Banana Pi BPI-M4 Zero
Revision as of 01:29, 12 November 2024 by Hf9929 (talk | contribs)
Banana Pi BPI-M4 Zero with Allwinner H618 chip
Banana Pi BPI-M4 Zero is the successor model of M2 Zero. It has a huge improvement in performance. The SOC is upgraded to H618 and the CPU frequency is increased by 25%. The memory is upgraded to DDR4, the capacity is quadrupled, and 8G eMMC is added. It supports 5G WiFi, and the USB interface has also been upgraded to type-C.
It has same form factor and 40-pin connector as the Raspberry Pi Zero W, and it can fit most of the RPI Zero W cases and accessories.
  • ARM Mali G31 GPU
  • 2.4G/5G WIFI & Bluetooth 4.2
  • 2G LPDDR4 RAM
  • 8G eMMC flash memory
  • 1x USB2.0 Type-C
  • 1x miniHDMI 2.0a
  • 1x 24-pin FPC connector
    • 1x USB2.0
    • 1x 100Mbps Ethernet
Hardware Specification of Banana pi BPI-M4 Zero
GPU ARM Mali G31 GPU
Memory 2 GB LPDDR4
Storage 8G eMMC flash
SD card MicroSD card slot, SDIO3.0
HDMI 1x miniHDMI 2.0a (up to 4K@60Hz with HDR10, CEC, DDC, SCDC), HDMI digital Audio output
USB 1x USB2.0 Type-C HOST, 1x USB2.0 Type-C OTG
40-pin header 28 pins GPIO and Power (+5V, +3.3V and GND)
24-pin FPC 0.5mm pitch FPC connector, 1x USB2.0, 1x IR, 1x 100Mbps Ethernet
9 pins GPIO, UART,TWI/I²C, PWM, PCM/I²S
Buttons Reset, FEL
Power 5V@3A via USB Type-C
Size 65mm × 30mm
Weight
PIN define
BPI-M4 Zero 40-pin header
24-pin FPC
24-pin FPC define and GPIO Alternative Functions Assignments
1 AP_RESET
2 GND
3 EPHY_RXN
4 EPHY_RXP
5 EPHY_TXN
6 EPHY_TXP
7 GND
8 PG14_1V8
9 PG13_1V8
10 PG12-1V8
11 PG11-1V8
12 GND
13 HP_R
14 HP_L
15 GND
16 TV_OUT
17 GND
18 USB1_DP
19 USB1_DM
20 5V
21 5V
22 USB2_DP
23 USB2_DM
24 GND
BPI-M4 Zero Debug UART
1 GND
2 UART0_RX
3 UART0_TX
  • BPI-M4 Zero DXF file
  • BPI-M4 ZERO Schematic diagram
Baidu cloud: https://pan.baidu.com/s/1kceiTekfFvYFsXrLiQrxQA?pwd=8888 (pincode: 8888)
Google drive: https://drive.google.com/file/d/1AtKZROqmdPSz2XQzdeQLL4K6wCPerqeu/view?usp=sharing
  • BPI-M4 Zero SBC bench test:
  • Allwinner H618 Datasheet
  • 2024-08-19-bananapi-m4zero-android12.zip
Baidu cloud: https://pan.baidu.com/s/1OUJEnathYgcPsmsX5CSj9w?pwd=8888 (pincode: 8888)
Google drive: https://drive.google.com/file/d/1twgJpV4kbHkK-OKiEwhMCIxbnkIw74dF/view?usp=sharing
  • 20240819-Bananapi-Armbian_24.8.0-trunk_Bpi-m4zero_Ubuntu22.04
Baidu cloud: https://pan.baidu.com/s/14d-s9O2cJco9fFsBUcUYoQ?pwd=8888 (pincode: 8888)
Google drive: https://drive.google.com/drive/folders/1-MzSVsduPX8qHKgbAOM3wmcCbwfkffAz?usp=sharing
  • 20240819-Bananapi-Armbian_24.8.0-trunk_Bpi-m4zero_Debian12
Baidu could: https://pan.baidu.com/s/1MFQE8zJVXeUKV9ZHeznWpA?pwd=8888 (pincode: 8888)
Google drive: https://drive.google.com/drive/folders/1Csk5mTyInOaWP6HsZbt_nk8V7dlG6Db0?usp=sharing
Old version system image
For the v00 version of M4 Zero, please use the image here.
  • 2024-01-14-bananapi-m4zero-android12-box.img.
Baidu Cloud: https://pan.baidu.com/s/1HRiOLLBwdrLehv_z2sksfA?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/drive/folders/15XDTLd5VqZxfgmv7tlqDBHrgOGvaBofU?usp=sharing
Baidu Cloud: https://pan.baidu.com/s/1rNXZc_OKJHyUVOPXtCixcQ?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/drive/folders/18ZvhcAMIOWyAZxHcxNGJmKVjZidYqGtW?usp=sharing
  • 20240314-Bpi-m4zero_1.0.1_debian12_bookworm_desktop_xfce_linux6.1.31
Baidu cloud: https://pan.baidu.com/s/1QJ0wFHxLMvaJgiCkk_NBpw?pwd=8888 (pincode:8888)
Google drive: https://drive.google.com/file/d/1OKrAm2fX8pLpiYM6GcQOIyNdcgQh9_bH/view?usp=sharing
  • 20240314-Bpi-m4zero_1.0.1_debian12_bookworm_minimal_linux6.1.31
Baidu cloud: https://pan.baidu.com/s/1oGq-HaHJoiUsUqIQwp72_Q?pwd=8888 (pincode:8888)
Google drive: https://drive.google.com/file/d/1dNkG1sbh2EkKD9UUmUhT9LtdbfF3rT_c/view?usp=sharing
  • 20240315_Bpi-m4zero_1.0.1_debian11_bullseye_desktop_xfce_linux6.1.31
Baidu Cloud: https://pan.baidu.com/s/1mkjxqcDDyDXDQ-ZJ_7Dcag?pwd=8888(pincode:8888)
Google Drive: https://drive.google.com/file/d/1RyIC-1AsVUk9i8aL6c37uDcB3VIBQJwk/view?usp=sharing
  • 20240315_Bpi-m4zero_1.0.1_debian11_bullseye_minimal_linux6.1.31
Baidu Cloud: https://pan.baidu.com/s/1x2ByNdQJHRxRxRIo5Ui1lA?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/file/d/19BjUfWAH8pQdVtxN1Ow6QERlSm5o5g5e/view?usp=sharing
  • 20240314-Bpi-m4zero_1.0.1_ubuntu24.04_jammy_desktop_xfce_linux6.1.31
Baidu Cloud: https://pan.baidu.com/s/1GigN7INJarQnqJL5pQNK4g?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/file/d/1AhQqo54W4QOS36ek9lxoMnewk0F5nIoX/view?usp=sharing
  • 20240314-Bpi-m4zero_1.0.1_ubuntu24.04_jammy_minimal_linux6.1.31
Baidu Cloud: https://pan.baidu.com/s/1nV6AJUayGSmLsUhIrMq9IQ?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/file/d/1CttN-hCD1PWImalYPh8QuxWsa2BPEyz-/view?usp=sharing
SINOVOIP Aliexpress shop: https://www.aliexpress.us/item/1005006325178305.html
Bipai Aliexpress shop: https://www.aliexpress.us/item/1005006325280213.html
Taobao Shop: https://item.taobao.com/item.htm?spm=a21dvs.23580594.0.0.4fee3d0dOP5VBH&ft=t&id=754939469582
