OLED12832 Module
Revision as of 02:08, 7 May 2018 by Qubot (talk | contribs) (Created page with " == OLED23832 Module== File:4.jpg ''' == 概述 == ''' OLED12832 Module For BPI是一个专门为BPI设计的OLED显示模块,可以直插所有型号BPI,其他部...")
OLED23832 Module
概述
OLED12832 Module For BPI是一个专门为BPI设计的OLED显示模块,可以直插所有型号BPI,其他部分板子也可以使用
点阵数量:128X32
尺寸:40X23
适宜温度:-30~70℃
原理图
芯片原理图
芯片用的是SSD1306,所以用法和OLED12864一样
模块接线图
| 模块 | GPIO | GPIO | 模块 |
| 40 | 39 | GND | |
| 38 | 37 | ||
| 36 | 35 | ||
| GND | 34 | 33 | |
| 32 | 31 | ||
| GND | 30 | 29 | |
| 28 | 27 | ||
| 26 | 25 | GND | |
| 24 | 23 | ||
| 22 | 21 | ||
| GND | 20 | 19 | |
| 18 | 17 | ||
| 16 | 15 | ||
| GND | 14 | 13 | |
| 12 | 11 | ||
| 10 | 9 | GND | |
| 8 | 7 | ||
| GND | 6 | 5 | SCL |
| VCC | 4 | 3 | SDA |
| 2 | 1 |
控制介绍
可以配合MikuPi 使用
也可以用BPI-[WiringPi2 https://github.com/BPI-SINOVOIP/BPI-WiringPi2],用法和OLED12864一样,具体以后再写
DataSheet
