BPI-EAI80 Compiling Steps
Revision as of 03:13, 13 October 2020 by Sinovoip (talk | contribs)
Compiling LCD source code
Step 1: Hardware connection
1. Connect a 7” LCD cable with a EAI80
2. Connect a battery cable with a EAI80
3. Connect a type C cable with a NB
Step 2: Modify LCD source code
1.Go to src under lcd folder
2.Copy main.c file to another folder before modifying its context
3.Modifying lcd source code – main.c (under lcd src folder) then saving
Step 3: Execute compiling
1.Turn on a terminal, path: github/BPI-EAI80-bsp/ugelis/ugelis_example/example/driver_example/lcd/build)
2.Command: make (execute comiling)
Burning ugelis.bin (after compiling) to EAI80 flash
Step 1:
Turn on a terminal, seek ugelis file under lcd, go to below path:
github/BPI-EAI80-bsp/ugelis_example/example/driver_example/lcd/build/ugeliss
Step 2:
Turn on 2nd terminal, go to below path: github/BPI-EAI80-bsp/ugelis/tools/gree_tool$
Step 3:
Copy ugelis.bin file under lcd/build/ugelis to gree_tools folder
Step 4:
Command: gree_tool$./gree_tool.ph (burning ugelis.bin file to EAI80 flash and lcd software burning done)
