Getting Started with R2PRO
1. Double male USB data cable.
2. MicroUSB cable or usb to ttl cable if you need debug.
3. Windows or Linux PC.
4. Download the latest android image, and confirm that the md5 checksum is correct.
MaskRom Mode
Upgrade Mode
Windows
1. Download and install Rockchip USB driver for windows
File:Driver install.PNG
2. Download Rockchip USB Download Tool for windows
This tool defaults language is Chinese. you can change it to English after extract the package. Open RKDevTool_Release_v2.84/config.ini with an text editor (like notepad). The starting lines are:
 #Language Selection: Selected=1(Chinese); Selected=2(English)
 [Language]
 Kinds=2
 Selected=1
 LangPath=Language\
  • Uboot Usb Download Mode (loader mode)
It's supposed to use this way if board already flashed a bootable uboot before.
  • Maskrom Usb Download Mode
Press the Recovery button or Maskrom button beside 3pin uart header and hold, connect the power adapter or press the RST button if power adapter already connected, about two seconds later, release the button. PC will Identify the device if RK usb driver installed correctly.
The download tool also show the download mode if device connected.
1. Download Linux USB Download Tool, And install it into the system as follows for easy invocation:
 $ unzip Linux_Upgrade_Tool_xxxx.zip
 $ cd Linux_UpgradeTool_xxxx
 $ sudo mv upgrade_tool /usr/local/bin
 $ sudo chown root:root /usr/local/bin/upgrade_tool
 $ sudo chmod a+x /usr/local/bin/upgrade_tool
 # upgrade again
USB OTG Mode Switch
The top usb port is a usb 3.0 otg port, but without hw id pin, it only can be used as host or peripheral.The release image set host mode default, you can change it in Settings->Connected devices->USB Connect to PC, switch on is peripheral mode and switch off is host mode.
