- 1. Double male USB data cable.
- 2. MicroUSB cable or usb to ttl cable if you need debug.
- 3. Windows or Linux PC.
- 4. Download the latest android image, and confirm that the md5 checksum is correct.
MaskRom Mode
Upgrade Mode
Windows
- 1. Download and install Rockchip USB driver for windows
- File:Driver install.PNG
- 2. Download Rockchip USB Download Tool for windows
#Language Selection: Selected=1(Chinese); Selected=2(English)
[Language]
Kinds=2
Selected=1
LangPath=Language\
![Download tool.PNG](/images/a/a1/1127x566xDownload_tool.PNG.pagespeed.ic.7vq8akmxg1.png)
- 3. Open RKDevTool.exe, Switch to the “upgrade firmware” page. Press the “firmware” button to open the image file to be upgraded. The upgrade tool displays detailed firmware information.
![Load image.PNG](/images/b/b0/902x453xLoad_image.PNG.pagespeed.ic.PrF9NGU-MT.png)
- 4. Disconnect power adapter, connect dual male usb cable from the top usb host port to PC.
- 5. There have two usb download mode for image upgrade.
- Maskrom Usb Download Mode
![Device manage.PNG](/images/7/7b/672x399xDevice_manage.PNG.pagespeed.ic.dVFUDhh4hp.png)
- The download tool also show the download mode if device connected.
![Load download.PNG](/images/b/b3/899x456xLoad_download.PNG.pagespeed.ic.9U0dLDnd95.png)
![Maskrom download.PNG](/images/0/0a/904x456xMaskrom_download.PNG.pagespeed.ic.yu5EH5uTxI.png)
- 6. Press the “upgrade” button to start the upgrade.
USB OTG Mode Switch
- The top usb port is a usb 3.0 otg port, but without hw id pin, it only can be used as host or peripheral.The release image set host mode default, you can change it in Settings->Connected devices->USB Connect to PC, switch on is peripheral mode and switch off is host mode.
File:Otg mode.jpg
