Banana Pi BPI-M4 Zero
![](/images/thumb/e/eb/Banana_Pi_BPI-M4_Zero_1.jpg/300x225x300px-Banana_Pi_BPI-M4_Zero_1.jpg.pagespeed.ic.NbRL9vLJun.jpg)
Banana Pi BPI-M4 Zero with Allwinner H618 chip
![](/images/thumb/4/40/BPI-M2_zero_11.JPG/300x225x300px-BPI-M2_zero_11.JPG.pagespeed.ic.3yYxPgEDZk.jpg)
![](/images/thumb/a/a6/Banana_Pi_BPI-M4_Berry_1.jpg/300x225x300px-Banana_Pi_BPI-M4_Berry_1.jpg.pagespeed.ic.RUYpd3zj9g.jpg)
![](/images/thumb/7/7b/Banana_Pi_BPI-M5_1.JPG/300x225x300px-Banana_Pi_BPI-M5_1.JPG.pagespeed.ic.gFvwugqKO7.jpg)
Banana Pi BPI-M4 Zero is the successor model of M2 Zero. It has a huge improvement in performance. The SOC is upgraded to H618 and the CPU frequency is increased by 25%. The memory is upgraded to DDR4, the capacity is quadrupled, and 8G eMMC is added. It supports 5G WiFi, and the USB interface has also been upgraded to type-C.
It has the same form factor and 40-pin connector as the Raspberry Pi Zero W, and it will fit most Zero W cases and accessories.
- Allwinner H618, Quad-core ARM Cortex™-A53 processor
- ARM Mali G31 GPU
- 2.4G/5G WIFI & Bluetooth 4.2
- 2G LPDDR4 RAM
- 8G eMMC flash memory
- 1x USB2.0 Type-C OTG, 5V power supply
- 1x USB2.0 Type-C
- 1x miniHDMI 2.0a
- 1x 24-pin FPC connector
- 1x USB2.0
- 1x 100Mbps Ethernet
Hardware Specification of Banana pi BPI-M4 Zero | |
CPU | Allwinner H618, Quad-core ARM Cortex™-A53 processor, 64-bit, up to 1.5GHz |
GPU | ARM Mali G31 GPU |
Memory | 2 GB LPDDR4 |
Storage | 8G eMMC flash |
SD card | MicroSD card slot, SDIO3.0 |
Wireless | 2.4G/5G WiFi and Bluetooth 4.2 |
HDMI | 1x miniHDMI 2.0a (up to 4K@60Hz with HDR10, CEC, DDC, SCDC), HDMI digital Audio output |
USB | 1x USB2.0 Type-C HOST, 1x USB2.0 Type-C OTG |
40-pin header | 28 pins GPIO and Power (+5V, +3.3V and GND) |
UART, SPI, TWI/I²C, PWM, PCM/I²S | |
24-pin FPC | 0.5mm pitch FPC connector, 1x USB2.0, 1x IR, 1x 100Mbps Ethernet |
9 pins GPIO, UART,TWI/I²C, PWM, PCM/I²S | |
Buttons | Reset, FEL |
LED | Power Status and Activity status |
Power | 5V@3A via USB Type-C |
Size | 65mm × 30mm |
Weight |
PIN define
BPI-M4 Zero 40-pin header
40-pin header define and GPIO Alternative Functions Assignments | |||||
Pin Num | Pin Name | ALT0 | ALT1 | ALT2 | ALT3 |
1 | 3.3V | ||||
2 | 5V | ||||
3 | PG16 | UART2_RX | TWI4_SDA | ||
4 | 5V | ||||
5 | PG15 | UART2_TX | TWI4_SCK | ||
6 | GND | ||||
7 | PG19 | PWM1 | |||
8 | PG6 | UART1_TX | |||
9 | GND | ||||
10 | PG7 | UART1_RX | |||
11 | PH2 | UART5_TX | PWM2 | ||
12 | PG11 | H_I2S2_BCLK | |||
13 | PH3 | UART5_RX | PWM1 | ||
14 | GND | ||||
15 | PG2 | ||||
16 | PG8 | UART1_RTS | |||
17 | 3.3V | ||||
18 | PG9 | UART1_CTS | |||
19 | PH7 | UART2_RTS | H_I2S3_LRCK | SPI1_MOSI | |
20 | GND | ||||
21 | PH8 | UART2_CTS | H_I2S3_DOUT0 | SPI1_MISO | H_I2S3_DIN1 |
22 | PG1 | ||||
23 | PH6 | UART2_RX | H_I2S3_BCLK | SPI1_CLK | |
24 | PH5 | UART2_TX | H_I2S3_MCLK | SPI1_CS0 | |
25 | GND | ||||
26 | PH9 | H_I2S3_DIN0 | SPI1_CS1 | H_I2S3_DOUT1 | |
27 | PG18 | UART2_CTS | TWI3_SDA | ||
28 | PG17 | UART2_RTS | TWI3_SCK | ||
29 | PG3 | ||||
30 | GND | ||||
31 | PG4 | ||||
32 | PG0 | ||||
33 | PG5 | ||||
34 | GND | ||||
35 | PG12 | H_I2S2_LRCK | |||
36 | PH4 | ||||
37 | PG10 | H_I2S2_MCLK | |||
38 | PG14 | H_I2S2_DIN0 | H_I2S2_DOUT1 | ||
39 | GND | ||||
40 | PG13 | H_I2S2_DOUT0 | H_I2S2_DIN1 |
24-pin FPC
24-pin FPC define and GPIO Alternative Functions Assignments | |||||
Pin Num | Pin Name | ALT0 | ALT1 | ||
1 | GND | ||||
2 | EPHY_RXN | ||||
3 | EPHY_RXP | ||||
4 | EPHY_TXN | ||||
5 | EPHY_TXP | ||||
6 | GND | ||||
7 | PI9 | UART3_TX | TWI2_SCK | ||
8 | PI10 | UART3_RX | TWI2_SDA | ||
9 | PI12 | UART3_CTS | PWM2 | ||
10 | PI11 | UART3_RTS | PWM1 | ||
11 | 3V3 | ||||
12 | 3V3 | ||||
13 | PI4 | H_I2S0_DIN0 | H_I2S0_DOUT1 | ||
14 | PI3 | H_I2S0_DOUT0 | H_I2S0_DIN1 | ||
15 | PI2 | H_I2S0_LRCK | |||
16 | PI1 | H_I2S0_BCLK | |||
17 | PI0 | H_I2S0_MCLK | |||
18 | GND | ||||
19 | PH10 | IR_RX | |||
20 | 5V | ||||
21 | 5V | ||||
22 | USB2_DP | ||||
23 | USB2_DM | ||||
24 | GND |
BPI-M4 Zero Debug UART
1 | GND |
2 | UART0_RX |
3 | UART0_TX |
- u-boot for H618 : https://github.com/BPI-SINOVOIP/pi-u-boot/tree/v2021.07-sunxi
- kernel for H618 : https://github.com/BPI-SINOVOIP/pi-linux/tree/pi-6.1-sunxi
- BPI-M4 Zero Allwinner H618 SBC burn Ubuntu desktop image
- BPI-M4 Zero DXF file
- BPI-M4 Zero SBC bench test:
- Allwinner H618 Datasheet
- Baidu Cloud: https://pan.baidu.com/s/10Rk4xLMOhIkk-gIoQx9DQw?pwd=8888 (pincode:8888)
- Google Drive: https://drive.google.com/file/d/1N6oWF9PHTcxXC1JY4x3Malr3twFv2wWZ/view?usp=sharing
- Aliexpress shop:
- SINOVOIP Aliexpress shop:
- Bipai Aliexpress shop:
- Taobao Shop:
