BPI-Bit
Revision as of 09:48, 6 March 2023 by Sinovoip (talk | contribs)
BPI-Bit with ESP32
BPI-Bit V2 with ESP32-S2
BPI-Leaf-S3 with ESP32-S3
BPI-AI Kendryte K210 RISC-V
BPI-UNO32 with ESP32 design
Overview: BPI:bit
BPI:bit gpio expansion board
BPI:bit robot expansion board
BPI Q-Car kit with BPI:Bit board
BPI-K210 RISC-V AIoT board
  • Buzzer: GPIO25
GPIO control of BPI:bit
Light Sensor(L) GPIO 36 Analog Input
Light Sensor(R) GPIO 39 Analog Input
Botton A GPIO 35 Digital Input
Botton B GPIO 27 Digital Input
Temperature Sensor GPIO 34 Analog Input
Buzzer GPIO 25 PWM(Digital Output) / Analog Output
RGB_LED GPIO 4 Digital Output
MPU9250_SCL GPIO 22 Digital Output
MPU9250_SDA GPIO 21 Digital Output
MPU9250_INT GPIO 16 Digital Input
R_LED(SPI_SCK) GPIO 18 Digital Output
Hardware description
Webduion bit board has a compact size of 50mm x 50mm, weighs 10-12 grams.It has 20 pins at the bottom,25 full color LED array in the middle, two photo cells,two buttons, one thermistor,one buzzer,one 9-axis sensor(3-axis accelerometer,3-axis gyroscope and 3-axis magnetometer)
PIN definitions
P3 ADC2_CH4 GPIO13
P0 ADC2_CH8 DAC_1 GPIO25
P4 ADC2_CH3 GPIO16
P5 ADC1_CH7 GPIO35
P6 ADC2_CH5 GPIO12
P7 ADC2_CH6 GPIO14
P1 ADC1_CH4 GPIO32
P8 GPIO16
P9 GPIO17
P10 ADC2_CH9 DAC_2 GPIO26
P11 ADC2_CH7 GPIO27
P12 ADC2_CH2 GPIO02
P2 ADC1_CH5 GPIO33
P13 GPIO18 SPI_SS
P14 GPIO19 SPI_SCK
P15 GPIO23 SPI_MISO
P16 GPIO05 SPI_MOSI
3V3 POWER:3V3
3V3 POWER:3V3
3V3 POWER:3V3
P19 GPIO22 I2C_SCL
P20 GPIO21 I2C_SDA
GND GROUND
GND GROUND
GND GROUND
5*5 25 LED
25 5*5 LED list of BPI:bit
20 15 10 5 0
21 16 11 6 1
22 17 12 7 2
23 18 13 8 3
24 19 14 9 4
MPU9250 9-axis sensor
BPI-BIT MPU9250 Library and how to : https://github.com/BPI-STEAM/MPU9250
BPI:bit power
BPI:bit VS micro:bit
bpi:bit VS micro:bit
Module bpi:bit micro:bit
RAM 520 KB 16 KB
ROM 448 KB Unkown
Flash 4096 KB 256 KB
WIFI 802.11 b/g/n/e/i N/A
Buzzer 1x Buzzer N/A
Size 5*5 cm 5*4 cm
BPI:bit Software development
BPI:bit for Arduino
BPI:bit for Arduino
BPI:bit for MicroPyhton
BPI:bit for MicroPython
BPI:bit for Scratch
BPI:bit for Scratch
BPI STEAM education website
https://bpi-steam.com/
Forum
free discuss forum : http://forum.banana-pi.org/c/bpi-bit
Books:
  • Plataforma STEAM Webduino. WEB:Bit manual para el aula.: Herramienta para el estudio de las Ciencias de la Computación en la Educación Primaria y Secundaria (Spanish Edition) Kindle Edition
https://www.amazon.com/gp/product/B0B4HNYBJ5/ref
Github
test routine
Useful links
