and linux-5.10.66 kernel version, linux-5.10.66 kernel version can support DSA feature.
kernel linux-5.10.66 Release image, support DSA feature
Supported OS Note: OpenWRT, Debian10, Ubuntu 16.04. Ubuntu 20.04, Ubunutu 22.04, Ubunut OS support server version, desktop version, mate desktop version.
AltLinux for Banana Pi BPI R2 pro
Armbian and LibreELEC for BPI-R2-pro
kernel linux-4.19.xx Release image
ubuntu 21.04
  • ubuntu 21.04 linux kernel 4.19 image 2022-5-16 update, HDMI ,eDP and SDIO interface RTL8822CS WIFI module working fine
google driver: https://drive.google.com/drive/folders/1pFayiLS3cS0idClUlvHzaySaJMb_AOrB
baidu link: https://pan.baidu.com/s/1zUVDXOmEur3KFpNW_va7Wg?pwd=ci4u Pincode ci4u
video and boot log:https://forum.banana-pi.org/t/banana-pi-bpi-r2-pro-openwrt-ubuntu-debian-linux-image/13158
  • OpenWRT-21.02 linux kernel 4.19 image, 2022-5-16 update,HDMI ,eDP and SDIO interface RTL8822CS WIFI module working fine
google driver: https://drive.google.com/drive/folders/10HzNC0pWhS8j3W7uaFQ5RGO7UK133Xt-
baidu link: https://pan.baidu.com/s/1KUIJUB6nd_vKmRXms7NUKg?pwd=i72r Pincode: i72r
  • Debian 10 linux kernel 4.19 image, 2022-5-16 update ,HDMI ,eDP and SDIO interface RTL8822CS WIFI module working fine
google driver: https://drive.google.com/drive/folders/1LSJlHtkHC_Ua6zVgVI3BRJOVPUb6vWO6
baidu link: https://pan.baidu.com/s/1rkVWlpeY0hIKPrIh3r7Nfw?pwd=n9gi Pincode: n9gi
How to flash Android Image
  • 2022-11-16 release, Android12-bpi-r2pro.img
Google Drive: https://drive.google.com/file/d/1UZ-e6QJIB8ZU-rdGsCnDNaNR2pYHHvxA/view?usp=share_link
Baidu Cloud: https://pan.baidu.com/s/1tQ5Fg47R0fpUajYpNIsJ3g?pwd=8888 (pincode: 8888)
MD5:a7b5faf7818f1ab2d36253a5d3ca1d18
Forum pthread:https://forum.banana-pi.org/t/bananapi-bpi-r2-pro-2022-11-16-android-12/14264
  • 2022-09-06 release, Android11-atv-bpi-r2pro image
Google Drive:https://drive.google.com/file/d/1E50R-8T3L42CUUYyv1eFw0Zvl1js3EuI/view?usp=sharing
Baidu Cloud:https://pan.baidu.com/s/10N9ZgrgVJ3SiCoNxi681Hw?pwd=jmrn (pincode: jmrn)
MD5: 82787086a4acf8e2d818b948670580cd
  • 2022-09-06 release, Android11-bpi-r2pro image
Google Drive:https://drive.google.com/file/d/1xY6ynrpJXIbo4vbz_P7KaiUAVLJQthzs/view?usp=sharing
Baidu Cloud:https://pan.baidu.com/s/14iLchseyarxAKHCzrfnaEg?pwd=1gul (pincode:1gul)
MD5: 83fa3ac4f0addcf3d47d20a58be39f50
  • 2022-06-10 release, Android 11 with kernel 4.19.219, tablet variant image
Google Drive: https://drive.google.com/file/d/1qiLZKU8_2O0hHgP25F0CRxv9MnSJlXpv/view?usp=sharing
Baidu Cloud:https://pan.baidu.com/s/1EUiGaXuPxAkR69g7EOnVaw?pwd=4n6c (pincode: 4n6c)
MD5: ebd336bad0c27c66ae65a4d38103bced
  • 2022-06-10 release, Android 11 with kernel 4.19.219, atv variant image
Google Drive: https://drive.google.com/file/d/104K7W1PX4OFvUtqNGHOnx6RZO49BrTZp/view?usp=sharing
Baidu Cloud: https://pan.baidu.com/s/1RbNf1dFqMxy1Dx_ysym82w?pwd=v4u8 (pincode: v4u8)
MD5: 49506a8a3183ab189046b5e2e2833b87
样品购买
