BPI-CM4 Computer module and development Kit
BPI-CM4 Introduction
[[[BPI-CM4 Computer module and development Kit]] with base board
  • NPU for AI :Next generation, deep-neural-network applications, at 5.0 TOPS
  • 4GB LPDDR4 RAM
  • 16GB eMMC flash (Max 128G)
  • Minipcie
  • HDMI output
  • 26 PIN GPIO
  • Size: 55x40mm
Getting Started with CM4
BPI-CM4 Module PIN Out define
Banana pi BPI-CM4 PIN Out define VS Raspberry PI CM4
BPI-CM4 RPI CM4 PIN PIN RPI CM4 BPI-CM4
GND GND 1 2 GND GND
NAT0_MDI3p Ethernet_Pair3_P 3 4 Ethernet_Pair1_P NAT0_MDI1p
NAT0_MDI3n Ethernet_Pair3_N 5 6 Ethernet_Pair1_N NAT0_MDI1n
GND GND 7 8 GND GND
NAT0_MDI2n Ethernet_Pair2_N 9 10 Ethernet_Pair0_N NAT0_MDI0n
NAT0_MDI2p Ethernet_Pair2_P 11 12 Ethernet_Pair0_P NAT0_MDI0p
GND GND 13 14 GND GND
Ethernet_LED2/1G_Active Ethernet_nLED3_1G-Active 15 16 Ethernet_SYNC_IN LINUX_Debug_RX
Ethernet_LED1/Link Ethernet_nLED2_1G-Link 17 18 Ethernet_SYNC_OUT LINUX_Debug_TX
Ethernet_0_LED0/CFG_EXT Ethernet_nLED1_Y 19 20 EEPROM_nWP NC
SYS_LED2 Pi_nLED_Activity 21 22 GND GND
GND GND 23 24 I2S_MCLK/GPIO26 GPIOA_0
GPIOA_3 GPIO21/I2S_DO 25 26 I2S_LRCLK/GPIO19 GPIOA_2
GPIOA_4 GPIO20/I2S_DI 27 28 GPIO13 GPIOA_7
GPIOAO_11 GPIO16 29 30 GPIO6 GPIOAO_10
GPIOH_5 GPIO12 31 32 GND GND
GND GND 33 34 GPO5 GPIOH_4
GPIOA_15 ID_SC 35 36 ID_SD GPIOA_14
GPIOAO_5 GPIO7/SPI-CE1 37 38 SPI-CLK/GPIO11 GPIOX_11
GPIOX_10 GPIO8/SPI-CE0 39 40 SPI-MISO/GPIO9 GPIOX_9
GPIOA_11 GPIO25 41 42 GND GND
GND GND 43 44 SPI-MOSI/GPIO10 GPIOX_8
GPIOA_12 GPIO24/UART0-CTS 45 46 GPIO22 GPIOA_5
GPIOA_13 GPIO23/UART0-RTS 47 48 UART1-RXD/GPIO27 GPIOA_6
GPIOA_1 GPIO18/I2S_SCLK 49 50 UART1-TXD/GPIO17 GPIOA_9
GPIOX_7 GPIO15/UART0-RXD 51 52 GND GND
GND GND 53 54 PWM/GPIO4 GPIOA_10
GPIOX_6 GPIO14/UART0-TXD 55 56 SCL/GPIO3 GPIOX_18
SD_CLK_B SD_CLK 57 58 SDA/GPIO2 GPIOX_17
GND GND 59 60 GND GND
SD_D3_B SD_DAT3 61 62 SD_CMD SD_CMD_B
SD_D0_B SD_DAT0 63 64 SD_DAT5 NC
GND GND 65 66 GND GND
SD_D1_B SD_DAT1 67 68 SD_DAT4 NC
SD_D2_B SD_DAT2 69 70 SD_DAT7 NC
GND GND 71 72 SD_DAT6 NC
NC SD_VDD_Override 73 74 GND GND
TF_VDD_EN SD_PWR_ON 75 76 Reserved/SD_DET CARD_DET
+5V_Input +5V_Input 77 78 GPIO_VREF NC
+5V_Input +5V_Input 79 80 SCL0_Camera_3V3 GPIOH_7
+5V_Input +5V_Input 81 82 SDA0_Camera_3V3 GPIOH_6
+5V_Input +5V_Input 83 84 CM4_3V3_OUTPUT CM4_3V3_OUTPUT
+5V_Input +5V_Input 85 86 CM4_3V3_OUTPUT CM4_3V3_OUTPUT
+5V_Input +5V_Input 87 88 CM4_1V8_OUTPUT CM4_1V8_OUTPUT
NC WL_nDisable_3V3 89 90 CM4_1V8_OUTPUT CM4_1V8_OUTPUT
NC BT_nDisable_3V3 91 92 RUN_PG/Reset_3V3 CPU_RST
NC nRPIBOOT_3V3 93 94 AnalogIP1/USBC_CC2 SARADC_CH3
SYS_LED PI_LED_nPWR 95 96 AnalogIP0/USBC_CC1 ADC_KEY
NC Camera_PWD_GPIO 97 98 GND GND
NC GLOBAL_EN_5V 99 100 nEXTRST GPIOH_8
USBOTG_B_ID USB_OTG_ID_3V3 101 102 PCIe_CLK_nREQ_3V3 PCIECK_REQN
USBOTG_B_DM USB_N 103 104 Reserved USB_A_DP
USBOTG_B_DP USB_P 105 106 Reserved USB_A_DM
GND GND 107 108 GND GND
PERST0_N PCIe_nRST_3V3 109 110 PCIe_CLK_P PCIE_CLKP
NC VDAC_COMP_TV 111 112 PCIe_CLK_N PCIE_CLKN
GND GND 113 114 GND GND
MIPI_CSI_D0N CAM1_D0_N 115 116 PCIe_RX_P PCIE_SOC_RXP
MIPI_CSI_D0P CAM1_D0_P 117 118 PCIe_RX_N PCIE_SOC_RXN
GND GND 119 120 GND GND
MIPI_CSI_D1N CAM1_D1_N 121 122 PCIe_TX_P PCIE_TX0_P
MIPI_CSI_D1P CAM1_D1_P 123 124 PCIe_TX_N PCIE_TX0_N
GND GND 125 126 GND GND
MIPI_CSI_CLKAN CAM1_C_N 127 128 CAM0_D0_N NC
MIPI_CSI_CLKAP CAM1_C_P 129 130 CAM0_D0_P NC
GND GND 131 132 GND GND
MIPI_CSI_D2N CAM1_D2_N 133 134 CAM0_D1_N NC
MIPI_CSI_D2P CAM1_D2_P 135 136 CAM0_D1_P NC
GND GND 137 138 GND GND
MIPI_CSI_D3N CAM1_D3_N 139 140 CAM0_C_N MIPI_CSI_CLKBN
MIPI_CSI_D3P CAM1_D3_P 141 142 CAM0_C_P MIPI_CSI_CLKBP
NC HDMI1_HOTPLUG_5V 143 144 GND GND
NC HDMI1_SDA_5V 145 146 HDMI1_TX2_P NC
NC HDMI1_SCL_5V 147 148 HDMI1_TX2_N NC
NC HDMI1_CEC_5V 149 150 GND GND
HDMI_TXCEC HDMI0_CEC_5V 151 152 HDMI1_TX1_P NC
HDMI_HPDC HDMI0_HOTPLUG_5V 153 154 HDMI1_TX1_N NC
GND GND 155 156 GND GND
NC DSI0_D0_N 157 158 HDMI1_TX0_P NC
NC DSI0_D0_P 159 160 HDMI1_TX0_N NC
GND GND 161 162 GND GND
NC DSI0_D1_N 163 164 HDMI1_CLK_P NC
NC DSI0_D1_P 165 166 HDMI1_CLK_N NC
GND GND 167 168 GND GND
NC DSI0_C_N 169 170 HDMI0_TX2_P HDMI_TX2P
NC DSI0_C_P 171 172 HDMI0_TX2_N HDMI_TX2N
GND GND 173 174 GNF GND
MIPI_D0_N DSI1_D0_N 175 176 HDMI0_TX1_P HDMI_TX1P
MIPI_D0_P DSI1_D0_P 177 178 HDMI0_TX1_N HDMI_TX1N
GND GND 179 180 GND GND
MIPI_D1_N DSI1_D1_N 181 182 HDMI0_TX0_P HDMI_TX0P
MIPI_D1_P DSI1_D1_P 183 184 HDMI0_TX0_N HDMI_TX0N
GND GND 185 186 GND GND
MIPI_CLK_N DSI1_C_N 187 188 HDMI0_CLK_P HDMI_TXCP
MIPI_CLK_P DSI1_C_P 189 190 HDMI0_CLK_N HDMI_TXCN
GND GND 191 192 GND GND
MIPI_D2_N DSI1_D2_N 193 194 DSI1_D3_N MIPI_D3_N
MIPI_D2_P DSI1_D2_P 195 196 DSI1_D3_P MIPI_D3_P
GND GND 197 198 GND GND
HDMI_SDA HDMI0_SDA_5V 199 200 HDMI0_SCL_5V HDMI_SCL
  • System Memory – 4GB LPDDR4
  • Video interfaces
HDMI 2.1 output up to 4Kp60
MIPI CSI connector for camera
  • Networking – 1x Gigabit Ethernet ports one via RTL8211F GbE transceiver
  • USB – 2x USB 2.0 Type-A port, 1x USB Type-C port
  • Expansion – 26-pin GPIO header
  • Misc – 2x buttons.
Same size as RPI CM4
Baidu Cloud: https://pan.baidu.com/s/1rANGEB-1MLPCBXqOR5aYCg?pwd=8888 (pincode: 8888)
Google Drive: https://drive.google.com/drive/folders/1INIABp_MbB5UcwfqujTngGLOZN7YGuWp?usp=share_link
How to flash Android Image
  • 2023-01-12-bpi-m2s-cm4-android9.img
Baidu Cloud: https://pan.baidu.com/s/1YVl0T9rSNqM3D0I1BRUr7A?pwd=8888 (pincode): 8888
Google Drive:https://drive.google.com/drive/folders/1u8flA6zsMOLnr75U4rvbph02z8YUKe2Y?usp=share_link
How to flash Linux Image
  • 2023-01-12-ubuntu-20.04-mate-desktop-bpi-cm4-aarch64-sd-emmc.img
Baidu Cloud: https://pan.baidu.com/s/1rh55yoEjPWsHXIcna7xEhQ?pwd=8888 (pincode: 8888)
Google Drive:https://drive.google.com/drive/folders/1xd2HA4Vv_U69iREiAUkOftZmmVbjw7yF?usp=share_link
  • 2023-01-12-ubuntu-20.04-server-bpi-cm4-aarch64-sd-emmc.img
Baidu Cloud: https://pan.baidu.com/s/17gu0ToxWmFi2i8VwuiqVDQ?pwd=8888 (pincode:8888)
Google Drive:https://drive.google.com/drive/folders/1i7okuijL3Jd99vf8PYuK7uH8D2t_WJZg?usp=share_link
  • 2023-01-12-debian-10-buster-bpi-cm4-aarch64-sd-emmc.img
Baidu Cloud: https://pan.baidu.com/s/19aQB16fdo2Si-is76R9LOQ?pwd=8888 (pincode: 8888)
Google Drive:https://drive.google.com/drive/folders/1_k0RYmuZoBBk4GCaDDOD112FDORcV5g2?usp=share_link
Third part image
Armbian unstable current build for Bananapi CM4
Armbian image release on 2023-01-12
  • Armbian_23.02.0-trunk_Bananapicm4_bullseye_current_6.0.14.img
Baidu Cloud: https://pan.baidu.com/s/1c4TuvJIB89tXuKEYYIqAfA?pwd=8888 (pincode:8888)
Google Drive:https://drive.google.com/drive/folders/1SbBUT9abRHcQmqlVGiexOZAHl0hXKO91?usp=share_link
  • Armbian_23.02.0-trunk_Bananapicm4_bullseye_current_6.0.14_minimal.img
Baidu Cloud:https://pan.baidu.com/s/1ZLzHljFLbUU6NUeI8nfCRQ?pwd=8888 (pincode: 8888)
Google Drive:https://drive.google.com/drive/folders/1SiWoz8o8Ed3Q1jQfSC8WsDjf1J6YLdMo?usp=share_link
  • Armbian_23.02.0-trunk_Bananapicm4_jammy_current_6.0.14_minimal.img
Baidu Cloud:https://pan.baidu.com/s/1E-DfPO0bIVlkehgn1buu0g?pwd=8888 (pincode: 8888)
Google Drive:https://drive.google.com/drive/folders/1b5eF2vdXXLCg2P_HVAuQD2xM-NWnhu7Z?usp=share_link
  • Armbian_23.02.0-trunk_Bananapicm4_jammy_current_6.0.14_cinnamon_desktop.img
Baidu Cloud:https://pan.baidu.com/s/16ImDYZraNWPSmrUGbvZY2Q?pwd=8888 (pincode: 8888)
Google Drive:https://drive.google.com/drive/folders/1EpwNek2rO8qSb_yUEU6NSdzf-LXvJgws?usp=share_link
  • Armbian_23.02.0-trunk_Bananapicm4_jammy_current_6.0.14_gnome_desktop.img
Baidu Cloud:https://pan.baidu.com/s/17cTi__f0hmR2WbAjk2th-g?pwd=8888 (pincode:8888)
Google Drive:https://drive.google.com/drive/folders/1RpJwj98ap4uJwD14tN45GuJbJOSea5d5?usp=share_link
  • Armbian_23.02.0-trunk_Bananapicm4_bullseye_current_6.0.14_xfce_desktop.img
Baidu Cloud:https://pan.baidu.com/s/1slqc3OSi8-WnEG6OhfAwhg?pwd=8888 (pincode:8888)
Google Drive:https://drive.google.com/drive/folders/1HhdXYjsPfJjgF_rEttxvAAQoq79itDan?usp=share_link
  • Armbian_23.02.0-trunk_Bananapicm4_jammy_current_6.0.14.img
Baidu Cloud:https://pan.baidu.com/s/1ivnnQFyMLauq5xH8KQBO7A?pwd=8888 (pincode:8888)
Google Drive:https://drive.google.com/drive/folders/1YBNbKY_4uhd0hW0ISb2Q9127z1W7-fLU?usp=share_link
