Getting Started with BPI-W3
Revision as of 08:32, 13 February 2023 by Sinovoip (talk | contribs)
Banana Pi BPI-R64 MTK MT7622
The below steps is to flash linux release image into BPI-W3
1. Good Type-C data cable for image download into EMMC
2. Usb to ttl cable if you need debug, default baudrate is 1500000.
3. Windows or Linux PC.
4. Download the Linux Release Image Linux Release Image, and confirm that the md5 checksum is correct before flashing.
Note: The below picture is for BPI-W3's Debug Connecting, the red usb cable is Type-C data cable for image download, the three colors usb to ttl cable is linux serial console, please install CH340E's USB convert serial driver.
Windows Driver install
File:Driver install.PNG
This tool defaults language is Chinese. you can change it to English after extract the package. Open RKDevTool_Release_v2.84/config.ini with an text editor (like notepad). The starting lines are:
 #Language Selection: Selected=1(Chinese); Selected=2(English)
 [Language]
 Kinds=2
 Selected=2
 LangPath=Language\
4. Disconnect power adapter, connect dual male usb cable from the top usb host port to PC.Use the Type-C data cable to connect one end to the PC and the other end to the BPI-W3 board.
  • Uboot Usb Download Mode (loader mode)
It's supposed to use this way if board already flashed a bootable uboot before.
  • Maskrom Usb Download Mode
Press the Recovery button or Maskrom button beside 3pin uart header and hold, connect the power adapter or press the RST button if power adapter already connected, about two seconds later, release the button. PC will Identify the device if RK usb driver installed correctly.
The download tool also show the download mode if device connected.
Install Image with SDcard
Build Linux BSP Source Code
1. Get Linux source code
2. Build the Linux BSP Source code
Dual Display
  Note: All linux Image suuport dual display HDMI and MIPI-DSI together, MIPI-DSI only support 1200x1920.
  Note: HDMI Display
  Note: MIPI-DSI panel Display
Wlan&BT
CN13 M.2 KEY E Slot is used for connect Wlan&BT adapter, default image support RTL8822CE(PCIE+USB) and RTL8822CS(SDIO+UART).
