Webduino firmware programming
firmware Bin file
File and burn position corresponding | |||
FileName | Function | ||
bit_default.bin | BPI-BIT Webduino standard firmware | ||
bit_stable.bin | BPI-BIT stable version Webduino firmware | ||
boot_app0.bin | Espressif-WROOM-32 master core program | ||
partitions.bin | BPI-BIT Webduino firmware partition table file | ||
bootloader_dio_40m.bin | Espressif-WROOM-32 bootloader(It is applicable to the DIO burning mode with a speed of 40MHz) |
Burning BPI:bit webduino firmware in Windows system
ESP FLASH DOWNLOAD TOOL
Flash programming procedures:
Select ESP32 DownloadTool:
set | file name | Position | |
1 | bootloader_dio_40m.bin | 0x1000 | |
2 | partitions.bin | 0x8000 | |
3 | boot_app0.bin | 0xe000 | |
4 | bit_default.bin | 0x10000 |
- SpiFlashConfig:
SpiFlashConfig | |||
1 | CrystalFreq | 40M | |
2 | SPI SPEED | 40MHz | |
3 | SPI MODE | DIO | |
4 | FLASH SIZE | 32Mbit | |
5 | COM | COMx(Fill in the port number assigned by the computer) | |
6 | BAUD | 1152000 |
During the burning process:
Finished:
Burn time is about 20s
