Banana Pi BPI-W3
[hide]Introduction
File:Baanna Pi BPI-W3 2.jpg
The Banana Pi BPI-W3 is a router based development board, it design with Rochchip RK3588 quad ARM Cortex-A76 and quad Cortex-A55 consists of an eight-core CPU processor. ,6Tops@INT8 NPU,8G memory,32G eMMC storage on board .which can run on a variety of open source operating systems including OpenWrt, Android, and linux. It has 1 Gigabit LAN ports, 1 Gigabit WAN., it also with 2 HDMI out and 1 HDMI in port.
SoC | RockChip RK3588 |
CPU | quad ARM Cortex-A76 and quad Cortex-A55 consists of an eight-core CPU processor |
GPU | ARM Mali-G610 MP4,support OpenGL ES 1.1/2.0/3.2,OpenCL 2.2,Vulkan 1.1 Embedded high-performance 2D acceleration hardware |
NPU | 6Tops@INT8 , |
Video decode | Caffe/TensorFlow/TFLite/ONNX PyTorch/Keras/Darknet mainstream architecture model of a key transformation VPU support 8 k 60 FPS h. 265 / AVS2 Profile0 / VP9 video decoding |
Video encode | Supports 8K 30FPS H.265/H.264 video encoding |
RAM | 8GB LPDDR4 |
eMMC flash | 32GB |
Onboard Network | 2x 10/100/1000Mbps Ethernet |
GPIO | 40 Pins Header, 28×GPIO, some of which can be used for specific functions including UART, I2C, SPI, PWM, I2S. |
System | Android 12.0 ,Linux support |
Power | current and voltage 12V/2A |
operating temperature | 0℃ ~ 80℃(Measurement can reach -20 degrees to 85 degrees) |
size | 148mm * 101mm |
- Rockchip RK3588 Datasheet V1.1-20220124:https://drive.google.com/file/d/1EXA766HZ3Ch-meZJhPuSAhKqvfGseJ2A/view?usp=sharing
- Rockchip RK3588S Datasheet V1.3-20220310 : https://drive.google.com/file/d/1XV7W7Yir4gEq5D4t1Z05ELdfcYM8ZEIN/view?usp=sharing
- Rockchip RK3588 TRM V1.0-20220309
- google driver:https://drive.google.com/file/d/1DtdEpVKOrds0fmeWAwB73b_DIkKtskYE/view?usp=sharing
- baidu link : https://pan.baidu.com/s/15mgdhPV05g7ty3W1lMaoaQ Pincode:ydtx
- Rockchip company PPT :https://drive.google.com/file/d/1To3qrA7mPzZTFXTv5aRktu59NA2aomNY/view?usp=sharing
