Banana Pi BPI-R2 Pro
- Rockchip RK3568 Quad-core ARM Cortex-A55 CPU
- Mali-G52 1-Core-2EE
- 2G LPDDR4 SDRAM (option 4G)
- Mini PCIE interface and M.2 key-e interface
- support 1 SATA interface
- 16G eMMC flash (option 16/32/64G)
- 2 MIPI display interface support
- 1 CSI camera interface
Rockchip RK3568
| Banana Pi R2 Pro | |
| CPU | Rockchip RK3568 Quad-core ARM Cortex-A55 CPU 2GHz |
| GPU | Mali-G52 1-Core-2EE OpenGL ES3.2 Vu1kn 1.1 OpenCL 2.0 |
| Memory | 2G DDR3 SDRAM (option 4G) |
| Storage | Onboard 16GB eMMC Flash, Micro SD-Card slot, SATA 3.0 Port,SPI flash |
| Network | 5 x 10/100/1000 Mbit/s Ethernet |
| Display(s) | 1 HDMI port, 2 DSI interface(1 DSI can change to LVDS by software) |
| Camera | 1 CSI camera interfact |
| Video decoder(s) | H.265 HEVC/MVC Main10 Profile [email protected] up to 4096x2304@60fps,H.264 AVC/MVC Main10 Profile yuv400/yuv420/yuv422/@L5.1 up to 4096x2304@60fps |
| Video encoder(s) | H.264/AVC BP/MP/[email protected],up to 1920x1080@100fps, H.265/HEVC [email protected], up to 1920x1080@100fps (4096x4096@10fps with TILE) |
| Audio Output(s) | HDMI & I2S & Speaker & Headphone |
| USB port | USB 3.0 PORT (x2), micro USB OTG (x1) |
| mini PCIE | 1 mini pcie interface & 1 M.2 key-e interface |
| Remote | IR Receiver (x1) |
| Power Source | 12 volt @2A via DC Power and/or Micro USB (OTG) |
| Size & Weight | 148 mm × 100.5mm 100g |
| OS | OpenWRT, Linux and others OS |
Source Code
- linux-4.19.xx kernel BSP Source code on github :https://github.com/BPI-SINOVOIP/BPI-R2PRO-BSP/
- linux-5.10.66 kernel BSP Source code on github :https://github.com/BPI-SINOVOIP/BPI-R2PRO-BSP-5.10.x/
- BPI-R2 PRO Android11 Source Code
- Baidu Cloud:https://pan.baidu.com/s/1c2vw-df4hh55VB3gSsM6Uw?pwd=8888 (提取码: 8888)
- Google Drive:
- BPI-R2 Pro schematic diagram : https://drive.google.com/file/d/1aDOL8U6-4bxn7iB_MzCOgHoDhUu0wuQu/view?usp=sharing
- BPI-R2 Pro DXF file :https://drive.google.com/file/d/1N9AWJVHC4fZEko5_RIkc3pI0gK1I0XiV/view?usp=sharing
- RTL8367RB-VB-CG Switch chip datasheet:https://drive.google.com/file/d/1Rua-SRJLPoV0NLnvwJg-fopsD178KIts/view?usp=sharing
- BPI-R2 Pro CE,FCC,RoHS certificate : https://banana-pi.org/en/bpi-honor/
- Install google play on Bananapi BPI-R2 pro Android 11/12:https://www.youtube.com/watch?v=pMKBVcJhsx4
Release image
Note: the network disk include linux-4.19.xx and linux-5.10.66 kernel version, linux-5.10.66 kernel version can support DSA feature.
- All image for BPI-R2 Pro google : https://drive.google.com/drive/folders/1gHNGVL_uq8L4t987k-nzg6MKWDSmDcfC
- All image for BPI-R2 Pro : Baidu : https://pan.baidu.com/s/1u5bIp0fMJPre-j0bXGfDWA?pwd=i8q6 Pincode: i8q6
kernel linux-5.10.66 Release image, support DSA feature
Supported OS Note: OpenWRT, Debian10, Ubuntu 16.04. Ubuntu 20.04, Ubunutu 22.04, Ubunut OS support server version, desktop version, mate desktop version.
- kernel linux-5.10.66 image for BPI-R2 Pro : Baidu : https://pan.baidu.com/s/19B6AYrHfbIFgRytTpW8Mbg?pwd=6me6 Pincode: 6me6
AltLinux for Banana Pi BPI R2 pro
Armbian and LibreELEC for BPI-R2-pro
- All Android image can find here:
- Google Drive: https://drive.google.com/drive/folders/1Bs0lhnukZ4A_BmbY-QPiJsFguPXh6imh?usp=share_link
- Baidu Cloud: https://pan.baidu.com/s/19_nZls-1tzAsIB3_B-PWrg?pwd=6zw8 (pincode: 6zw8)
- 2023-03-17-Android11-atv-bpi-r2pro.img
- Google Drive:https://drive.google.com/drive/folders/1TZMsaeg99bC8WwxEb8zOMTOAA0TurQ_E?usp=share_link
- Baidu Cloud:https://pan.baidu.com/s/1_Hb0dB_4mHhTXiWP6TAzDA?pwd=bdxa (pincode: bdxa)
- 2023-03-17-Android11-bpi-r2pro.img
- Google Drive:https://drive.google.com/drive/folders/108SbohEB8OsWYaxvFeYhGDzxHaUJ1OcW?usp=share_link
- Baidu Cloud: https://pan.baidu.com/s/1FKdN2b3qA2Cc4syO15zbng?pwd=rnxd (pincode: rnxd)
- 2022-11-16 release, Android12-bpi-r2pro.img
- Google Drive: https://drive.google.com/file/d/1UZ-e6QJIB8ZU-rdGsCnDNaNR2pYHHvxA/view?usp=share_link
- Baidu Cloud: https://pan.baidu.com/s/1tQ5Fg47R0fpUajYpNIsJ3g?pwd=8888 (pincode: 8888)
- MD5:a7b5faf7818f1ab2d36253a5d3ca1d18
- Forum pthread:https://forum.banana-pi.org/t/bananapi-bpi-r2-pro-2022-11-16-android-12/14264
- 2022-06-10 release, Android 11 with kernel 4.19.219, tablet variant image
- Google Drive: https://drive.google.com/file/d/1qiLZKU8_2O0hHgP25F0CRxv9MnSJlXpv/view?usp=sharing
- Baidu Cloud:https://pan.baidu.com/s/1EUiGaXuPxAkR69g7EOnVaw?pwd=4n6c (pincode: 4n6c)
- MD5: ebd336bad0c27c66ae65a4d38103bced
- 2022-06-10 release, Android 11 with kernel 4.19.219, atv variant image
- Google Drive: https://drive.google.com/file/d/104K7W1PX4OFvUtqNGHOnx6RZO49BrTZp/view?usp=sharing
- Baidu Cloud: https://pan.baidu.com/s/1RbNf1dFqMxy1Dx_ysym82w?pwd=v4u8 (pincode: v4u8)
- MD5: 49506a8a3183ab189046b5e2e2833b87
