Banana Pi BPI-W3
Revision as of 02:02, 20 July 2022 by Sinovoip (talk | contribs) (Hardware spec)
File:Baanna Pi BPI-W3 2.jpg
BPI-RK3588 Stamp hole Core board and development Kit
The Banana Pi BPI-W3 is a router based development board, it design with Rochchip RK3588 quad ARM Cortex-A76 and quad Cortex-A55 consists of an eight-core CPU processor. ,6Tops@INT8 NPU,8G memory,32G eMMC storage on board .which can run on a variety of open source operating systems including OpenWrt, Android, and linux. It has 1 Gigabit LAN ports, 1 Gigabit WAN., it also with 2 HDMI out and 1 HDMI in port.
SoC RockChip RK3588
CPU quad ARM Cortex-A76 and quad Cortex-A55 consists of an eight-core CPU processor
GPU ARM Mali-G610 MP4,support OpenGL ES 1.1/2.0/3.2,OpenCL 2.2,Vulkan 1.1 Embedded high-performance 2D acceleration hardware
NPU 6Tops@INT8 ,
Video decode Caffe/TensorFlow/TFLite/ONNX PyTorch/Keras/Darknet mainstream architecture model of a key transformation VPU support 8 k 60 FPS h. 265 / AVS2 Profile0 / VP9 video decoding
Video encode Supports 8K 30FPS H.265/H.264 video encoding
RAM 8GB LPDDR4
eMMC flash 32GB
System Android 12.0 ,Linux support
Power current and voltage 12V/2A
operating temperature 0℃ ~ 80℃(Measurement can reach -20 degrees to 85 degrees)
size 148mm * 101mm
google driver:https://drive.google.com/file/d/1DtdEpVKOrds0fmeWAwB73b_DIkKtskYE/view?usp=sharing
baidu link : https://pan.baidu.com/s/15mgdhPV05g7ty3W1lMaoaQ Pincode:ydtx
