Banana Pi BPI-CM5
Revision as of 04:06, 29 May 2023 by Sinovoip (talk | contribs)
BPI-CM5 Introduction
Banana Pi BPI-CM5 with A311D2 design
Banana Pi BPI-CM5 with BPI-CM4 base board
Banana Pi BPI-CM4 with A311D design
Banana Pi BPI-CM5 is a computer module with Amlogic A311D2 quad-core Cortex-A73 and quad-core Cortex-A53 SOC, Mali-G52 GPU MP8 GPU,4GB LPDDR4/LPDDR4x (Max 8G),16G eMMC flash (Max 128G),Designed with Board to Board connectors for enhanced stability same as Raspberry Pi CM4 , which means that it should work with carrier boards designed for the Raspberry Pi CM4.
  • 1. Amlogic A311D2,quad-core Cortex-A73 and quad-core Cortex-A53 SOC
  • 2. Mali-G52 GPU MP8 GPU
  • 3. 4GB LPDDR4/LPDDR4x (Max 8G)
  • 4. 16G eMMC flash (Max 128G)
  • 5. Designed with Board to Board connectors for enhanced stability same as RasPi CM4
  • 6. One on-board Gigabit Ethernet
  • 7. One PCIe2.0 interface expansion, can flexibly add related modules
  • 8. One USB3.0 port up to 5Gbps
  • 9. One USB2.0 high-speed USB/IO witch support USB OTG
  • 10. Three HDMI2.1 receiver ports
  • 11. one HDMI2.1 transmitter port with CEC
  • 12. two 8-lane V-by-One output can support up to 4Kx2K resolution(Multiplexing with MIPI-DSI/eDP/LVDS)
  • 13. two 4-lane MIPI-CSI camera interface with 16Mp ISP
  • 14. support Android and Linux system.
  • 15. Size: 55x40mm
Getting Started with CM5
BPI-CM5 Module Hardware interface
BPI-CM5 Module PIN Out define
Same size as RPI CM4
Baidu Cloud: https://pan.baidu.com/s/1rANGEB-1MLPCBXqOR5aYCg?pwd=8888 (pincode: 8888)
Google Drive: https://drive.google.com/drive/folders/1INIABp_MbB5UcwfqujTngGLOZN7YGuWp?usp=share_link
How to flash Android Image
  • 2023-01-12-bpi-m2s-cm4-android9.img
Baidu Cloud: https://pan.baidu.com/s/1YVl0T9rSNqM3D0I1BRUr7A?pwd=8888 (pincode): 8888
Google Drive:https://drive.google.com/drive/folders/1u8flA6zsMOLnr75U4rvbph02z8YUKe2Y?usp=share_link
How to flash Linux Image
  • 2023-01-12-ubuntu-20.04-mate-desktop-bpi-cm4-aarch64-sd-emmc.img
Baidu Cloud: https://pan.baidu.com/s/1rh55yoEjPWsHXIcna7xEhQ?pwd=8888 (pincode: 8888)
Google Drive:https://drive.google.com/drive/folders/1xd2HA4Vv_U69iREiAUkOftZmmVbjw7yF?usp=share_link
  • 2023-01-12-ubuntu-20.04-server-bpi-cm4-aarch64-sd-emmc.img
Baidu Cloud: https://pan.baidu.com/s/17gu0ToxWmFi2i8VwuiqVDQ?pwd=8888 (pincode:8888)
Google Drive:https://drive.google.com/drive/folders/1i7okuijL3Jd99vf8PYuK7uH8D2t_WJZg?usp=share_link
  • 2023-01-12-debian-10-buster-bpi-cm4-aarch64-sd-emmc.img
Baidu Cloud: https://pan.baidu.com/s/19aQB16fdo2Si-is76R9LOQ?pwd=8888 (pincode: 8888)
Google Drive:https://drive.google.com/drive/folders/1_k0RYmuZoBBk4GCaDDOD112FDORcV5g2?usp=share_link
Third part image
Armbian unstable current build for Bananapi CM4
Armbian image release on 2023-01-12
  • Armbian_23.02.0-trunk_Bananapicm4_bullseye_current_6.0.14.img
Baidu Cloud: https://pan.baidu.com/s/1c4TuvJIB89tXuKEYYIqAfA?pwd=8888 (pincode:8888)
Google Drive:https://drive.google.com/drive/folders/1SbBUT9abRHcQmqlVGiexOZAHl0hXKO91?usp=share_link
  • Armbian_23.02.0-trunk_Bananapicm4_bullseye_current_6.0.14_minimal.img
Baidu Cloud:https://pan.baidu.com/s/1ZLzHljFLbUU6NUeI8nfCRQ?pwd=8888 (pincode: 8888)
Google Drive:https://drive.google.com/drive/folders/1SiWoz8o8Ed3Q1jQfSC8WsDjf1J6YLdMo?usp=share_link
  • Armbian_23.02.0-trunk_Bananapicm4_jammy_current_6.0.14_minimal.img
Baidu Cloud:https://pan.baidu.com/s/1E-DfPO0bIVlkehgn1buu0g?pwd=8888 (pincode: 8888)
Google Drive:https://drive.google.com/drive/folders/1b5eF2vdXXLCg2P_HVAuQD2xM-NWnhu7Z?usp=share_link
  • Armbian_23.02.0-trunk_Bananapicm4_jammy_current_6.0.14_cinnamon_desktop.img
Baidu Cloud:https://pan.baidu.com/s/16ImDYZraNWPSmrUGbvZY2Q?pwd=8888 (pincode: 8888)
Google Drive:https://drive.google.com/drive/folders/1EpwNek2rO8qSb_yUEU6NSdzf-LXvJgws?usp=share_link
  • Armbian_23.02.0-trunk_Bananapicm4_jammy_current_6.0.14_gnome_desktop.img
Baidu Cloud:https://pan.baidu.com/s/17cTi__f0hmR2WbAjk2th-g?pwd=8888 (pincode:8888)
Google Drive:https://drive.google.com/drive/folders/1RpJwj98ap4uJwD14tN45GuJbJOSea5d5?usp=share_link
  • Armbian_23.02.0-trunk_Bananapicm4_bullseye_current_6.0.14_xfce_desktop.img
Baidu Cloud:https://pan.baidu.com/s/1slqc3OSi8-WnEG6OhfAwhg?pwd=8888 (pincode:8888)
Google Drive:https://drive.google.com/drive/folders/1HhdXYjsPfJjgF_rEttxvAAQoq79itDan?usp=share_link
  • Armbian_23.02.0-trunk_Bananapicm4_jammy_current_6.0.14.img
Baidu Cloud:https://pan.baidu.com/s/1ivnnQFyMLauq5xH8KQBO7A?pwd=8888 (pincode:8888)
Google Drive:https://drive.google.com/drive/folders/1YBNbKY_4uhd0hW0ISb2Q9127z1W7-fLU?usp=share_link
