The Banana Pi BPI-W3 is a router based development board, it design with Rochchip RK3588 quad ARM Cortex-A76 and quad Cortex-A55 consists of an eight-core CPU processor. ,6Tops@INT8 NPU,8G memory,32G eMMC storage on board .which can run on a variety of open source operating systems including OpenWrt, Android, and linux. It has 1 Gigabit LAN ports, 1 Gigabit WAN., it also with 2 HDMI out and 1 HDMI in port.
File:Banana Pi BPI-W3 Banner.jpg
- ARM Mali-G610 MP4,
- NPU for AI : 6Tops@INT8
- 8G RAM and 32G eMMC flash onbord
- 2x 10/100/1000Mbps Ethernet
- support HDMI in and HDMI out
Getting Started with BPI-W3
SoC |
RockChip RK3588
CPU |
GPU |
ARM Mali-G610 MP4,support OpenGL ES 1.1/2.0/3.2,OpenCL 2.2,Vulkan 1.1 Embedded high-performance 2D acceleration hardware
NPU |
6Tops@INT8 ,
Video decode |
Caffe/TensorFlow/TFLite/ONNX PyTorch/Keras/Darknet mainstream architecture model of a key transformation VPU support 8 k 60 FPS h. 265 / AVS2 Profile0 / VP9 video decoding
Video encode |
Supports 8K 30FPS H.265/H.264 video encoding
RAM |
8GB LPDDR4
eMMC flash |
32GB
Onboard Network |
HDMI |
2 HDMI Out and 1 HDMI in
GPIO |
40 Pins Header, 28×GPIO, some of which can be used for specific functions including UART, I2C, SPI, PWM, I2S.
SATA |
1 SATA hardisk interface
System |
Android 12.0 ,Linux support
Power |
current and voltage 12V/2A
operating temperature |
0℃ ~ 80℃(Measurement can reach -20 degrees to 85 degrees)
size |
148mm * 101mm
GPIO number
Function8
Function7
Function6
Function5
Function4
Function3
Function2
Function1
Pin#
+3.3V
I2S1_SDO2_M0
I2C7_SDA_M3
UART8_CTSN_M0
PWM15_IR_M1
CAN1_TX_M1
GPIO4_B3
3
138
I2S1_SDO1_M0
I2C7_SCL_M3
UART8_RTSN_M0
PWM14_M1
CAN1_RX_M1
GPIO4_B2
5
115
SPI1_CS1_M1
I2C8_SDA_M4
UART7_CTSN_M1
PWM15_IR_M0
GPIO3_C3
7
GND
9
113
SPI1_CLK_M1
UART7_RX_M1
GPIO3_C1
11
111
SPI1_MOSI_M1
I2C3_SCL_M1
GPIO3_B7
13
112
SPI1_MISO_M1
I2C3_SDA_M1
UART7_TX_M1
GPIO3_C0
15
+3.3V
17
42
SPI0_MOSI_M2
UART4_RX_M2
GPIO1_B2
19
41
SPI0_MISO_M2
GPIO1_B1
21
43
SPI0_CLK_M2
UART4_TX_M2
GPIO1_B3
23
GND
25
150
SPI3_CLK_M0
I2C0_SDA_M1
PWM7_IR_M3
GPIO4_C6
27
63
UART1_CTSN_M1
PWM15_IR_M3
GPIO1_D7
29
47
SPDIF_TX_M0
UART1_RX_M1
PWM13_M2
GPIO1_B7
31
103
PWM8_M0
GPIO3_A7
33
110
I2S2_LRCK_M1
UART3_RX_M1
PWM13_M0
CAN1_TX_M0
GPIO3_B6
35
37
GND
39
Pin#
Function1
Function2
Function3
Function4
Function5
Function6
Function7
Function8
GPIO number
2
+5.0V
4
+5.0V
6
GND
8
GPIO0_B5
UART2_TX_M0
I2C1_SCL_M0
I2S1_MCLK_M1
13
10
GPIO0_B6
UART2_RX_M0
I2C1_SDA_M0
I2S1_SCLK_M1
14
12
GPIO3_B5
CAN1_RX_M0
PWM12_M0
UART3_TX_M1
I2S2_SCLK_M1
109
14
GND
16
GPIO3_A4
100
18
GPIO4_C4
PWM5_M2
SPI3_MISO_M0
148
20
GND
22
SARADC_IN4
24
GPIO1_B4
UART7_RX_M2
SPI0_CS0_M2
44
26
GPIO1_B5
UART7_TX_M2
SPI0_CS1_M2
45
28
GPIO4_C5
PWM6_M2
I2C0_SCL_M1
SPI3_MOSI_M0
149
30
GND
32
GPIO3_C2
PWM14_M0
UART7_RTSN_M1
I2C8_SCL_M4
SPI1_CS0_M1
114
34
GND
36
GPIO3_B1
PWM2_M1
UART2_TX_M2
105
38
GPIO3_B2
PWM3_IR_M1
UART2_RX_M2
I2S2_SDI_M1
106
40
GPIO3_B3
UART2_RTSN
I2S2_SDO_M1
107
