Banana Pi BPI-CM2
BPI-CM2 Introduction
![](/images/thumb/8/85/Banana_Pi_BPI-CM2_1.jpg/300x225x300px-Banana_Pi_BPI-CM2_1.jpg.pagespeed.ic.dxIlc-_AlQ.jpg)
Banana Pi BPI-CM2 with RK3568 design
![](/images/thumb/b/b1/Banana_Pi_BPI-CM5_1.jpg/300x225x300px-Banana_Pi_BPI-CM5_1.jpg.pagespeed.ic.kgaBoHgx-o.jpg)
Banana Pi BPI-CM5 with A311D2 design
![](/images/thumb/2/28/Banana_Pi_BPI-CM5_5.jpg/300x225x300px-Banana_Pi_BPI-CM5_5.jpg.pagespeed.ic.-g7n6udz46.jpg)
Banana Pi BPI-CM5 with BPI-CM4 base board
![](/images/thumb/3/31/Banana_Pi_BPI-CM4_1.jpg/300x300x300px-Banana_Pi_BPI-CM4_1.jpg.pagespeed.ic.vegDz3DSjR.jpg)
Banana Pi BPI-CM4 with A311D design
![](/images/thumb/1/12/BananaPi_BPI-CM4_base_board_1.jpg/300x300x300px-BananaPi_BPI-CM4_base_board_1.jpg.pagespeed.ic.6sGSfHusyK.jpg)
BPI-CM4 Computer module and development Kit with base board
![](/images/thumb/a/a7/Banana_Pi_BPI-CM4_2.jpg/300x225x300px-Banana_Pi_BPI-CM4_2.jpg.pagespeed.ic.OJ0Ny_1buV.jpg)
![](/images/thumb/d/df/Banana_Pi_BPI-CM4_9.jpg/300x200x300px-Banana_Pi_BPI-CM4_9.jpg.pagespeed.ic.s_P-lEX3jf.jpg)
![](/images/thumb/4/4f/Banana_Pi_BPI-M5_4.JPG/300x225x300px-Banana_Pi_BPI-M5_4.JPG.pagespeed.ic.5eDUNHGM8e.jpg)
![](/images/thumb/a/a9/BPI-M2_Pro_2.jpg/300x225x300px-BPI-M2_Pro_2.jpg.pagespeed.ic.QwYAEL6-Jj.jpg)
![](/images/thumb/6/6e/Banana_Pi_BPI-M2S_1.jpg/300x225x300px-Banana_Pi_BPI-M2S_1.jpg.pagespeed.ic.09oBHwAysc.jpg)
Banana Pi BPI-CM2 is a computer module with Rockchip RK3568 Quad-core ARM Cortex-A55 CPU, Mali-G52 1-Core-2EE GPU,2GB LPDDR4/LPDDR4x ,8 G eMMC flash (Max 128G),Designed with Board to Board connectors for enhanced stability same as Raspberry Pi CM4 , which means that it should work with carrier boards designed for the Raspberry Pi CM4.
Application direction
- . Maker DIY
- . Internet service gateway
- . robot control
- . Industrial control and industrial automation gateway
- . Nas device
- 1. Rockchip RK3568 Quad-core ARM Cortex-A55 CPU
- 2. Mali-G52 1-Core-2EE GPU
- 3. 2GB LPDDR4/LPDDR4x (Max 8G)
- 4. 8G eMMC flash (Max 128G)
- 14. support Android and Linux system.
- 15. Size: 55x40mm
BPI-CM2 Module Hardware interface
BPI-CM2 Module PIN Out define
BPI-CM5 moudule base board interface
Banana Pi BPI-CM5 SBC specifications
Same size as RPI CM4
Third part image
