Webduino firmware programming
firmware Bin file
| FileName | Function | ||
| bit_default.bin | BPI-BIT Webduino standard firmware | ||
| bit_stable.bin | BPI-BIT stable version Webduino firmware | ||
| boot_app0.bin | Espressif-WROOM-32 master core program | ||
| partitions.bin | BPI-BIT Webduino firmware partition table file | ||
| bootloader_dio_40m.bin | Espressif-WROOM-32 bootloader(It is applicable to the DIO burning mode with a speed of 40MHz) | ||
Burning BPI:bit webduino firmware in Windows system
ESP FLASH DOWNLOAD TOOL
Tool download address:ESP Flash Download Tool
After downloading, unzip the archive and you will see an ESPFlashDownloadTool_v3.6.4.exe inside the folder. Open this shortcut and open an interface selection mode.
- Double-click to open espflashdownloadtool_v3.6.4.exe and select ESP32 DownloadTool to start
Select ESP32 DownloadTool:
- Check the four-line selection box, fill in the following four addresses 0x1000, 0x8000, 0xe000, 0x10000 in the box next to the column, and then select the corresponding file according to the following corresponding relations:
- Verify the burn Settings, File and burn position corresponding to:
- SpiFlashConfig:
| SpiFlashConfig | |||
| 1 | CrystalFreq | 40M | |
| 2 | SPI SPEED | 40MHz | |
| 3 | SPI MODE | DIO | |
| 4 | FLASH SIZE | 32Mbit | |
| 5 | COM | COMx(Fill in the port number assigned by the computer) | |
| 6 | BAUD | 1152000 | |
Note : Where COMx is the serial number your system assigns to the board
During the burning process:
Finished:
- Please refer to the following legend for details:
Burn time is about 20s
Auto Flash工具
