Getting Started with R2PRO
Revision as of 09:25, 4 January 2024 by Squy (talk | contribs) (→Prepare)
Banana Pi BPI-R64 MTK MT7622
1. Double male USB data cable for image download or adb debug.
2. MicroUSB cable or usb to ttl cable (3.3v) if you need console debug message print, default baudrate is 1500000.
3. Windows or Linux PC.
4. Download the latest android image, and confirm that the md5 checksum is correct before flashing.
  • Default IP address for LAN port: 192.168.1.1
  • User name/password: pi/bananapi ,root/bananapi.
Windows
This tool defaults language is Chinese. you can change it to English after extract the package. Open RKDevTool_Release_v2.84/config.ini with an text editor (like notepad). The starting lines are:
 #Language Selection: Selected=1(Chinese); Selected=2(English)
 [Language]
 Kinds=2
 Selected=1
 LangPath=Language\
  • Uboot Usb Download Mode (loader mode)
It's supposed to use this way if board already flashed a bootable uboot before.
  • Maskrom Usb Download Mode(maskrom mode)
Press the Recovery button or Maskrom button beside 3pin uart header and hold, connect the power adapter or press the RST button if power adapter already connected, about two seconds later, release the button. PC will Identify the device if RK usb driver installed correctly.
The download tool also show the download mode if device connected.
 $ unzip Linux_Upgrade_Tool_xxxx.zip
 $ cd Linux_UpgradeTool_xxxx
 $ sudo mv upgrade_tool /usr/local/bin
 $ sudo chown root:root /usr/local/bin/upgrade_tool
 $ sudo chmod a+x /usr/local/bin/upgrade_tool
 # upgrade again
Install Image with SDcard
Boot Android from SDcard
Create a sdcard for android boot is almost the same as create a firmware upgrade sdcard, only one difference is select "SD Boot" mode instead of "Upgrade Firmware". This process lasts about 8 minutes, then safely remove the SDcard, insert it into the r2pro board and power on.
One thing to note is that make sure emmc is empty, you must erase it if flashed before. We recommend that use emmc for android boot because it is faster and more stable.
1. Get Android source code
 $ git clone https://github.com/BPI-SINOVOIP/BPI-Rockchip-Android11 --depth=1
2. Build the Android Source code
USB OTG Mode Switch
1. Tablet variant image
Settings->Connected devices->USB Connect to PC, switch on is peripheral mode and switch off is host mode.
2. Box variant image
Go to Settings->Device Preferences->About, tap "Build" seven times to enable "Developer options" preference. Then back to Settings->Device Preferences->Developer options.Switch on is peripheral mode and switch off is host mode.
Dual Display
Touch Panel
R2Pro hw design only have one group TP io, CN7, CN8, CN9 are all connect to it, so only one interface Touch Screen can be used at the same time. you can enable or disable it in dtb
 &i2c1 {
         status = "okay"
1. prepare two bmp format files, logo.bmp for uboot logo and logo_kernel.bmp for kernel logo.
2. there are two ways to replace the logo
1). create and replace the logo with adb tool
switch the otg port to enable adb, push the logo files to /sdcard/ directory.
 $ adb push logo_kernel.bmp /sdcard/
 $ adb push logo.bmp /sdcard/
 $ adb root
 $ adb shell
create logo.img
 bananapi_r2pro:/ # cd /sdcard/
 bananapi_r2pro:/sdcard # cat logo.bmp > logo.img && truncate -s %512 logo.img && cat logo_kernel.bmp >> logo.img
flash logo.img to logo partition
 bananapi_r2pro:/sdcard # dd if=logo.img  of=/dev/block/by-name/logo
 24301+1 records in
 24301+1 records out
 12442166 bytes (12 M) copied, 1.104449 s, 11 M/s
reboot android
 bananapi_r2pro:/sdcard # reboot
2). create the logo on Linux and replace it with RKDevTool
create logo.img on Linux
 $ cat logo.bmp > logo.img && truncate -s %512 logo.img && cat logo_kernel.bmp >> logo.img
open RKDevTool.exe, Switch to the “Download Image” page, change the items as following, press REC/LOADER and power on or reset the board to enter loader download mode, then click Run to flash logo.img to logo partition.
IR Custom
Wlan&BT
CN13 M.2 KEY E Slot is used for connect Wlan&BT adapter, the following WiFi Cards are tested and supported in default image
 RTL8822CE WIFI/BT (PCIE+USB)
 RTL8822BE WIFI/BT (PCIE+USB)
 RTL8852BE WIFI/BT (PCIE+USB)
 RTL8822CS WIFI/BT (SDIO+UART)
 AP6256 WIFI/BT (SDIO+UART)
Install Google Play with Magisk
1. Download Magisk app
2. Download MagiskGapps package
3. Download device id app
4. Copy download apps and package to SDcard and plugin it to Bananapi R2pro.
5. Follow the process in the video to Install Google Play store.
Another way, you can build the android source code with OpenGApps google play include.
1. Download the android source code
2. Apply this patch to enable build OpenGApps
 diff --git a/device/rockchip/rk356x/bananapi_r2pro/BoardConfig.mk b/device/rockchip/rk356x/bananapi_r2pro/BoardConfig.mk
 index 3f17d3c0cc..bd8d1b3213 100755
 --- a/device/rockchip/rk356x/bananapi_r2pro/BoardConfig.mk
 +++ b/device/rockchip/rk356x/bananapi_r2pro/BoardConfig.mk
 @@ -45,7 +45,7 @@ SF_PRIMARY_DISPLAY_ORIENTATION := 0
  TARGET_ROCKCHIP_PCBATEST := false
  BOARD_HAS_FACTORY_TEST := false
 -BOARD_HAVE_OPENGAPPS := false
 +BOARD_HAVE_OPENGAPPS := true
  # increase super partition size for system, system_ext, vendor, product and odm
  # must be a multiple of its block size(65536)
3. Create /vendor/opengapps folder
4. Download OpenGApps aosp_build project to /vendor/opengapps/build
5. Create /vendor/opengapps/sources folder, download OpenGApps projects to /vendor/opengapps/sources/
6. Build the source code and flash the output image.
7. Install device id app and register your device for google play certification, more info please refer to the video above.
1. Double male USB data cable for image download into EMMC
2. MicroUSB cable or usb to ttl(3.3v) cable if you need debug, default baudrate is 1500000.
4. Download the Linux Release Image Linux Release Image, and confirm that the md5 checksum is correct before flashing.
Windows Driver install
File:Driver install.PNG
 [Language]
 Kinds=2
 Selected=2
 LangPath=Language\
Build Linux BSP Source Code
1. Get Linux source code
2. Build the Linux BSP Source code
Dual Display
  Note: All linux Image suuport dual display HDMI and eDP together, eDP only support 1920x1080.
  Note: HDMI Display
  Note: eDP panel Display
Wlan&BT
CN13 M.2 KEY E Slot is used for connect Wlan&BT adapter, default image support RTL8822CE(PCIE+USB) and RTL8822CS(SDIO+UART).
