Banana Pi BPI-W3
- ARM Mali-G610 MP4,
- NPU for AI : 6Tops@INT8
- 8G RAM and 32G eMMC flash onboard
- 2.5Gbps Ethernet
LGA Core board
| SOC | RockChip RK3588 |
| CPU | Quad Core A76+ Quad Core A55 ,use 8nm , 2.4GHz |
| GPU | ARM Mali-G610 MP4 GPU,Support OpenGL ES3.2 / OpenCL 2.2 / Vulkan1.1, 450 GFLOPS |
| NPU | 6 TOPS,Support INT4/INT8/INT16 mixed operation,Support framework switching of TensorFlow/MXNet/PyTorch/Caffe |
| Encode&Decode | encode:8K@60fps H.265/VP9/AVS2、8K@30fps H.264 AVC/MVC、4K@60fps AV1、1080P@60fps MPEG-2/-1/VC-1/VP8 ,decode:8K@30fps H.265 / H.264 |
| Ram | 4GB/8GB/16GB(up to 32GB)64bit LPDDR4/LPDDR4x/LPDDR5,Defalut LPDDR4 8GB |
| Flash | 16GB/32GB/64GB/128GB/256GB eMMC,support MicroSD card slot,Defaut :32GB |
| M2 Key M | The interface supports extension SSD |
| network | 2.5G network port(RLT8125BS) |
| video output | 2 x HDMI2.1(just one support 8K@60fps or 4K@120fps,other support 4K@60fps),1 x MIPI-DSI(4K@60fps),1 x DP1.4(8K@30fps), |
| video input | 1 x 4Lanes MIPI CSI / 2 x 2lanes MIPI CSI,1 x HDMI RX2.0 |
| Voice | 2 x HDMI voice output ,1 x DP1.4 voice output,1 x headphone (es8316) |
| Wireless | M2 E key interface support sdio、pcie、usb BT&wifi(AP6256,Intel AX210) |
| USB | 2 x USB3.1,2 x USB2.0,1x USB-C(DP1.4(8K@30fps)/OTG/PD fast charging) |
| Others | Fan、RTC、LED、debug |
| Button | Power Button、Reset Button、 Recovery Button、Root Button |
| GPIO | 40 x GPIO(UART、SPI、I2C、I2S、PWM、ADC、 GPIO、 5V power 、3.3V power) |
| Power | DC 12V/2.5A bore diameter 2.5mm,support USB Type-C PD 2.0 ,9V/2A, 12V/2A, 15V/2A,Support 12V POE power supply |
| System | Android 12.0、Ubuntu、Debian11、Buildroot、Kylin Linux |
| Size | 148 mm × 100.5mm |
| operating temperature | -10℃ ~ 70℃ |
| storage temperature | -20℃ ~ 70℃ |
40 PIN GPIO
| GPIO number | Function8 | Function7 | Function6 | Function5 | Function4 | Function3 | Function2 | Function1 | Pin# |
| +3.3V | 1 | ||||||||
| 139 | I2S1_SDO2_M0 | I2C7_SDA_M3 | UART8_CTSN_M0 | PWM15_IR_M1 | CAN1_TX_M1 | GPIO4_B3 | 3 | ||
| 138 | I2S1_SDO1_M0 | I2C7_SCL_M3 | UART8_RTSN_M0 | PWM14_M1 | CAN1_RX_M1 | GPIO4_B2 | 5 | ||
| 115 | SPI1_CS1_M1 | I2C8_SDA_M4 | UART7_CTSN_M1 | PWM15_IR_M0 | GPIO3_C3 | 7 | |||
| GND | 9 | ||||||||
| 113 | SPI1_CLK_M1 | UART7_RX_M1 | GPIO3_C1 | 11 | |||||
| 111 | SPI1_MOSI_M1 | I2C3_SCL_M1 | GPIO3_B7 | 13 | |||||
| 112 | SPI1_MISO_M1 | I2C3_SDA_M1 | UART7_TX_M1 | GPIO3_C0 | 15 | ||||
| +3.3V | 17 | ||||||||
| 42 | SPI0_MOSI_M2 | UART4_RX_M2 | GPIO1_B2 | 19 | |||||
| 41 | SPI0_MISO_M2 | GPIO1_B1 | 21 | ||||||
| 43 | SPI0_CLK_M2 | UART4_TX_M2 | GPIO1_B3 | 23 | |||||
| GND | 25 | ||||||||
| 150 | SPI3_CLK_M0 | I2C0_SDA_M1 | PWM7_IR_M3 | GPIO4_C6 | 27 | ||||
| 63 | UART1_CTSN_M1 | PWM15_IR_M3 | GPIO1_D7 | 29 | |||||
| 47 | SPDIF_TX_M0 | UART1_RX_M1 | PWM13_M2 | GPIO1_B7 | 31 | ||||
| 103 | PWM8_M0 | GPIO3_A7 | 33 | ||||||
| 110 | I2S2_LRCK_M1 | UART3_RX_M1 | PWM13_M0 | CAN1_TX_M0 | GPIO3_B6 | 35 | |||
| 37 | |||||||||
| GND | 39 |
| Pin# | Function1 | Function2 | Function3 | Function4 | Function5 | Function6 | Function7 | Function8 | GPIO number |
| 2 | +5.0V | ||||||||
| 4 | +5.0V | ||||||||
| 6 | GND | ||||||||
| 8 | GPIO0_B5 | UART2_TX_M0 | I2C1_SCL_M0 | I2S1_MCLK_M1 | 13 | ||||
| 10 | GPIO0_B6 | UART2_RX_M0 | I2C1_SDA_M0 | I2S1_SCLK_M1 | 14 | ||||
| 12 | GPIO3_B5 | CAN1_RX_M0 | PWM12_M0 | UART3_TX_M1 | I2S2_SCLK_M1 | 109 | |||
| 14 | GND | ||||||||
| 16 | GPIO3_A4 | 100 | |||||||
| 18 | GPIO4_C4 | PWM5_M2 | SPI3_MISO_M0 | 148 | |||||
| 20 | GND | ||||||||
| 22 | SARADC_IN4 | ||||||||
| 24 | GPIO1_B4 | UART7_RX_M2 | SPI0_CS0_M2 | 44 | |||||
| 26 | GPIO1_B5 | UART7_TX_M2 | SPI0_CS1_M2 | 45 | |||||
| 28 | GPIO4_C5 | PWM6_M2 | I2C0_SCL_M1 | SPI3_MOSI_M0 | 149 | ||||
| 30 | GND | ||||||||
| 32 | GPIO3_C2 | PWM14_M0 | UART7_RTSN_M1 | I2C8_SCL_M4 | SPI1_CS0_M1 | 114 | |||
| 34 | GND | ||||||||
| 36 | GPIO3_B1 | PWM2_M1 | UART2_TX_M2 | 105 | |||||
| 38 | GPIO3_B2 | PWM3_IR_M1 | UART2_RX_M2 | I2S2_SDI_M1 | 106 | ||||
| 40 | GPIO3_B3 | UART2_RTSN | I2S2_SDO_M1 | 107 |
MIPI CSI
0.5mm FPC Connector
Pin# MIPI-CSI Description 1,4,7,10,13,16,19,21,24,25,26,27,32,33 GND Power Ground & Signal Ground 2 MIPI_CSI0_RX_D3N MIPI RX Lane3 iuput N 3 MIPI_CSI0_RX_D3P MIPI RX Lane3 iuput P 5 MIPI_CSI0_RX_D2N MIPI RX Lane2 iuput N 6 MIPI_CSI0_RX_D2P MIPI RX Lane2 iuput P 8 MIPI_CSI0_RX_CLK1N MIPI RX Clock iuput N 9 MIPI_CSI0_RX_CLK1P MIPI RX Clock iuput P 11 MIPI_CSI0_RX_D1N MIPI RX Lane1 iuput N 12 MIPI_CSI0_RX_D1P MIPI RX Lane1 iuput P 14 MIPI_CSI0_RX_D0N MIPI RX Lane0 iuput N 15 MIPI_CSI0_RX_D0P MIPI RX Lane0 iuput P 17 MIPI_CSI0_RX_CLK0N MIPI RX Clock iuput N 18 MIPI_CSI0_RX_CLK0P MIPI RX Clock iuput P 20 MIPI_CAM3_CLKOUT 1.8V, CLock ouput for Sensor 22 MIPI_CAM1_CLKOUT 1.8V, CLock ouput for Sensor 23 MIPI_CSI0_PDN0_H(GPIO1_B0) 1.8V, GPIO 24 I2C3_SCL_M0_MIPI 1.8V, I2C Clock, pulled up to 1.8V with 2.2K on w3 25 I2C3_SDA_M0_MIPI 1.8V, I2C Clock, pulled up to 1.8V with 2.2K on w3 26 MIPI_CSI0_PDN1_H(GPIO1_A7) 1.8V, GPIO 27 CM_RST_L(GPIO4_A0) 3.3V, GPIO 28,29 VCC_RX 3.3V Power ouput 30,31 VCC_5V0 5V Power ouput
MIPI DSI
0.5mm FPC Connector (J23)
Pin# MIPI-DSI Description 1,4,7,10,13,16,27,33,34 GND Power and Signal Ground 2 MIPI_DPHY1_TX_D0N MIPI1 TX Lane0 ouput N 3 MIPI_DPHY1_TX_D0P MIPI1 TX Lane0 ouput P 5 MIPI_DPHY1_TX_D1N MIPI1 TX Lane1 ouput N 6 MIPI_DPHY1_TX_D1P MIPI1 TX Lane1 ouput P 8 MIPI_DPHY1_TX_CLKN MIPI1 TX Clock ouput N 9 MIPI_DPHY1_TX_CLKP MIPI1 TX Clock ouput P 11 MIPI_DPHY1_TX_D2N MIPI1 TX Lane2 ouput N 12 MIPI_DPHY1_TX_D2P MIPI1 TX Lane2 ouput P 14 MIPI_DPHY1_TX_D3N MIPI1 TX Lane3 ouput N 15 MIPI_DPHY1_TX_D3P MIPI1 TX Lane3 ouput P 17 LCD_PWM (PWM2_M2/GPIO4_C2) 1.8V, GPIO/PWM 18,19 VCC3V3_LCD 3.3V Power ouput 20 LCD_RESET (GPIO2_C1) 1.8V, GPIO 21 /NC No Connection 22 LCD_BL_EN (GPIO3_A1) 3.3V, GPIO 23 I2C6_SCL_M0 1.8V, I2C Clock, pulled up to 1.8V with 2.2K on w3 24 I2C6_SDA_M0 1.8V, I2C Data, pulled up to 1.8V with 2.2K on w3 25 TP_INT (GPIO0_D3) 1.8V, GPIO 26 TP_RST (GPIO0_C6) 1.8V, GPIO 28,29 VCC5V0_LCD 5V Power ouput 31,32 VCC_1V8 1.8V Power ouput
Debug UART
3.3V level signals, 1500000bps
Pin# Assignment Description 1 UART2_RX_M0 intput 2 UART2_TX_M0 output 3 GND 0V
PoE In
1.25mm Connector
Pin# Assignment Description 1 VC1 TX1 2 VC2 RX1 3 VC3 TX2 4 VC4 RX2
PoE Out
2.0mm Connector
Pin# Assignment Description 1 VDD_POE 12V Power ouput 2 VDD_POE 12V Power ouput 3 GND Ground pin 4 GND Ground pin
Fan
1.25mm Connector
Pin# Assignment Description 1 VCC_5V0 5V Power ouput 2 VCC_5V0 5V Power ouput 3 PWM1_M0/GPIO0_C0 1.8V, PWM/GPIO
- linux-5.10.110 kernel BSP Source code on github :https://github.com/BPI-SINOVOIP/BPI-W3-BSP
- Armsom github source code :https://github.com/ArmSoM/armsom-w3-bsp
- Banana PI BPI-W3 SCH, DXF, SMD file:
- Baidu cloud : https://pan.baidu.com/s/1cxHc0nRnav2jH1BEpFjxLQ?pwd=arms Pincode: arms
- Google drive: https://drive.google.com/drive/folders/1tzVbrZYoj6G6ShwTfe1Cxv8wC4knKBOu?usp=drive_link
- Banana Pi BPI-W3 coare board 3588-LGA Core board all pin list file(5.core board (LGA) pin List)
- Banana Pi Core board design for RK3588 : BPI-RK3588 Core board and development Kit
- Rockchip RK3588 datasheet :https://drive.google.com/file/d/1KAq1_kKqPtkq8Vlq-h_yUPUZLrgqSKHI/view?usp=sharing
- Banana Pi BPI-W3 RK3588 NPU6T AI RKNN Toolkit2 and RKNPU2 demo :https://www.youtube.com/watch?v=AEU87YUZz8Y
- Android 12 image:
- Google driver: https://drive.google.com/drive/folders/1qgvHCI8F-z7SjEYoeDopy7aNfiP1mTMA
- Baidu Cloud: https://pan.baidu.com/s/1mGT7n8Mr3PM_y9LY4kVjUA?pwd=8888 (pincode:8888)
- All image for BPI-W3 :
- Google drive:https://drive.google.com/drive/folders/16xIyxd64NBbtJxPNbP-NyJUCj3fWsSJ-
- BPI-W3 android 12 image 2023.4.14 update:
- Google drive:https://drive.google.com/drive/folders/17JueSJx6xBgoXGixRkoIpuFMazS3LEou?usp=drive_link
- BPI-W3 armbian image 2023.4.14 update
- Google drive:https://drive.google.com/drive/folders/1toeRkmdbo2dnhSnEEtFLipefn5GsnA2q?usp=drive_link
- Baidu cloud: https://pan.baidu.com/s/1cxHc0nRnav2jH1BEpFjxLQ?pwd=arms Pincode: arms
- Google drive:https://drive.google.com/drive/folders/189hdj2vfzmJgar1XxVbPhUJGWPRtinUZ?usp=drive_link
BPI-W3 Tools
- Baidu cloud :https://pan.baidu.com/s/1ocWvRUz4IFCoZBjSx7MavQ?pwd=arms Pincode:arms
- Google drive: https://drive.google.com/drive/folders/1WJxMzmInB1xr3DpDQXYblU0iM9RbsmPF?usp=drive_link
- SINOVOIP Aliexpress shop: https://www.aliexpress.us/item/3256805306000586.html?gatewayAdapt=glo2usa4itemAdapt&_randl_shipto=US
- BPI Aliexpress shop : https://www.aliexpress.com/item/1005005492412383.html?spm=5261.ProductManageOnline.0.0.44927197rtt5Zg
- Taobao shop : https://item.taobao.com/item.htm?spm=a213gs.success.result.1.7a637a8674R4AD&id=714475598378
- OEM&ODM:[email protected]
