Webduino firmware programming
Revision as of 22:56, 23 February 2019 by Sinovoip (talk | contribs) (ESP FLASH DOWNLOAD TOOL)
firmware Bin file
File and burn position corresponding
FileName Function
bit_default.bin BPI-BIT Webduino standard firmware
bit_stable.bin BPI-BIT stable version Webduino firmware
boot_app0.bin Espressif-WROOM-32 master core program
partitions.bin BPI-BIT Webduino firmware partition table file
bootloader_dio_40m.bin Espressif-WROOM-32 bootloader(It is applicable to the DIO burning mode with a speed of 40MHz)
Burning BPI:bit webduino firmware in Windows system
Tool download address:ESP Flash Download Tool
After downloading, unzip the archive and you will see an ESPFlashDownloadTool_v3.6.4.exe inside the folder. Open this shortcut and open an interface selection mode.
  • Double-click to open espflashdownloadtool_v3.6.4.exe and select ESP32 DownloadTool to start
Select ESP32 DownloadTool:
  • Check the four-line selection box, fill in the following four addresses 0x1000, 0x8000, 0xe000, 0x10000 in the box next to the column, and then select the corresponding file according to the following corresponding relations:
  • Verify the burn Settings, File and burn position corresponding to:
set file name Position
2 partitions.bin 0x8000
3 boot_app0.bin 0xe000
4 bit_default.bin 0x10000
- SpiFlashConfig:
SpiFlashConfig
1 CrystalFreq 40M
2 SPI SPEED 40MHz
3 SPI MODE DIO
4 FLASH SIZE 32Mbit
5 COM COMx(Fill in the port number assigned by the computer)
6 BAUD 1152000
Note : Where COMx is the serial number your system assigns to the board
During the burning process:
Finished:
Burn time is about 20s
Auto Flash工具
