Banana Pi BPI-W3
Revision as of 03:40, 18 October 2023 by Sinovoip (talk | contribs) (Hardware interface)
RK3588 LGA BGA core board with Rockchip RK3588
BPI-RK3588 Core board and development Kit Gold finger interface core board
BPI-RK3588 BPI-RK3588 Core board and development Kit Stamp hole Core board and development Kit
  • Rockchip RK3588 quad ARM Cortex-A76 and quad Cortex-A55 consists of an eight-core CPU processor
  • ARM Mali-G610 MP4,
  • NPU for AI : 6Tops@INT8
  • 8G RAM and 32G eMMC flash onboard
  • 2.5Gbps Ethernet
  • support HDMI in and HDMI out * 2
BPI-3588-LGA Core board
BPI-3588-LGA core board uses the Rockchip RK3588 flagship chip,integrating a 6Tops NPU and a high-performance quad-core Mali-G610 MP4 GPU. It adopts LGA 506pin package method, which can expand a variety of display interfaces and industrial application interfaces. With open baseboard design materials and open-source SDKs, it can be efficiently developed. It supports multiple operating systems such as Android, Ubuntu, Debian, and Buildroot. It provides robust, stable, reliable, and expandable product support for various AI application scenarios, and is widely applicable to fields such as edge computing, artificial intelligence,cloud computing, VR/AR, blockchain, smart security, intelligent industrial control, and smart home.
SOC RockChip RK3588
CPU Quad Core A76+ Quad Core A55 ,use 8nm , 2.4GHz
GPU ARM Mali-G610 MP4 GPU,Support OpenGL ES3.2 / OpenCL 2.2 / Vulkan1.1, 450 GFLOPS
NPU 6 TOPS,Support INT4/INT8/INT16 mixed operation,Support framework switching of TensorFlow/MXNet/PyTorch/Caffe
Encode&Decode encode:8K@60fps H.265/VP9/AVS2、8K@30fps H.264 AVC/MVC、4K@60fps AV1、1080P@60fps MPEG-2/-1/VC-1/VP8 ,decode:8K@30fps H.265 / H.264
Ram 4GB/8GB/16GB(up to 32GB)64bit LPDDR4/LPDDR4x/LPDDR5,Defalut LPDDR4 8GB
Flash 16GB/32GB/64GB/128GB/256GB eMMC,support MicroSD card slot,Defaut :32GB
M2 Key M The interface supports extension SSD
network 2.5G network port(RLT8125BS)
video output 2 x HDMI2.1(just one support 8K@60fps or 4K@120fps,other support 4K@60fps),1 x MIPI-DSI(4K@60fps),1 x DP1.4(8K@30fps),
video input 1 x 4Lanes MIPI CSI / 2 x 2lanes MIPI CSI,1 x HDMI RX2.0
Voice 2 x HDMI voice output ,1 x DP1.4 voice output,1 x headphone (es8316)
Wireless M2 E key interface support sdio、pcie、usb BT&wifi(AP6256,Intel AX210)
USB 2 x USB3.1,2 x USB2.0,1x USB-C(DP1.4(8K@30fps)/OTG/PD fast charging)
Others Fan、RTC、LED、debug
GPIO 40 x GPIO(UART、SPI、I2C、I2S、PWM、ADC、 GPIO、 5V power 、3.3V power)
Power DC 12V/2.5A bore diameter 2.5mm,support USB Type-C PD 2.0 ,9V/2A, 12V/2A, 15V/2A,Support 12V POE power supply
System Android 12.0、Ubuntu、Debian11、Buildroot、Kylin Linux
Size 148 mm × 100.5mm
operating temperature -10℃ ~ 70℃
storage temperature -20℃ ~ 70℃
40 PIN GPIO
GPIO number Function8 Function7 Function6 Function5 Function4 Function3 Function2 Function1 Pin#
+3.3V 1
139 I2S1_SDO2_M0 I2C7_SDA_M3 UART8_CTSN_M0 PWM15_IR_M1 CAN1_TX_M1 GPIO4_B3 3
138 I2S1_SDO1_M0 I2C7_SCL_M3 UART8_RTSN_M0 PWM14_M1 CAN1_RX_M1 GPIO4_B2 5
115 SPI1_CS1_M1 I2C8_SDA_M4 UART7_CTSN_M1 PWM15_IR_M0 GPIO3_C3 7
GND 9
113 SPI1_CLK_M1 UART7_RX_M1 GPIO3_C1 11
111 SPI1_MOSI_M1 I2C3_SCL_M1 GPIO3_B7 13
112 SPI1_MISO_M1 I2C3_SDA_M1 UART7_TX_M1 GPIO3_C0 15
+3.3V 17
42 SPI0_MOSI_M2 UART4_RX_M2 GPIO1_B2 19
41 SPI0_MISO_M2 GPIO1_B1 21
43 SPI0_CLK_M2 UART4_TX_M2 GPIO1_B3 23
GND 25
150 SPI3_CLK_M0 I2C0_SDA_M1 PWM7_IR_M3 GPIO4_C6 27
63 UART1_CTSN_M1 PWM15_IR_M3 GPIO1_D7 29
47 SPDIF_TX_M0 UART1_RX_M1 PWM13_M2 GPIO1_B7 31
103 PWM8_M0 GPIO3_A7 33
110 I2S2_LRCK_M1 UART3_RX_M1 PWM13_M0 CAN1_TX_M0 GPIO3_B6 35
37
GND 39
Pin# Function1 Function2 Function3 Function4 Function5 Function6 Function7 Function8    GPIO number
2 +5.0V
4 +5.0V
6 GND
8 GPIO0_B5 UART2_TX_M0 I2C1_SCL_M0 I2S1_MCLK_M1 13
10 GPIO0_B6 UART2_RX_M0 I2C1_SDA_M0 I2S1_SCLK_M1 14
12 GPIO3_B5 CAN1_RX_M0 PWM12_M0 UART3_TX_M1 I2S2_SCLK_M1 109
14 GND
16 GPIO3_A4 100
18 GPIO4_C4 PWM5_M2 SPI3_MISO_M0 148
20 GND
22 SARADC_IN4
24 GPIO1_B4 UART7_RX_M2 SPI0_CS0_M2 44
26 GPIO1_B5 UART7_TX_M2 SPI0_CS1_M2 45
28 GPIO4_C5 PWM6_M2 I2C0_SCL_M1 SPI3_MOSI_M0 149
30 GND
32 GPIO3_C2 PWM14_M0 UART7_RTSN_M1 I2C8_SCL_M4 SPI1_CS0_M1 114
34 GND
36 GPIO3_B1 PWM2_M1 UART2_TX_M2 105
38 GPIO3_B2 PWM3_IR_M1 UART2_RX_M2 I2S2_SDI_M1 106
40 GPIO3_B3 UART2_RTSN I2S2_SDO_M1 107
MIPI CSI
0.5mm FPC Connector
Pin# MIPI-CSI Description
1,4,7,10,13,16,19,21,24,25,26,27,32,33 GND Power Ground & Signal Ground
2 MIPI_CSI0_RX_D3N MIPI RX Lane3 iuput N
3 MIPI_CSI0_RX_D3P MIPI RX Lane3 iuput P
5 MIPI_CSI0_RX_D2N MIPI RX Lane2 iuput N
6 MIPI_CSI0_RX_D2P MIPI RX Lane2 iuput P
8 MIPI_CSI0_RX_CLK1N MIPI RX Clock iuput N
9 MIPI_CSI0_RX_CLK1P MIPI RX Clock iuput P
11 MIPI_CSI0_RX_D1N MIPI RX Lane1 iuput N
12 MIPI_CSI0_RX_D1P MIPI RX Lane1 iuput P
14 MIPI_CSI0_RX_D0N MIPI RX Lane0 iuput N
15 MIPI_CSI0_RX_D0P MIPI RX Lane0 iuput P
17 MIPI_CSI0_RX_CLK0N MIPI RX Clock iuput N
18 MIPI_CSI0_RX_CLK0P MIPI RX Clock iuput P
20 MIPI_CAM3_CLKOUT 1.8V, CLock ouput for Sensor
22 MIPI_CAM1_CLKOUT 1.8V, CLock ouput for Sensor
23 MIPI_CSI0_PDN0_H(GPIO1_B0) 1.8V, GPIO
24 I2C3_SCL_M0_MIPI 1.8V, I2C Clock, pulled up to 1.8V with 2.2K on w3
25 I2C3_SDA_M0_MIPI 1.8V, I2C Clock, pulled up to 1.8V with 2.2K on w3
26 MIPI_CSI0_PDN1_H(GPIO1_A7) 1.8V, GPIO
27 CM_RST_L(GPIO4_A0) 3.3V, GPIO
28,29 VCC_RX 3.3V Power ouput
30,31 VCC_5V0 5V Power ouput
MIPI DSI
0.5mm FPC Connector (J23)
Pin# MIPI-DSI Description
1,4,7,10,13,16,27,33,34 GND Power and Signal Ground
2 MIPI_DPHY1_TX_D0N MIPI1 TX Lane0 ouput N
3 MIPI_DPHY1_TX_D0P MIPI1 TX Lane0 ouput P
5 MIPI_DPHY1_TX_D1N MIPI1 TX Lane1 ouput N
6 MIPI_DPHY1_TX_D1P MIPI1 TX Lane1 ouput P
8 MIPI_DPHY1_TX_CLKN MIPI1 TX Clock ouput N
9 MIPI_DPHY1_TX_CLKP MIPI1 TX Clock ouput P
11 MIPI_DPHY1_TX_D2N MIPI1 TX Lane2 ouput N
12 MIPI_DPHY1_TX_D2P MIPI1 TX Lane2 ouput P
14 MIPI_DPHY1_TX_D3N MIPI1 TX Lane3 ouput N
15 MIPI_DPHY1_TX_D3P MIPI1 TX Lane3 ouput P
17 LCD_PWM (PWM2_M2/GPIO4_C2) 1.8V, GPIO/PWM
18,19 VCC3V3_LCD 3.3V Power ouput
20 LCD_RESET (GPIO2_C1) 1.8V, GPIO
21 /NC No Connection
22 LCD_BL_EN (GPIO3_A1) 3.3V, GPIO
23 I2C6_SCL_M0 1.8V, I2C Clock, pulled up to 1.8V with 2.2K on w3
24 I2C6_SDA_M0 1.8V, I2C Data, pulled up to 1.8V with 2.2K on w3
25 TP_INT (GPIO0_D3) 1.8V, GPIO
26 TP_RST (GPIO0_C6) 1.8V, GPIO
28,29 VCC5V0_LCD 5V Power ouput
31,32 VCC_1V8 1.8V Power ouput
Debug UART
3.3V level signals, 1500000bps
Pin# Assignment Description
1 UART2_RX_M0 intput
2 UART2_TX_M0 output
3 GND 0V
PoE In
1.25mm Connector
1 VC1 TX1
2 VC2 RX1
3 VC3 TX2
4 VC4 RX2
PoE Out
2.0mm Connector
1 VDD_POE 12V Power ouput
2 VDD_POE 12V Power ouput
3 GND Ground pin
4 GND Ground pin
Fan
1.25mm Connector
2 VCC_5V0 5V Power ouput
3 PWM1_M0/GPIO0_C0 1.8V, PWM/GPIO
  • Banana PI BPI-W3 SCH, DXF, SMD file:
Baidu cloud  : https://pan.baidu.com/s/1cxHc0nRnav2jH1BEpFjxLQ?pwd=arms Pincode: arms
Google drive: https://drive.google.com/drive/folders/1tzVbrZYoj6G6ShwTfe1Cxv8wC4knKBOu?usp=drive_link
  • Banana Pi BPI-W3 coare board 3588-LGA Core board all pin list file(5.core board (LGA) pin List)
Rockchip RK3588 datasheet :https://drive.google.com/file/d/1KAq1_kKqPtkq8Vlq-h_yUPUZLrgqSKHI/view?usp=sharing
Banana Pi BPI-W3 RK3588 NPU6T AI RKNN Toolkit2 and RKNPU2 demo :https://www.youtube.com/watch?v=AEU87YUZz8Y
  • BPI-W3 android 12 image 2023.4.14 update:
Google drive:https://drive.google.com/drive/folders/17JueSJx6xBgoXGixRkoIpuFMazS3LEou?usp=drive_link
  • BPI-W3 armbian image 2023.4.14 update
Google drive:https://drive.google.com/drive/folders/1toeRkmdbo2dnhSnEEtFLipefn5GsnA2q?usp=drive_link
Baidu cloud: https://pan.baidu.com/s/1cxHc0nRnav2jH1BEpFjxLQ?pwd=arms Pincode: arms
Google drive:https://drive.google.com/drive/folders/189hdj2vfzmJgar1XxVbPhUJGWPRtinUZ?usp=drive_link
BPI-W3 Tools
Baidu cloud :https://pan.baidu.com/s/1ocWvRUz4IFCoZBjSx7MavQ?pwd=arms Pincode:arms
Google drive: https://drive.google.com/drive/folders/1WJxMzmInB1xr3DpDQXYblU0iM9RbsmPF?usp=drive_link
