BPI-M2S Introduction
BPI-M2S with Wifi&BT module
BananaPi BPI-M2S new design with Amlogic A311D Quad core ARM Cortex-A73 and dual core ARM Cortex-A53 CPU ,ARM G52 MP4(6EE) GPU,NPU for AI at 5.0 TOPS, support Camera and MIPI-CSI interface ,HDMI output,2 Gigabit port . 4G RAM and 16 GB eMMC flash.Amlogic S922X variant M2S board is not support npu, mipi panel and mipi camera.BPI-M2S same size as Banana Pi BPI-M2+ and Banana Pi BPI-M2 Pro
- 4GB LPDDR4 RAM
- 16GB eMMC flash (Max 128G)
- 2 Gigabit port
- HDMI output
- 40 PIN GPIO
Getting Started with M2S
- System Memory – 4GB LPDDR4
- Video interfaces
- HDMI 2.1 output up to 4Kp60
- Misc – 3x buttons
- Dimensions – 65 x 65mm
PoE Wifi&BT
BPI-M2S 40PIN GPIO (CON2)
GPIO Pin Name |
Default :GPIO |
Function2 |
Function3
CON2-P01 |
VCC-3V3 |
CON2-P02 |
DCIN |
CON2-P03 |
GPIOX_17 |
I2C_EE_M2_SDA |
BT_EN
CON2-P04 |
DCIN |
CON2-P05 |
GPIOX_18 |
I2C_EE_M2_SCL |
BT_WAKE_HOST
CON2-P06 |
GND |
CON2-P07 |
GPIOX_5 |
PWM_C |
WIFI_SD_CMD
CON2-P08 |
GPIOX_12 |
UART_EE_A_TX |
CON2-P09 |
GND |
CON2-P10 |
GPIOX_13 |
UART_EE_A_RX |
CON2-P11 |
GPIOX_3 |
WIFI_SD_D3
CON2-P12 |
GPIOA_1 |
I2SB_SCLK
CON2-P13 |
GPIOX_4 |
WIFI_SD_CLK
CON2-P14 |
GND |
CON2-P15 |
GPIOX_7 |
WIFI_WAKE_HOST
CON2-P16 |
GPIOX_0 |
WIFI_SD_D0
CON2-P17 |
VCC-3V3 |
CON2-P18 |
GPIOX_1 |
WIFI_SD_D1
CON2-P19 |
GPIOX_8 |
SPI_A_MOSI |
BTPCM_DIN
CON2-P20 |
GND |
CON2-P21 |
GPIOX_9 |
SPI_A_MISO |
BTPCM_DOUT
CON2-P22 |
GPIOX_2 |
WIFI_SD_D2
CON2-P23 |
GPIOX_11 |
SPI_A_CLK |
BTPCM_CLK
CON2-P24 |
GPIOX_10 |
SPI_A_CS |
BTPCM_SYNC
CON2-P25 |
GND |
CON2-P26 |
GPIOX_16 |
BT_32K
CON2-P27 |
GPIOH_5 |
CON2-P28 |
GPIOH_4 |
CON2-P29 |
GPIOX_14 |
BTUART_A_CTS_N
CON2-P30 |
GND |
CON2-P31 |
GPIOX_15 |
BTUART_A_RTS_N
CON2-P32 |
GPIOX_19 |
HOST_WAKE_BT
CON2-P33 |
GPIOX_6 |
WIFI_PWREN
CON2-P34 |
GND |
CON2-P35 |
GPIOA_2 |
I2SB_LRCLK
CON2-P36 |
GPIOAO_5 |
IR_IN
CON2-P37 |
GPIOA_0 |
I2S_MCLK_0
CON2-P38 |
GPIOA_4 |
I2SB_DOUT_DIN_1
CON2-P39 |
GND |
CON2-P40 |
GPIOA_3 |
I2SB_DOUT_DIN_0
BPI-M2S Debug UART(CON1)
CON2-P1 |
GND
CON2-P2 |
UART0-RX
CON2-P3 |
UART0-TX
BPI-M2S Camera(CN10)
CSI Pin Name |
Default Function |
Function2:GPIO
CN10-P01 |
GND |
CN10-P02 |
MIPI_CSI_D3N |
CN10-P03 |
MIPI_CSI_D3P |
CN10-P04 |
GND |
CN10-P05 |
MIPI_CSI_D2N |
CN10-P06 |
MIPI_CSI_D2P |
CN10-P07 |
GND |
CN10-P08 |
MIPI_CSI_CLKBN |
CN10-P09 |
MIPI_CSI_CLKBP |
CN10-P10 |
GND |
CN10-P11 |
MIPI_CSI_D1N |
CN10-P12 |
MIPI_CSI_D1P |
CN10-P13 |
GND |
CN10-P14 |
MIPI_CSI_D0N |
CN10-P15 |
MIPI_CSI_D0P |
CN10-P16 |
GND |
CN10-P17 |
MIPI_CSI_CLKAN |
CN10-P18 |
MIPI_CSI_CLKAP |
CN10-P19 |
NC |
CN10-P20 |
CAM0_MCLK |
CN10-P21 |
CAM0_IRCUT |
CN10-P22 |
CAM0_SCL |
CN10-P23 |
CAM0_SDA |
CN10-P24 |
CAM0_RESET |
CN10-P25 |
VCC1V8_DOVDD |
CN10-P26 |
GND |
CN10-P27 |
GND |
CN10-P28 |
VCC33 |
CN10-P29 |
VCC33 |
CN10-P30 |
VCC33 |
BPI-M2S LCD(CN9)
DSI Pin Name |
Default Function |
Function2:GPIO
CN9-P01 |
MIPI_D0_N |
CN9-P02 |
MIPI_D0_P |
CN9-P03 |
MIPI_D1_N |
CN9-P04 |
MIPI_D1_P |
CN9-P05 |
MIPI_CLK_N |
CN9-P06 |
MIPI_CLK_P |
CN9-P07 |
MIPI_D2_N |
CN9-P08 |
MIPI_D2_P |
CN9-P09 |
MIPI_D3_N |
CN9-P10 |
MIPI_D3_P |
CN9-P11 |
TP_INT_3V3 |
CN9-P12 |
TP_RST_3V3 |
CN9-P13 |
I2C_M3_SCL_3V3 |
CN9-P14 |
I2C_M3_SDA_3V3 |
CN9-P15 |
LCD_BL_EN_3V3 |
CN9-P16 |
LCD_PWM_3V3 |
CN9-P17 |
GND |
CN9-P18 |
GND |
CN9-P19 |
VLCD_5V |
CN9-P20 |
VLCD_5V |
- How to flash Android Image
- Baidu Cloud: https://pan.baidu.com/s/1C-EiB4UcjuSYCfjFNlVL0g?pwd=8gqg (pincode: 8gqg)
- Google Drive:https://drive.google.com/file/d/1SkFY9Zoc5NY_wNXkzw514-DnN_TBy0K6/view?usp=sharing
- Baidu Cloud: https://pan.baidu.com/s/1Z8KmmvvA8Bc-JwR4nbBOWA?pwd=dtk8 (pincode: dtk8)
- Google Drive:https://drive.google.com/file/d/1U3wLxouH2-IBBYQmHngWErLCwIJgLA7G/view?usp=sharing
- How to flash Linux Image
Raspbian
- google driver: https://drive.google.com/drive/folders/1oqamIMl5Kmb3LVYMPFw-1tilvwKQI6n-
- discuss on forum : https://forum.banana-pi.org/t/bpi-m5-bpi-m2-pro-new-image-rasbian-image-2022-4-09-update/13246
- Baidu Cloud: https://pan.baidu.com/s/1o8itbnSMq3zmp28Wstn8iA?pwd=q3cx (pincode: q3cx)
- Google drive:https://drive.google.com/file/d/1gpVaqs-iyDIglCuRr4h3G73Wlb81kFPr/view?usp=sharing
- Baidu Cloud: https://pan.baidu.com/s/1IAugHTujzkTV9zfQoLw-iA?pwd=a37k (pincode: a37k)
- Google Drive:https://drive.google.com/file/d/1ASyBYkQmv6RMg_NSf2KQTpd87PosyeW-/view?usp=sharing
- Google Drive:
