Banana Pi BPI-CM5
BPI-CM5 Introduction
![](/images/thumb/b/b1/Banana_Pi_BPI-CM5_1.jpg/300x225x300px-Banana_Pi_BPI-CM5_1.jpg.pagespeed.ic.kgaBoHgx-o.jpg)
Banana Pi BPI-CM5 with A311D2 design
![](/images/thumb/2/28/Banana_Pi_BPI-CM5_5.jpg/300x225x300px-Banana_Pi_BPI-CM5_5.jpg.pagespeed.ic.-g7n6udz46.jpg)
Banana Pi BPI-CM5 with BPI-CM4 base board
![](/images/thumb/3/31/Banana_Pi_BPI-CM4_1.jpg/300x300x300px-Banana_Pi_BPI-CM4_1.jpg.pagespeed.ic.vegDz3DSjR.jpg)
Banana Pi BPI-CM4 with A311D design
![](/images/thumb/1/12/BananaPi_BPI-CM4_base_board_1.jpg/300x300x300px-BananaPi_BPI-CM4_base_board_1.jpg.pagespeed.ic.6sGSfHusyK.jpg)
BPI-CM4 Computer module and development Kit with base board
![](/images/thumb/a/a7/Banana_Pi_BPI-CM4_2.jpg/300x225x300px-Banana_Pi_BPI-CM4_2.jpg.pagespeed.ic.OJ0Ny_1buV.jpg)
![](/images/thumb/d/df/Banana_Pi_BPI-CM4_9.jpg/300x200x300px-Banana_Pi_BPI-CM4_9.jpg.pagespeed.ic.s_P-lEX3jf.jpg)
![](/images/thumb/4/4f/Banana_Pi_BPI-M5_4.JPG/300x225x300px-Banana_Pi_BPI-M5_4.JPG.pagespeed.ic.5eDUNHGM8e.jpg)
![](/images/thumb/a/a9/BPI-M2_Pro_2.jpg/300x225x300px-BPI-M2_Pro_2.jpg.pagespeed.ic.QwYAEL6-Jj.jpg)
![](/images/thumb/6/6e/Banana_Pi_BPI-M2S_1.jpg/300x225x300px-Banana_Pi_BPI-M2S_1.jpg.pagespeed.ic.09oBHwAysc.jpg)
Banana Pi BPI-CM5 is a computer module with Amlogic A311D2 quad-core Cortex-A73 and quad-core Cortex-A53 SOC, Mali-G52 GPU MP8 GPU,4GB LPDDR4/LPDDR4x (Max 8G),16G eMMC flash (Max 128G),Designed with Board to Board connectors for enhanced stability same as Raspberry Pi CM4 , which means that it should work with carrier boards designed for the Raspberry Pi CM4.
- 1. Amlogic A311D2,quad-core Cortex-A73 and quad-core Cortex-A53 SOC
- 2. Mali-G52 GPU MP8 GPU
- 3. 4GB LPDDR4/LPDDR4x (Max 8G)
- 4. 16G eMMC flash (Max 128G)
- 5. Designed with Board to Board connectors for enhanced stability same as RasPi CM4
- 6. One on-board Gigabit Ethernet
- 7. One PCIe2.0 interface expansion, can flexibly add related modules
- 8. One USB3.0 port up to 5Gbps
- 9. One USB2.0 high-speed USB/IO witch support USB OTG
- 10. Three HDMI2.1 receiver ports
- 11. one HDMI2.1 transmitter port with CEC
- 12. two 8-lane V-by-One output can support up to 4Kx2K resolution(Multiplexing with MIPI-DSI/eDP/LVDS)
- 13. two 4-lane MIPI-CSI camera interface with 16Mp ISP
- 14. support Android and Linux system.
- 15. Size: 55x40mm
BPI-CM5 Module Hardware interface
BPI-CM5 Module PIN Out define
BPI-CM5 moudule base board interface
Banana Pi BPI-CM5 SBC specifications
Same size as RPI CM4
- geerlingguy sbc-reviews : https://github.com/geerlingguy/sbc-reviews/issues/11
- BPI-M2S/CM4 Android9 Source Code
- Baidu Cloud: https://pan.baidu.com/s/1rANGEB-1MLPCBXqOR5aYCg?pwd=8888 (pincode: 8888)
- Google Drive: https://drive.google.com/drive/folders/1INIABp_MbB5UcwfqujTngGLOZN7YGuWp?usp=share_link
- BPI-CM4 Schematic:https://drive.google.com/file/d/1IXXok1P2OLiW3p8tavkbfEPTGTrM3b-R/view?usp=sharing
- BPI-CM4 Base board Schematic:https://drive.google.com/file/d/1IErCKqfWdU7gL7kUod2-wlpG7uE9EiVZ/view?usp=sharing
- BPI-CM4 DXF file: https://drive.google.com/file/d/1hTLNCwmYhCuzt9rL6fP0PjK4MTIE5dK6/view?usp=sharing
- BPI-CM4 Base board DXF file: https://drive.google.com/file/d/1-K3ESgU63S4ynwwNbe0p3Ol1ajOsufQ8/view?usp=sharing
- UglyScale Present - Banana Pi BPI-CM4 : https://www.youtube.com/watch?v=9qhAmpjdEfE
- Banana Pi CM4 Review ( VS Compute Raspberrypi CM4) : https://bret.dk/banana-pi-cm4-review/
- 2023-01-12-bpi-m2s-cm4-android9.img
- Baidu Cloud: https://pan.baidu.com/s/1YVl0T9rSNqM3D0I1BRUr7A?pwd=8888 (pincode): 8888
- Google Drive:https://drive.google.com/drive/folders/1u8flA6zsMOLnr75U4rvbph02z8YUKe2Y?usp=share_link
- 2023-01-12-ubuntu-20.04-mate-desktop-bpi-cm4-aarch64-sd-emmc.img
- Baidu Cloud: https://pan.baidu.com/s/1rh55yoEjPWsHXIcna7xEhQ?pwd=8888 (pincode: 8888)
- Google Drive:https://drive.google.com/drive/folders/1xd2HA4Vv_U69iREiAUkOftZmmVbjw7yF?usp=share_link
- 2023-01-12-ubuntu-20.04-server-bpi-cm4-aarch64-sd-emmc.img
- Baidu Cloud: https://pan.baidu.com/s/17gu0ToxWmFi2i8VwuiqVDQ?pwd=8888 (pincode:8888)
- Google Drive:https://drive.google.com/drive/folders/1i7okuijL3Jd99vf8PYuK7uH8D2t_WJZg?usp=share_link
- 2023-01-12-debian-10-buster-bpi-cm4-aarch64-sd-emmc.img
- Baidu Cloud: https://pan.baidu.com/s/19aQB16fdo2Si-is76R9LOQ?pwd=8888 (pincode: 8888)
- Google Drive:https://drive.google.com/drive/folders/1_k0RYmuZoBBk4GCaDDOD112FDORcV5g2?usp=share_link
Third part image
- Armbian unstable current build for Bananapi CM4
Armbian image release on 2023-01-12
- Armbian_23.02.0-trunk_Bananapicm4_bullseye_current_6.0.14.img
- Baidu Cloud: https://pan.baidu.com/s/1c4TuvJIB89tXuKEYYIqAfA?pwd=8888 (pincode:8888)
- Google Drive:https://drive.google.com/drive/folders/1SbBUT9abRHcQmqlVGiexOZAHl0hXKO91?usp=share_link
- Armbian_23.02.0-trunk_Bananapicm4_bullseye_current_6.0.14_minimal.img
- Baidu Cloud:https://pan.baidu.com/s/1ZLzHljFLbUU6NUeI8nfCRQ?pwd=8888 (pincode: 8888)
- Google Drive:https://drive.google.com/drive/folders/1SiWoz8o8Ed3Q1jQfSC8WsDjf1J6YLdMo?usp=share_link
- Armbian_23.02.0-trunk_Bananapicm4_jammy_current_6.0.14_minimal.img
- Baidu Cloud:https://pan.baidu.com/s/1E-DfPO0bIVlkehgn1buu0g?pwd=8888 (pincode: 8888)
- Google Drive:https://drive.google.com/drive/folders/1b5eF2vdXXLCg2P_HVAuQD2xM-NWnhu7Z?usp=share_link
- Armbian_23.02.0-trunk_Bananapicm4_jammy_current_6.0.14_cinnamon_desktop.img
- Baidu Cloud:https://pan.baidu.com/s/16ImDYZraNWPSmrUGbvZY2Q?pwd=8888 (pincode: 8888)
- Google Drive:https://drive.google.com/drive/folders/1EpwNek2rO8qSb_yUEU6NSdzf-LXvJgws?usp=share_link
- Armbian_23.02.0-trunk_Bananapicm4_jammy_current_6.0.14_gnome_desktop.img
- Baidu Cloud:https://pan.baidu.com/s/17cTi__f0hmR2WbAjk2th-g?pwd=8888 (pincode:8888)
- Google Drive:https://drive.google.com/drive/folders/1RpJwj98ap4uJwD14tN45GuJbJOSea5d5?usp=share_link
- Armbian_23.02.0-trunk_Bananapicm4_bullseye_current_6.0.14_xfce_desktop.img
- Baidu Cloud:https://pan.baidu.com/s/1slqc3OSi8-WnEG6OhfAwhg?pwd=8888 (pincode:8888)
- Google Drive:https://drive.google.com/drive/folders/1HhdXYjsPfJjgF_rEttxvAAQoq79itDan?usp=share_link
- Armbian_23.02.0-trunk_Bananapicm4_jammy_current_6.0.14.img
- Baidu Cloud:https://pan.baidu.com/s/1ivnnQFyMLauq5xH8KQBO7A?pwd=8888 (pincode:8888)
- Google Drive:https://drive.google.com/drive/folders/1YBNbKY_4uhd0hW0ISb2Q9127z1W7-fLU?usp=share_link
