Banana Pi BPI-R2 Pro
Revision as of 01:25, 20 July 2023 by Sinovoip (talk | contribs) (Release image)
Rockchip RK3568 chip
BPI-R2 Pro case same as BPI-R2
  • Mali-G52 1-Core-2EE
  • 2G LPDDR4 SDRAM (option 4G)
  • support 1 SATA interface
  • 1 CSI camera interface
Rockchip RK3568
Getting Started with R2PRO
Banana Pi R2 Pro
Storage Onboard 16GB eMMC Flash, Micro SD-Card slot, SATA 3.0 Port,SPI flash
Camera 1 CSI camera interfact
Video decoder(s) H.265 HEVC/MVC Main10 Profile [email protected] up to 4096x2304@60fps,H.264 AVC/MVC Main10 Profile yuv400/yuv420/yuv422/@L5.1 up to 4096x2304@60fps
Video encoder(s) H.264/AVC BP/MP/[email protected],up to 1920x1080@100fps, H.265/HEVC [email protected], up to 1920x1080@100fps (4096x4096@10fps with TILE)
Remote IR Receiver (x1)
LED Power Status and 8P8C
Custom production
RK3568 custom board, industrial control board
Source Code
Baidu Cloud:https://pan.baidu.com/s/1c2vw-df4hh55VB3gSsM6Uw?pwd=8888 (提取码: 8888)
Google Drive:
Release image
Note: the network disk include linux-4.19.xx and linux-5.10.66 kernel version, linux-5.10.66 kernel version can support DSA feature.
kernel linux-5.10.66 Release image, support DSA feature
Supported OS Note: OpenWRT, Debian10, Ubuntu 16.04. Ubuntu 20.04, Ubunutu 22.04, Ubunut OS support server version, desktop version, mate desktop version.
AltLinux for Banana Pi BPI R2 pro
Armbian and LibreELEC for BPI-R2-pro
  • 2023-07 Armbian_2023.02.0 for BPI-R2 PRO
Baidu Cloud:
Google Drive:
How to flash Android Image
  • All Android image can find here:
Google Drive: https://drive.google.com/drive/folders/1Bs0lhnukZ4A_BmbY-QPiJsFguPXh6imh?usp=share_link
Baidu Cloud: https://pan.baidu.com/s/19_nZls-1tzAsIB3_B-PWrg?pwd=6zw8 (pincode: 6zw8)
  • 2023-03-17-Android11-atv-bpi-r2pro.img
Google Drive:https://drive.google.com/drive/folders/1TZMsaeg99bC8WwxEb8zOMTOAA0TurQ_E?usp=share_link
Baidu Cloud:https://pan.baidu.com/s/1_Hb0dB_4mHhTXiWP6TAzDA?pwd=bdxa (pincode: bdxa)
  • 2023-03-17-Android11-bpi-r2pro.img
Google Drive:https://drive.google.com/drive/folders/108SbohEB8OsWYaxvFeYhGDzxHaUJ1OcW?usp=share_link
Baidu Cloud: https://pan.baidu.com/s/1FKdN2b3qA2Cc4syO15zbng?pwd=rnxd (pincode: rnxd)
  • 2022-11-16 release, Android12-bpi-r2pro.img
Google Drive: https://drive.google.com/file/d/1UZ-e6QJIB8ZU-rdGsCnDNaNR2pYHHvxA/view?usp=share_link
Baidu Cloud: https://pan.baidu.com/s/1tQ5Fg47R0fpUajYpNIsJ3g?pwd=8888 (pincode: 8888)
MD5:a7b5faf7818f1ab2d36253a5d3ca1d18
Forum pthread:https://forum.banana-pi.org/t/bananapi-bpi-r2-pro-2022-11-16-android-12/14264
  • 2022-06-10 release, Android 11 with kernel 4.19.219, tablet variant image
Google Drive: https://drive.google.com/file/d/1qiLZKU8_2O0hHgP25F0CRxv9MnSJlXpv/view?usp=sharing
Baidu Cloud:https://pan.baidu.com/s/1EUiGaXuPxAkR69g7EOnVaw?pwd=4n6c (pincode: 4n6c)
MD5: ebd336bad0c27c66ae65a4d38103bced
  • 2022-06-10 release, Android 11 with kernel 4.19.219, atv variant image
Google Drive: https://drive.google.com/file/d/104K7W1PX4OFvUtqNGHOnx6RZO49BrTZp/view?usp=sharing
Baidu Cloud: https://pan.baidu.com/s/1RbNf1dFqMxy1Dx_ysym82w?pwd=v4u8 (pincode: v4u8)
MD5: 49506a8a3183ab189046b5e2e2833b87
