Banana Pi BPI-W3
Revision as of 23:08, 12 March 2023 by Sinovoip (talk | contribs) (Source code)
BPI-RK3588 Core board and development Kit Gold finger interface core board
BPI-RK3588 BPI-RK3588 Core board and development Kit Stamp hole Core board and development Kit
File:Banana Pi BPI-W3 Banner.jpg
  • Rockchip RK3588 quad ARM Cortex-A76 and quad Cortex-A55 consists of an eight-core CPU processor
  • ARM Mali-G610 MP4,
  • NPU for AI : 6Tops@INT8
  • 8G RAM and 32G eMMC flash onbord
  • 2.5Gbps Ethernet
  • support HDMI in and HDMI out
Getting Started with BPI-W3
SoC RockChip RK3588
CPU quad ARM Cortex-A76 and quad Cortex-A55 consists of an eight-core CPU processor
GPU ARM Mali-G610 MP4,support OpenGL ES 1.1/2.0/3.2,OpenCL 2.2,Vulkan 1.1 Embedded high-performance 2D acceleration hardware
NPU 6Tops@INT8 ,
Video decode Caffe/TensorFlow/TFLite/ONNX PyTorch/Keras/Darknet mainstream architecture model of a key transformation VPU support 8 k 60 FPS h. 265 / AVS2 Profile0 / VP9 video decoding
Video encode Supports 8K 30FPS H.265/H.264 video encoding
RAM 8GB LPDDR4
eMMC flash 32GB
HDMI 2 HDMI Out and 1 HDMI in
SATA 1 SATA hardisk interface
System Android 12.0 ,Linux support
Power current and voltage 12V/2A
operating temperature 0℃ ~ 80℃(Measurement can reach -20 degrees to 85 degrees)
size 148mm * 101mm
40 PIN GPIO
GPIO number Function8 Function7 Function6 Function5 Function4 Function3 Function2 Function1 Pin#
+3.3V 1
139 I2S1_SDO2_M0 I2C7_SDA_M3 UART8_CTSN_M0 PWM15_IR_M1 CAN1_TX_M1 GPIO4_B3 3
138 I2S1_SDO1_M0 I2C7_SCL_M3 UART8_RTSN_M0 PWM14_M1 CAN1_RX_M1 GPIO4_B2 5
115 SPI1_CS1_M1 I2C8_SDA_M4 UART7_CTSN_M1 PWM15_IR_M0 GPIO3_C3 7
GND 9
113 SPI1_CLK_M1 UART7_RX_M1 GPIO3_C1 11
111 SPI1_MOSI_M1 I2C3_SCL_M1 GPIO3_B7 13
112 SPI1_MISO_M1 I2C3_SDA_M1 UART7_TX_M1 GPIO3_C0 15
+3.3V 17
42 SPI0_MOSI_M2 UART4_RX_M2 GPIO1_B2 19
41 SPI0_MISO_M2 GPIO1_B1 21
43 SPI0_CLK_M2 UART4_TX_M2 GPIO1_B3 23
GND 25
150 SPI3_CLK_M0 I2C0_SDA_M1 PWM7_IR_M3 GPIO4_C6 27
63 UART1_CTSN_M1 PWM15_IR_M3 GPIO1_D7 29
47 SPDIF_TX_M0 UART1_RX_M1 PWM13_M2 GPIO1_B7 31
103 PWM8_M0 GPIO3_A7 33
110 I2S2_LRCK_M1 UART3_RX_M1 PWM13_M0 CAN1_TX_M0 GPIO3_B6 35
37
GND 39
Pin# Function1 Function2 Function3 Function4 Function5 Function6 Function7 Function8    GPIO number
2 +5.0V
4 +5.0V
6 GND
8 GPIO0_B5 UART2_TX_M0 I2C1_SCL_M0 I2S1_MCLK_M1 13
10 GPIO0_B6 UART2_RX_M0 I2C1_SDA_M0 I2S1_SCLK_M1 14
12 GPIO3_B5 CAN1_RX_M0 PWM12_M0 UART3_TX_M1 I2S2_SCLK_M1 109
14 GND
16 GPIO3_A4 100
18 GPIO4_C4 PWM5_M2 SPI3_MISO_M0 148
20 GND
22 SARADC_IN4
24 GPIO1_B4 UART7_RX_M2 SPI0_CS0_M2 44
26 GPIO1_B5 UART7_TX_M2 SPI0_CS1_M2 45
28 GPIO4_C5 PWM6_M2 I2C0_SCL_M1 SPI3_MOSI_M0 149
30 GND
32 GPIO3_C2 PWM14_M0 UART7_RTSN_M1 I2C8_SCL_M4 SPI1_CS0_M1 114
34 GND
36 GPIO3_B1 PWM2_M1 UART2_TX_M2 105
38 GPIO3_B2 PWM3_IR_M1 UART2_RX_M2 I2S2_SDI_M1 106
40 GPIO3_B3 UART2_RTSN I2S2_SDO_M1 107
linux-5.10.110 kernel BSP Source code on github :https://github.com/BPI-SINOVOIP/BPI-W3-BSP
