BPI-Bit
Revision as of 18:25, 3 July 2018 by Sinovoip (talk | contribs) (Webduino firmware programming)
Overview: BPI:bit
Overview: BPI:bit
  • Button switch : GPIO35 (A), GPIO27 (B)
  • Buzzer: GPIO25
  • MPU-9250 9-axis sensor: GPIO0, GPIO21, GPIO22, GPIO33
Description
Interface
Edge interface
PIN definitions
P3 ADC2_CH4 GPIO13
P0 ADC2_CH8 DAC_1 GPIO25
P4 ADC2_CH3 GPIO16
P5 ADC1_CH7 GPIO35
P6 ADC2_CH5 GPIO12
P7 ADC2_CH6 GPIO14
P1 ADC1_CH4 GPIO32
P8 GPIO16
P9 GPIO17
P10 ADC2_CH9 DAC_2 GPIO26
P11 ADC2_CH7 GPIO27
P12 ADC2_CH2 GPIO02
P2 ADC1_CH5 GPIO33
P13 GPIO18 SPI_SS
P14 GPIO19 SPI_SCK
P15 GPIO23 SPI_MISO
P16 GPIO05 SPI_MOSI
3V3 POWER:3V3
3V3 POWER:3V3
3V3 POWER:3V3
P19 GPIO22 I2C_SCL
P20 GPIO21 I2C_SDA
GND GROUND
GND GROUND
GND GROUND
5*5 LED list
25 5*5 LED list of BPI:bit
20 15 10 5 0
21 16 11 6 1
22 17 12 7 2
23 18 13 8 3
24 19 14 9 4
MPU9250 9-axis sensor
The 9-axis is the combination of 3 separate triple axis sensors. For more detailed information of this chip, click here MPU 9250 datasheet to view the datasheet.
BPI:bit power
BPI:bit VS micro:bit
bpi:bit VS micro:bit
Module bpi:bit micro:bit
RAM 520 KB 16 KB
ROM 448 KB Unkown
Flash 4096 KB 256 KB
WIFI 802.11 b/g/n/e/i N/A
Buzzer 1x Buzzer N/A
Size 5*5 cm 5*4 cm
BPI:bit planning programming:
Webduino
What is Webduino
Webduino working model:
  • 1 use WebComponents integration Breakout.
  • 2 use WebSocket(Firmata) to interacting with the server.
  • 3 Server use TCP/IP(Firmata) to control webduino terminal.
item compared Webduino Arduino Micro:bit
development language HTML/JavaScript C/C++ Python/JavaScript
development environment WEB browser Arduino IDE JavaScript Blocks
Simulator Webduino Simulator Third-party support Microsoft MakeCode
graphical programming Wbduino blockly Third-party Scratch Blockly
Cloud Server webduino cloud N/A N/A
attended mode WiFi USB USB
Update the program web online update USB burn USB disk
Webduino Blockly and simulator
  • Webduino Blockly and simulator
https://bit.webduino.com.cn/blockly/?lang=en
  • Quick start BPI:bit with Webduino Blockly and simulator
http://www.webduino.com.cn/site/en/tutorials.html
Webduino Cloud
https://cloud.webduino.io
Webduino OTA Cloud upgrade
BPI:bit for webduino support OTA cloud upgrade , it is easy to use this function to update newest version.
power on bit ,Press the A button when flash white light, unpress A booton when when the green light is on, so start to update.
Flash programming procedures:
Select ESP32 DownloadTool:
set file name Position
2 partitions.bin 0x8000
3 boot_app0.bin 0xe000
4 bit_default.bin 0x10000
- SpiFlashConfig:
SpiFlashConfig
1 SPI SPEED 40MHz
2 SPI MODE DIO
3 FLASH SIZE 32Mbit
5 BAUD 1152000
During the burning process:
Finished:
Burn time is about 20s
Online tutorials
Arduino
Arduino IDE
microPyhton
Scratch
Examples
MPU9250 sample code
Github
Useful links
webduino See sample
  • BPI:bit Through the photosensitive resistors built into Webduino Bit on the left and right sides, it is easy to determine which side the gesture comes from
  • Using Webduino Bit nine shaft sensor "attitude Angle" + full color dot matrix, simple implementation ~ ^_^ interesting effects
