BPI-Bit
![](/images/thumb/4/47/ESP32_6.JPG/300x222x300px-ESP32_6.JPG.pagespeed.ic.1EbEnK4HRo.jpg)
- Buzzer: GPIO25
GPIO control of BPI:bit | |||
Hardware description
Webduion bit board has a compact size of 50mm x 50mm, weighs 10-12 grams.It has 20 pins at the bottom,25 full color LED array in the middle, two photo cells,two buttons, one thermistor,one buzzer,one 9-axis sensor(3-axis accelerometer,3-axis gyroscope and 3-axis magnetometer)
PIN definitions
P3 | ADC2_CH4 | GPIO13 | |||
P4 | ADC2_CH3 | GPIO16 | |||
P5 | ADC1_CH7 | GPIO35 | |||
P6 | ADC2_CH5 | GPIO12 | |||
P7 | ADC2_CH6 | GPIO14 | |||
P1 | ADC1_CH4 | GPIO32 | |||
P8 | GPIO16 | ||||
P9 | GPIO17 | ||||
P11 | ADC2_CH7 | GPIO27 | |||
P12 | ADC2_CH2 | GPIO02 | |||
P2 | ADC1_CH5 | GPIO33 | |||
P13 | GPIO18 | SPI_SS | |||
P14 | GPIO19 | SPI_SCK | |||
P15 | GPIO23 | SPI_MISO | |||
P16 | GPIO05 | SPI_MOSI | |||
3V3 | POWER:3V3 | ||||
P19 | GPIO22 | I2C_SCL | |||
P20 | GPIO21 | I2C_SDA | |||
GND | GROUND | ||||
GND | GROUND | ||||
GND | GROUND |
5*5 25 LED
20 | 15 | 10 | 5 | 0 |
21 | 16 | 11 | 6 | 1 |
22 | 17 | 12 | 7 | 2 |
23 | 18 | 13 | 8 | 3 |
24 | 19 | 14 | 9 | 4 |
MPU9250 9-axis sensor
BPI:bit power
BPI:bit VS micro:bit
RAM | 520 KB | 16 KB | |||||
ROM | 448 KB | Unkown | |||||
Size | 5*5 cm | 5*4 cm |
BPI:bit Software development
BPI:bit for Webduino
BPI:bit for Arduino
BPI:bit for MicroPyhton
BPI:bit for Scratch
- BPI:bit user manual
- BPI:bit dxf file
- BPI:bit 3D design file
Forum
free discuss forum : http://forum.banana-pi.org/c/bpi-bit
Github
test routine
Useful links
- ESP32 规格书 ESP32 datasheet]
- Espressif ESP32 Resources
- MPU9250 datasheet
- More others
- Webduino official website
- Webduino website in China
- Facebook group
