BPI:bit for Webduino
About webduino
Webduino working model
- 1 use WebComponents integration Breakout.
- 2 use WebSocket(Firmata) to interacting with the server.
- 3 Server use TCP/IP(Firmata) to control webduino terminal.
Webduino source code on github
More webduino function now is open source , and code update to github.
BPI:bit Webduino
How to :Use BPI:bit with webduino
webduino refer to the tutorial
