Getting Started BPI-UNO32 with Visuino
About BPI-UNO32
How to use BPI-UNO32 with Visuino
The BPI:UNO32 is fully supported in Visuino and can be selected as board by double clicking on the Arduino component in the design are, or by clicking on the button\
This will open a dialog listing all supported boards, and bpi:uno32 can be selected:
Once the board is selected the component in the design area will change to represent all the capabilities available on the BPI:UNO32:
Including the Hall Sensor, the Button, Buzzer, LED pins, and the Wi-Fi module:
No as example, by simply connecting the Output of the Hall sensor to the Input of the Serial port, the BPI:UNO32 can be programmed to send the Hall Sensor values to the Serial Terminal:
The Wi-Fi Module supports variety of operations, even including programming over the air (Wi-Fi).
Adding the operations is as simple as clicking on the “...”and button of the Operations property:
And selecting the Operations to add:
Once as example “Scan Networks” operation is added, it will appear on the BPI:UNO32 component and it can be connected, as example to print the SSIDs of the discovered hot-spots:
Adding sockets is equally simple:
And once the sockets are added, they can be connected to send the data from any sensor, or control any actuator:
All the Visuino components for sensors, displays, actuators, processing communication and more are available to be used with BPI:UNO32 as shown in this example displaying the Temperature and Humidity on OLED display, and controlling servo position based on the temperature:
All currently supported shields are also available and can be added to the BPI:UNO32 component:
And once added their functionality will appear on the component:
Once a project is designed, by simply clicking on the button, Visuino will generate the necessary C++ code, and will open the Arduino IDE:
In the Arduino IDE the generated code can be compiled and uploaded:
