Webduino firmware programming
firmware Bin file
File and burn position corresponding | |||
FileName | Function | ||
bit_default.bin | BPI-BIT Webduino standard firmware | ||
bit_stable.bin | BPI-BIT stable version Webduino firmware | ||
boot_app0.bin | Espressif-WROOM-32 master core program | ||
partitions.bin | BPI-BIT Webduino firmware partition table file | ||
bootloader_dio_40m.bin | Espressif-WROOM-32 bootloader(It is applicable to the DIO burning mode with a speed of 40MHz) |
Burning BPI:bit webduino firmware in Windows system
ESP FLASH DOWNLOAD TOOL
Tool download address:ESP Flash Download Tool
After downloading, unzip the archive and you will see an ESPFlashDownloadTool_v3.6.4.exe inside the folder. Open this shortcut and open an interface selection mode.
- Double-click to open espflashdownloadtool_v3.6.4.exe and select ESP32 DownloadTool to start
Select ESP32 DownloadTool:
- Check the four-line selection box, fill in the following four addresses 0x1000, 0x8000, 0xe000, 0x10000 in the box next to the column, and then select the corresponding file according to the following corresponding relations:
- Verify the burn Settings, File and burn position corresponding to:
set | file name | Position | |
1 | bootloader_dio_40m.bin | 0x1000 | |
2 | partitions.bin | 0x8000 | |
3 | boot_app0.bin | 0xe000 | |
4 | bit_default.bin | 0x10000 |
- SpiFlashConfig:
SpiFlashConfig | |||
1 | CrystalFreq | 40M | |
2 | SPI SPEED | 40MHz | |
3 | SPI MODE | DIO | |
4 | FLASH SIZE | 32Mbit | |
5 | COM | COMx(Fill in the port number assigned by the computer) | |
6 | BAUD | 1152000 |
Note : Where COMx is the serial number your system assigns to the board
During the burning process:
Finished:
Burn time is about 20s
- Please refer to the following legend for details:
Auto Flash工具
We recommend that you first run the AutoErase. Exe tool to clear the bit board memory before burning the new firmware
- AutoErase.exe double-click to run the script, and the latest serial port will be automatically selected (you can reconnect the bit board to the computer before burning). The script will automatically erase the memory of the bit board.
- Double click autoflashwebduinobin.exe to run the script will automatically select the latest access to the serial port, burning the corresponding firmware file with the directory below, a total of four files are as follows:
bootloader_dio_40m.bin,partitions.bin,boot_app0.bin,webduino.bin
