Webduino firmware programming
firmware Bin file
| FileName | Function | ||
| bit_default.bin | BPI-BIT Webduino standard firmware | ||
| bit_stable.bin | BPI-BIT stable version Webduino firmware | ||
| boot_app0.bin | Espressif-WROOM-32 master core program | ||
| partitions.bin | BPI-BIT Webduino firmware partition table file | ||
| bootloader_dio_40m.bin | Espressif-WROOM-32 bootloader(It is applicable to the DIO burning mode with a speed of 40MHz) | ||
Burning BPI:bit webduino firmware in Windows system
Firmware download address:for bpi:bit Firmware
Flash programming procedures:
Select ESP32 DownloadTool:
- SpiFlashConfig:
| SpiFlashConfig | |||
| 1 | CrystalFreq | 40M | |
| 2 | SPI SPEED | 40MHz | |
| 3 | SPI MODE | DIO | |
| 4 | FLASH SIZE | 32Mbit | |
| 5 | COM | COMx(Fill in the port number assigned by the computer) | |
| 6 | BAUD | 1152000 | |
During the burning process:
Finished:
Burn time is about 20s
