BPI:bit for Webduino
About webduino
Webduino working model
- 1 use WebComponents integration Breakout.
- 2 use WebSocket(Firmata) to interacting with the server.
- 3 Server use TCP/IP(Firmata) to control webduino terminal.
Webduino project VS Arduino and micro:bit project | |||
item compared | Webduino | Arduino | Micro:bit |
development language | HTML/JavaScript | C/C++ | Python/JavaScript |
development environment | WEB browser | Arduino IDE | JavaScript Blocks |
Simulator | Webduino Simulator | Third-party support | Microsoft MakeCode |
graphical programming | Wbduino blockly | Third-party Scratch | Blockly |
Cloud Server | webduino cloud | N/A | N/A |
attended mode | WiFi | USB | USB |
Update the program | web online update | USB burn | USB disk |
Webduino source code on github
More webduino function now is open source , and code update to github.
How to power the Bit:bit board
Board a total of three power supply, you can choose one
- 1,USB cable power supply, bit board design has a Micro USB interface, in daily life wire is relatively common, it is quite convenient to use.
- 2,Power is supplied through 2Pin battery socket, which can supply power to the board through lithium battery, battery pack, etc. The interface has anti-stay design, and there is no need to worry about the problem of inverting the power supply
- 3,Through the goldfinger power supply, the lower end of the board goldfinger contains a power interface, while both input and output functions, compatibility is very high.
Webduino firmware programming
How to burn webduino firmware
bpi:bit has been programmed Webduino firmware by default. Only when you reprogram the flash with other firmware, will you need to program Webduino firmware again.
How to : Webduino firmware programming
Webduino OTA Cloud upgrade
BPI:bit for webduino support OTA cloud upgrade , it is easy to use this function to update newest version.
power on bit ,Press the A button when flash white light, unpress A booton when when the green light is on, so start to update.
Initialization of Webduino Bit
Initialization of Webduino Bit:https://www.webduino.com.cn/site/en/docs/setting.html
if you can connect BPI:Bit to internet ,so you can use webduino blockly to use webduino all functions.
Webduino Blockly and simulator
Webduino online Blockly (english): https://bit.webduino.com.cn/blockly/?lang=en
Webduino online Blockly (chinese) https://bit.webduino.io/blockly/?lang=zh-hant
- Quick start BPI:bit with Webduino Blockly and simulator
Get to know Webduino Blockly Bit
Get to know Webduino Blockly Bit :https://www.webduino.com.cn/site/en/docs/blockly.html
Webduino Cloud
webduino refer to the tutorial
Online tutorials
- Webduino Bit Detail:https://www.webduino.com.cn/site/en/docs/detail.html
- Initialization of Webduino Bit:https://www.webduino.com.cn/site/en/docs/setting.html
- Get to know Webduino Blockly Bit :https://www.webduino.com.cn/site/en/docs/blockly.html
- 5x5 RGB LED matrix:https://www.webduino.com.cn/site/en/docs/rgbmatrix.html
- Buttons : https://www.webduino.com.cn/site/en/docs/button.html
- Light Detection :https://www.webduino.com.cn/site/en/docs/photocell.html
- Buzzer :https://www.webduino.com.cn/site/en/docs/buzzer.html
