13 Codelab Scratch3
How to use scratch3 for bpi:bit
Online Scratch3 Codelab website,See here for more details CodeLab and scratch open soruce documents
First select the version of the system that works for you and get adapter ,No need installation , just open it.
And then going to refer to usb_microbit user manual,in a similar way,,choose mpfshell option。
Begin to use BPI:bit with CodeLab scratch 3
1,Make sure adapter software and scratch3 websites are open.
2,In scratch3, click on it (the expand button in the bottom left corner)
3,Scroll to the bottom, find the BPI :bit plug-in, select it, and click ok to return to the main interface.
4,Check the isconnected indicator to connect
5,At this point, insert the hardware and click on the connection button. (if you're not sure, check with your regular mpfshell) if connect , will show "true"
