Getting Started with R2PRO
[hide]Introduction
- 2. MicroUSB cable or usb to ttl cable if you need debug, default baudrate is 1500000.
- 3. Windows or Linux PC.
Windows
- Maskrom Usb Download Mode
Install Image with SDcard
- 1. Get Android source code
$ git clone https://github.com/Dangku/BPI-Rockchip-Android11 --depth=1
USB OTG Mode Switch
1. Tablet variant image
2. Box variant image
Dual Display
Wlan&BT
- 4. Download the Linux Release Image [1], and confirm that the md5 checksum is correct before flashing.
Windows
USB OTG Mode Switch
Dual Display
Wlan&BT
