Webduino firmware programming
Revision as of 02:25, 4 July 2018 by Sinovoip (talk | contribs) (Created page with "A special Webduino version have been developed for bpi:bit. Of course, before using it, we need to program bpi:bit flash with the Webduino firmware. '''Note:''' bpi:bit has b...")
Flash programming procedures:
Select ESP32 DownloadTool:
set file name Position
2 partitions.bin 0x8000
3 boot_app0.bin 0xe000
4 bit_default.bin 0x10000
- SpiFlashConfig:
SpiFlashConfig
1 SPI SPEED 40MHz
2 SPI MODE DIO
3 FLASH SIZE 32Mbit
5 BAUD 1152000
During the burning process:
Finished:
Burn time is about 20s
