BPI-EAI80 Compiling Steps
Revision as of 01:46, 13 October 2020 by Sinovoip (talk | contribs) (Created page with "=BPI-EAI80 Compiling Steps= ==Compiling LCD source code== Step 1: Hardware connection 1. Connect a 7” LCD cable with a EAI80 2. Connect a battery cable with a EAI80 3. Con...")
Step 1: Hardware connection 1. Connect a 7” LCD cable with a EAI80 2. Connect a battery cable with a EAI80 3. Connect a type C cable with a NB
Step 2: Modify LCD source code 1.Go to src under lcd folder 2.Copy main.c file to another folder before modifying its context
3.Modifying lcd source code – main.c (under lcd src folder) then saving
Step 3: Execute compiling 1.Turn on a terminal, path: github/BPI-EAI80-bsp/ugelis/ugelis_example/example/driver_example/lcd/build) 2.Command: make (execute comiling)
Step 4: Burning ugelis.bin (after compiling) to EAI80 flash: 1.Turn on 2nd terminal, path: github/BPI-EAI80-bsp/ugelis_example/example/driver_example/lcd/build/ugeliss 2. Turn on 3rd terminal, path: github/BPI-EAI80-bsp/ugelis/tools/gree_tool$
3. Copy ugelis.bin file under lcd/build/ugelis to gree_tools folder
4. Command: gree_tool$./gree_tool.ph (burning ugelis.bin file to EAI80 flash and lcd software burning done)
