Banana Pi BPI-R2 Pro
- Rockchip RK3568 Quad-core ARM Cortex-A55 CPU
- Mali-G52 1-Core-2EE
- 2G LPDDR4 SDRAM (option 4G)
- Mini PCIE interface and M.2 key-e interface
- support 1 SATA interface
- 16G eMMC flash (option 16/32/64G)
- 2 MIPI display interface support
- 1 CSI camera interface
Rockchip RK3568
Banana Pi R2 Pro | |
CPU | Rockchip RK3568 Quad-core ARM Cortex-A55 CPU 2GHz |
GPU | Mali-G52 1-Core-2EE OpenGL ES3.2 Vu1kn 1.1 OpenCL 2.0 |
Memory | 2G DDR3 SDRAM (option 4G) |
Storage | Onboard 16GB eMMC Flash, Micro SD-Card slot, SATA 2.0 Port,SPI flash |
Network | 5 x 10/100/1000 Mbit/s Ethernet |
Display(s) | 1 HDMI port, 2 DSI interface(1 DSI can change to LVDS by software) |
Camera | 1 CSI camera interfact |
Video decoder(s) | H.265 HEVC/MVC Main10 Profile [email protected] up to 4096x2304@60fps,H.264 AVC/MVC Main10 Profile yuv400/yuv420/yuv422/@L5.1 up to 4096x2304@60fps |
Video encoder(s) | H.264/AVC BP/MP/[email protected],up to 1920x1080@100fps, H.265/HEVC [email protected], up to 1920x1080@100fps (4096x4096@10fps with TILE) |
Audio Output(s) | HDMI & I2S & Speaker & Headphone |
USB port | USB 3.0 PORT (x2), micro USB OTG (x1) |
mini PCIE | 1 mini pcie interface & 1 M.2 key-e interface |
Remote | IR Receiver (x1) |
LED | Power Status and 8P8C |
Power Source | 12 volt @2A via DC Power and/or Micro USB (OTG) |
Size & Weight | 148 mm × 100.5mm 100g |
OS | OpenWRT, Linux and others OS |
Source Code
- Source code on github :https://github.com/BPI-SINOVOIP/BPI-R2PRO-BSP/
documents
- Rockchip RK3568 datasheet: https://drive.google.com/file/d/18_MCl-3p0iDTzeady8N40X_qUbECTNmd/view?usp=sharing
- Rockchip RK809 PMIC datasheet: https://drive.google.com/file/d/18jObGuXCguS_hIth9JKEoEQXWTmcJQMI/view?usp=sharing
- RTL8367RB-VB-CG Switch chip datasheet:https://drive.google.com/file/d/1Rua-SRJLPoV0NLnvwJg-fopsD178KIts/view?usp=sharing
Release image
All image for BPI-R2 Pro : Baidu : https://pan.baidu.com/s/1u5bIp0fMJPre-j0bXGfDWA?pwd=i8q6 Pincode: i8q6
ubuntu 21.04
- ubuntu 21.04 linux kernel 4.19 image 2022-5-16 update, HDMI ,eDP and SDIO interface RTL8822CS WIFI module working fine
- google driver: https://drive.google.com/drive/folders/1pFayiLS3cS0idClUlvHzaySaJMb_AOrB
- baidu link: https://pan.baidu.com/s/1zUVDXOmEur3KFpNW_va7Wg?pwd=ci4u Pincode ci4u
- video and boot log:https://forum.banana-pi.org/t/banana-pi-bpi-r2-pro-openwrt-ubuntu-debian-linux-image/13158
OpneWRT
- OpenWRT-21.02 linux kernel 4.19 image, 2022-5-16 update,HDMI ,eDP and SDIO interface RTL8822CS WIFI module working fine
- google driver: https://drive.google.com/drive/folders/10HzNC0pWhS8j3W7uaFQ5RGO7UK133Xt-
- baidu link: https://pan.baidu.com/s/1KUIJUB6nd_vKmRXms7NUKg?pwd=i72r Pincode: i72r
- Debian 10 linux kernel 4.19 image, 2022-5-16 update ,HDMI ,eDP and SDIO interface RTL8822CS WIFI module working fine
- google driver: https://drive.google.com/drive/folders/1LSJlHtkHC_Ua6zVgVI3BRJOVPUb6vWO6
- baidu link: https://pan.baidu.com/s/1rkVWlpeY0hIKPrIh3r7Nfw?pwd=n9gi Pincode: n9gi
- 2022-06-10 release, Android 11 with kernel 4.19.219, tablet variant image
- Download: [ 2022-06-10-Android11-bpi-r2pro.img.zip]
- MD5:
- MD5:
