Banana Pi BPI-W3
BPI-RK3588 Core board and development Kit Gold finger interface core board
BPI-RK3588 Core board and development Kit Stamp hole Core board
BPI-RK3588 BPI-RK3588 Core board and development Kit Stamp hole Core board and development Kit
The Banana Pi BPI-W3 is a router based development board, it design with Rochchip RK3588 quad ARM Cortex-A76 and quad Cortex-A55 consists of an eight-core CPU processor. ,6Tops@INT8 NPU,8G memory,32G eMMC storage on board .which can run on a variety of open source operating systems including OpenWrt, Android, and linux. It has 1 Gigabit LAN ports, 1 Gigabit WAN., it also with 2 HDMI out and 1 HDMI in port.
File:Banana Pi BPI-W3 Banner.jpg
- ARM Mali-G610 MP4,
- NPU for AI : 6Tops@INT8
- 8G RAM and 32G eMMC flash onbord
- 2x 10/100/1000Mbps Ethernet
- support HDMI in and HDMI out
SoC | RockChip RK3588 |
CPU | quad ARM Cortex-A76 and quad Cortex-A55 consists of an eight-core CPU processor |
GPU | ARM Mali-G610 MP4,support OpenGL ES 1.1/2.0/3.2,OpenCL 2.2,Vulkan 1.1 Embedded high-performance 2D acceleration hardware |
NPU | 6Tops@INT8 , |
Video decode | Caffe/TensorFlow/TFLite/ONNX PyTorch/Keras/Darknet mainstream architecture model of a key transformation VPU support 8 k 60 FPS h. 265 / AVS2 Profile0 / VP9 video decoding |
Video encode | Supports 8K 30FPS H.265/H.264 video encoding |
RAM | 8GB LPDDR4 |
eMMC flash | 32GB |
Onboard Network | 2x 10/100/1000Mbps Ethernet |
HDMI | 2 HDMI Out and 1 HDMI in |
GPIO | 40 Pins Header, 28×GPIO, some of which can be used for specific functions including UART, I2C, SPI, PWM, I2S. |
SATA | 1 SATA hardisk interface |
System | Android 12.0 ,Linux support |
Power | current and voltage 12V/2A |
operating temperature | 0℃ ~ 80℃(Measurement can reach -20 degrees to 85 degrees) |
size | 148mm * 101mm |
GPIO number | Function8 | Function7 | Function6 | Function5 | Function4 | Function3 | Function2 | Function1 | Pin# |
+3.3V | 1 | ||||||||
139 | I2S1_SDO2_M0 | I2C7_SDA_M3 | UART8_CTSN_M0 | PWM15_IR_M1 | CAN1_TX_M1 | GPIO4_B3 | 3 | ||
138 | I2S1_SDO1_M0 | I2C7_SCL_M3 | UART8_RTSN_M0 | PWM14_M1 | CAN1_RX_M1 | GPIO4_B2 | 5 | ||
115 | SPI1_CS1_M1 | I2C8_SDA_M4 | UART7_CTSN_M1 | PWM15_IR_M0 | GPIO3_C3 | 7 | |||
GND | 9 | ||||||||
113 | SPI1_CLK_M1 | UART7_RX_M1 | GPIO3_C1 | 11 | |||||
111 | SPI1_MOSI_M1 | I2C3_SCL_M1 | GPIO3_B7 | 13 | |||||
112 | SPI1_MISO_M1 | I2C3_SDA_M1 | UART7_TX_M1 | GPIO3_C0 | 15 | ||||
+3.3V | 17 | ||||||||
42 | SPI0_MOSI_M2 | UART4_RX_M2 | GPIO1_B2 | 19 | |||||
41 | SPI0_MISO_M2 | GPIO1_B1 | 21 | ||||||
43 | SPI0_CLK_M2 | UART4_TX_M2 | GPIO1_B3 | 23 | |||||
GND | 25 | ||||||||
150 | SPI3_CLK_M0 | I2C0_SDA_M1 | PWM7_IR_M3 | GPIO4_C6 | 27 | ||||
63 | UART1_CTSN_M1 | PWM15_IR_M3 | GPIO1_D7 | 29 | |||||
47 | SPDIF_TX_M0 | UART1_RX_M1 | PWM13_M2 | GPIO1_B7 | 31 | ||||
103 | PWM8_M0 | GPIO3_A7 | 33 | ||||||
110 | I2S2_LRCK_M1 | UART3_RX_M1 | PWM13_M0 | CAN1_TX_M0 | GPIO3_B6 | 35 | |||
37 | |||||||||
GND | 39 |
Pin# | Function1 | Function2 | Function3 | Function4 | Function5 | Function6 | Function7 | Function8 | GPIO number |
2 | +5.0V | ||||||||
4 | +5.0V | ||||||||
6 | GND | ||||||||
8 | GPIO0_B5 | UART2_TX_M0 | I2C1_SCL_M0 | I2S1_MCLK_M1 | 13 | ||||
10 | GPIO0_B6 | UART2_RX_M0 | I2C1_SDA_M0 | I2S1_SCLK_M1 | 14 | ||||
12 | GPIO3_B5 | CAN1_RX_M0 | PWM12_M0 | UART3_TX_M1 | I2S2_SCLK_M1 | 109 | |||
14 | GND | ||||||||
16 | GPIO3_A4 | 100 | |||||||
18 | GPIO4_C4 | PWM5_M2 | SPI3_MISO_M0 | 148 | |||||
20 | GND | ||||||||
22 | SARADC_IN4 | ||||||||
24 | GPIO1_B4 | UART7_RX_M2 | SPI0_CS0_M2 | 44 | |||||
26 | GPIO1_B5 | UART7_TX_M2 | SPI0_CS1_M2 | 45 | |||||
28 | GPIO4_C5 | PWM6_M2 | I2C0_SCL_M1 | SPI3_MOSI_M0 | 149 | ||||
30 | GND | ||||||||
32 | GPIO3_C2 | PWM14_M0 | UART7_RTSN_M1 | I2C8_SCL_M4 | SPI1_CS0_M1 | 114 | |||
34 | GND | ||||||||
36 | GPIO3_B1 | PWM2_M1 | UART2_TX_M2 | 105 | |||||
38 | GPIO3_B2 | PWM3_IR_M1 | UART2_RX_M2 | I2S2_SDI_M1 | 106 | ||||
40 | GPIO3_B3 | UART2_RTSN | I2S2_SDO_M1 | 107 |
