Getting Started with R2PRO
[hide]Introduction
- 1. Double male USB data cable.
- 2. MicroUSB cable or usb to ttl cable if you need debug.
- 3. Windows or Linux PC.
- 4. Download the latest android image, and confirm that the md5 checksum is correct.
Windows
1. Download and install Rockchip USB driver for windows
2. Download Rockchip USB Download Tool for windows
- Maskrom Usb Download Mode
1. Download Linux USB Download Tool, And install it into the system as follows for easy invocation:
Install Image with SDcard
USB OTG Mode Switch
The top usb port is a usb 3.0 otg port, but without hw id pin, it only can be used as host or peripheral.The release image set host mode default, you can change it in Settings->Connected devices->USB Connect to PC, switch on is peripheral mode and switch off is host mode.
