Banana Pi BPI-M2S
BPI-M2S Introduction
BananaPi BPI-M2S new design with Amlogic A311D, Quad core ARM Cortex-A73 and dual core ARM Cortex-A53 CPU ,ARM G52 MP4(6EE) GPU,NPU for AI at 5.0 TOPS, support Camera and MIPI-CSI interface ,HDMI output,2 Gigabit port, 4G RAM and 16 GB eMMC flash.
Amlogic S922X variant M2S board is 2G ram, 16G eMMC, not support npu, mipi panel and mipi camera.
- 4GB LPDDR4 RAM
- 16GB eMMC flash (Max 128G)
- 2 Gigabit port
- HDMI output
- 40 PIN GPIO
BPI-M2S(Amlogic A311D)Hardware interface
File:Banana Pi BPI-M2S interface.jpg
BPI-M2S(Amlogic S922X) Hardware interface
- System Memory – 4GB LPDDR4
- Video interfaces
- HDMI 2.1 output up to 4Kp60
- Misc – 3x buttons
- Dimensions – 65 x 65mm
PoE Wifi&BT
BPI-M2S 40PIN GPIO (CON2)
GPIO Pin Name | Default :GPIO | Function2 | Function3 |
CON2-P01 | VCC-3V3 | ||
CON2-P02 | DCIN | ||
CON2-P03 | GPIOX_17 | I2C_EE_M2_SDA | BT_EN |
CON2-P04 | DCIN | ||
CON2-P05 | GPIOX_18 | I2C_EE_M2_SCL | BT_WAKE_HOST |
CON2-P06 | GND | ||
CON2-P07 | GPIOX_5 | PWM_C | WIFI_SD_CMD |
CON2-P08 | GPIOX_12 | UART_EE_A_TX | |
CON2-P09 | GND | ||
CON2-P10 | GPIOX_13 | UART_EE_A_RX | |
CON2-P11 | GPIOX_3 | WIFI_SD_D3 | |
CON2-P12 | GPIOA_1 | I2SB_SCLK | |
CON2-P13 | GPIOX_4 | WIFI_SD_CLK | |
CON2-P14 | GND | ||
CON2-P15 | GPIOX_7 | WIFI_WAKE_HOST | |
CON2-P16 | GPIOX_0 | WIFI_SD_D0 | |
CON2-P17 | VCC-3V3 | ||
CON2-P18 | GPIOX_1 | WIFI_SD_D1 | |
CON2-P19 | GPIOX_8 | SPI_A_MOSI | BTPCM_DIN |
CON2-P20 | GND | ||
CON2-P21 | GPIOX_9 | SPI_A_MISO | BTPCM_DOUT |
CON2-P22 | GPIOX_2 | WIFI_SD_D2 | |
CON2-P23 | GPIOX_11 | SPI_A_CLK | BTPCM_CLK |
CON2-P24 | GPIOX_10 | SPI_A_CS | BTPCM_SYNC |
CON2-P25 | GND | ||
CON2-P26 | GPIOX_16 | BT_32K | |
CON2-P27 | GPIOH_5 | ||
CON2-P28 | GPIOH_4 | ||
CON2-P29 | GPIOX_14 | BTUART_A_CTS_N | |
CON2-P30 | GND | ||
CON2-P31 | GPIOX_15 | BTUART_A_RTS_N | |
CON2-P32 | GPIOX_19 | HOST_WAKE_BT | |
CON2-P33 | GPIOX_6 | WIFI_PWREN | |
CON2-P34 | GND | ||
CON2-P35 | GPIOA_2 | I2SB_LRCLK | |
CON2-P36 | GPIOAO_5 | IR_IN | |
CON2-P37 | GPIOA_0 | I2S_MCLK_0 | |
CON2-P38 | GPIOA_4 | I2SB_DOUT_DIN_1 | |
CON2-P39 | GND | ||
CON2-P40 | GPIOA_3 | I2SB_DOUT_DIN_0 |
BPI-M2S Debug UART(CON1)
CON2-P1 | GND |
CON2-P2 | UART0-RX |
CON2-P3 | UART0-TX |
BPI-M2S Camera(CN10)
CSI Pin Name | Default Function | Function2:GPIO |
CN10-P01 | GND | |
CN10-P02 | MIPI_CSI_D3N | |
CN10-P03 | MIPI_CSI_D3P | |
CN10-P04 | GND | |
CN10-P05 | MIPI_CSI_D2N | |
CN10-P06 | MIPI_CSI_D2P | |
CN10-P07 | GND | |
CN10-P08 | MIPI_CSI_CLKBN | |
CN10-P09 | MIPI_CSI_CLKBP | |
CN10-P10 | GND | |
CN10-P11 | MIPI_CSI_D1N | |
CN10-P12 | MIPI_CSI_D1P | |
CN10-P13 | GND | |
CN10-P14 | MIPI_CSI_D0N | |
CN10-P15 | MIPI_CSI_D0P | |
CN10-P16 | GND | |
CN10-P17 | MIPI_CSI_CLKAN | |
CN10-P18 | MIPI_CSI_CLKAP | |
CN10-P19 | NC | |
CN10-P20 | CAM0_MCLK | |
CN10-P21 | CAM0_IRCUT | |
CN10-P22 | CAM0_SCL | |
CN10-P23 | CAM0_SDA | |
CN10-P24 | CAM0_RESET | |
CN10-P25 | VCC1V8_DOVDD | |
CN10-P26 | GND | |
CN10-P27 | GND | |
CN10-P28 | VCC33 | |
CN10-P29 | VCC33 | |
CN10-P30 | VCC33 |
BPI-M2S LCD(CN9)
DSI Pin Name | Default Function | Function2:GPIO |
CN9-P01 | MIPI_D0_N | |
CN9-P02 | MIPI_D0_P | |
CN9-P03 | MIPI_D1_N | |
CN9-P04 | MIPI_D1_P | |
CN9-P05 | MIPI_CLK_N | |
CN9-P06 | MIPI_CLK_P | |
CN9-P07 | MIPI_D2_N | |
CN9-P08 | MIPI_D2_P | |
CN9-P09 | MIPI_D3_N | |
CN9-P10 | MIPI_D3_P | |
CN9-P11 | TP_INT_3V3 | |
CN9-P12 | TP_RST_3V3 | |
CN9-P13 | I2C_M3_SCL_3V3 | |
CN9-P14 | I2C_M3_SDA_3V3 | |
CN9-P15 | LCD_BL_EN_3V3 | |
CN9-P16 | LCD_PWM_3V3 | |
CN9-P17 | GND | |
CN9-P18 | GND | |
CN9-P19 | VLCD_5V | |
CN9-P20 | VLCD_5V |
- Android 9: https://github.com/BPI-SINOVOIP/BPI-A311D-Android9
- BPI-M2S/CM4 Android9 Source Code
- Baidu Cloud: https://pan.baidu.com/s/1rANGEB-1MLPCBXqOR5aYCg?pwd=8888 (pincode: 8888)
- Google Drive: https://drive.google.com/drive/folders/1INIABp_MbB5UcwfqujTngGLOZN7YGuWp?usp=share_link
- BPI-M2S Schematic Diagram:
- Baidu Cloud: https://pan.baidu.com/s/1eKLdicH0v_XBkUyX9aVRhw?pwd=ikme (pincode: ikme)
- Google Drive:https://drive.google.com/file/d/1kZjWV91WUNK7rNJQw5HNUNMf5Lob2qsi/view?usp=share_link
- 2023-01-12-bpi-m2s-cm4-android9.img
- Baidu Cloud: https://pan.baidu.com/s/1YVl0T9rSNqM3D0I1BRUr7A?pwd=8888 (pincode): 8888
- Google Drive:https://drive.google.com/drive/folders/1u8flA6zsMOLnr75U4rvbph02z8YUKe2Y?usp=share_link
Third part image
- Armbian unstable current build for Bananapi M2S
Armbian Image release on 2023-01-06
- Armbian_23.02.0-trunk_Bananapim2s_bullseye_current_6.0.14_minimal.img.xz
- Baidu Cloud:https://pan.baidu.com/s/1iEO_GcFa6Gy-cC0pnT4H3A?pwd=8888 (pincode: 8888)
- Google Drive:https://drive.google.com/drive/folders/1TDXuFliLZr4BY7NO5m_ijL4FxjsZNY8a?usp=share_link
- Discuss on the forum:https://forum.banana-pi.org/t/banana-pi-bpi-m2s-new-image-release-armbian-bullseye-current-minimal/14635
- Armbian_23.02.0-trunk_Bananapim2s_jammy_current_6.0.14_cinnamon_desktop.img.xz
- Baidu Cloud:https://pan.baidu.com/s/1aqvVJXy1MqSVUHL-DD5Rpw?pwd=8888 (pincode: 8888)
- Googel Drive:https://drive.google.com/drive/folders/1MPxwSg38uu0hVllUgqqmxKGsEMpfm-lM?usp=share_link
- Discuss on the forum:https://forum.banana-pi.org/t/banana-pi-bpi-m2s-new-image-release-armbian-jammy-current-cinnamon-desktop/14642
- Armbian_23.02.0-trunk_Bananapim2s_bullseye_current_6.0.14.img.xz
- Baidu Cloud:https://pan.baidu.com/s/1j0GVw3-ULFnWUFhwxr7muQ?pwd=8888 (pincode: 8888)
- Google Drive:https://drive.google.com/drive/folders/1Psku14DtTONHJD-73G58sD7CEoWfk4tT?usp=share_link
- Discuss on the forum:https://forum.banana-pi.org/t/banana-pi-bpi-m2s-new-image-release-armbian-bullseye-current/14634
- Armbian_23.02.0-trunk_Bananapim2s_jammy_current_6.0.14_minimal.img.xz
- Baidu Cloud:https://pan.baidu.com/s/1MevqHbBTX8S-fsXuy9SahA?pwd=8888 (pincode: 8888)
- Discuss on the forum:https://forum.banana-pi.org/t/banana-pi-bpi-m2s-new-image-release-armbian-jammy-current-minimal/14639
- Armbian_23.02.0-trunk_Bananapim2s_bullseye_current_6.0.14_xfce_desktop.img.xz
- Armbian_23.02.0-trunk_Bananapim2s_jammy_current_6.0.14_gnome_desktop.img.xz
- Baidu Cloud:https://pan.baidu.com/s/107kO-hGlyWMJFD9vpvKA-g?pwd=8888 (pincode: 8888)
- Google Drive:https://drive.google.com/drive/folders/19mLva4UQgON8exl5xuF2T9HD-Wy2eH94?usp=share_link
- Discuss on the forum:https://forum.banana-pi.org/t/banana-pi-bpi-m2s-new-image-release-jammy-current-gnome-desktop/14640
- 2023-01-6 Armbian_23.02.0-trunk_Bananapim2s_jammy_current_6.0.14.img.xz
