产品介绍
M4 Zero是M2 Zero的后续型号,在性能上有着巨大提升,SOC升级为H618, CPU频率提升25% 。内存升级为DDR4, 容量翻4倍,新增8G eMMC。支持5G WiFi, 另外USB接口也升级为type-C,它的外形大小和40-pin接头与Raspberry Pi Zero W相同,它将适合Zero W的大部分外壳和配件。
- Allwinner H618, Quad-core ARM Cortex™-A53 processor
- ARM Mali G31 GPU
- 2.4G/5G WIFI & Bluetooth 4.2
- 2G LPDDR4 RAM
- 8G eMMC flash memory
- 1x USB2.0 Type-C OTG, 5V power supply
- 1x USB2.0 Type-C
- 1x miniHDMI 2.0a
- 1x 24-pin FPC connector
- 1x USB2.0
- 1x 100Mbps Ethernet
快速上手
硬件接口
| Hardware Specification of Banana pi BPI-M4 Zero
| CPU |
Allwinner H618, Quad-core ARM Cortex™-A53 processor, 64-bit, up to 1.5GHz
| GPU |
ARM Mali G31 GPU
| Memory |
2 GB LPDDR4
| Storage |
8G eMMC flash
| SD card |
MicroSD card slot, SDIO3.0
| Wireless |
2.4G/5G WiFi and Bluetooth 4.2
| HDMI |
1x miniHDMI 2.0a (up to 4K@60Hz with HDR10, CEC, DDC, SCDC), HDMI digital Audio output
| USB |
1x USB2.0 Type-C HOST, 1x USB2.0 Type-C OTG
| 40-pin header
28 pins GPIO and Power (+5V, +3.3V and GND)
| UART, SPI, TWI/I²C, PWM, PCM/I²S
| 24-pin FPC
0.5mm pitch FPC connector, 1x USB2.0, 1x IR, 1x 100Mbps Ethernet
| 9 pins GPIO, UART,TWI/I²C, PWM, PCM/I²S
| Buttons |
Reset, FEL
| LED |
Power Status and Activity status
| Power |
5V@3A via USB Type-C
| Size |
65mm × 30mm
| Weight |
PIN 定义
| 40-pin header define and GPIO Alternative Functions Assignments
| Pin Num
Pin Name
ALT0
ALT1
ALT2
ALT3
| 1
3.3V
| 2
5V
| 3
PG16
UART2_RX
TWI4_SDA
| 4
5V
| 5
PG15
UART2_TX
TWI4_SCK
| 6
GND
| 7
PG19
PWM1
| 8
PG6
UART1_TX
| 9
GND
| 10
PG7
UART1_RX
| 11
PH2
UART5_TX
PWM2
| 12
PG11
H_I2S2_BCLK
| 13
PH3
UART5_RX
PWM1
| 14
GND
| 15
PG2
| 16
PG8
UART1_RTS
| 17
3.3V
| 18
PG9
UART1_CTS
| 19
PH7
UART2_RTS
H_I2S3_LRCK
SPI1_MOSI
| 20
GND
| 21
PH8
UART2_CTS
H_I2S3_DOUT0
SPI1_MISO
H_I2S3_DIN1
| 22
PG1
| 23
PH6
UART2_RX
H_I2S3_BCLK
SPI1_CLK
| 24
PH5
UART2_TX
H_I2S3_MCLK
SPI1_CS0
| 25
GND
| 26
PH9
H_I2S3_DIN0
SPI1_CS1
H_I2S3_DOUT1
| 27
PG18
UART2_CTS
TWI3_SDA
| 28
PG17
UART2_RTS
TWI3_SCK
| 29
PG3
| 30
GND
| 31
PG4
| 32
PG0
| 33
PG5
| 34
GND
| 35
PG12
H_I2S2_LRCK
| 36
PH4
| 37
PG10
H_I2S2_MCLK
| 38
PG14
H_I2S2_DIN0
H_I2S2_DOUT1
| 39
GND
| 40
PG13
H_I2S2_DOUT0
H_I2S2_DIN1
24-pin FPC
| 24-pin FPC define and GPIO Alternative Functions Assignments
| Pin Num
Pin Name
ALT0
ALT1
| 1
GND
| 2
EPHY_RXN
| 3
EPHY_RXP
| 4
EPHY_TXN
| 5
EPHY_TXP
| 6
GND
| 7
PI9
UART3_TX
TWI2_SCK
| 8
PI10
UART3_RX
TWI2_SDA
| 9
PI12
UART3_CTS
PWM2
| 10
PI11
UART3_RTS
PWM1
| 11
3V3
| 12
3V3
| 13
PI4
H_I2S0_DIN0
H_I2S0_DOUT1
| 14
PI3
H_I2S0_DOUT0
H_I2S0_DIN1
| 15
PI2
H_I2S0_LRCK
| 16
PI1
H_I2S0_BCLK
| 17
PI0
H_I2S0_MCLK
| 18
GND
| 19
PH10
IR_RX
| 20
5V
| 21
5V
| 22
USB2_DP
| 23
USB2_DM
| 24
GND
BPI-M4 Zero Debug UART
| 1 |
GND
| 2 |
UART0_RX
| 3 |
UART0_TX
开发
源码
资源
- Baidu Cloud: https://pan.baidu.com/s/1Mjpa8V_rm9S_advARWvzKA?pwd=8888 (pincode:8888)
- Google Drive: https://drive.google.com/file/d/1HBTiiMwU5mz2ogGsBUwHz2idkqJpXCNB/view?usp=sharing
- Baidu Cloud: https://pan.baidu.com/s/1KPAf3tz_-h-9PWv-6VcAJg?pwd=8888 (pincode:8888)
- Google Drive: https://drive.google.com/file/d/1WUFn_GItB6fBIt0C-ejdyu3FwznuGmCr/view?usp=sharing
- BPI-M4 Zero SBC bench test:
- Baidu Cloud: https://pan.baidu.com/s/10Rk4xLMOhIkk-gIoQx9DQw?pwd=8888 (pincode:8888)
- Google Drive: https://drive.google.com/file/d/1N6oWF9PHTcxXC1JY4x3Malr3twFv2wWZ/view?usp=sharing
系统镜像
- 2024-01-14-bananapi-m4zero-android12-box.img.
- Baidu Cloud: https://pan.baidu.com/s/1HRiOLLBwdrLehv_z2sksfA?pwd=8888 (pincode:8888)
- Google Drive: https://drive.google.com/drive/folders/15XDTLd5VqZxfgmv7tlqDBHrgOGvaBofU?usp=sharing
- Baidu Cloud: https://pan.baidu.com/s/1rNXZc_OKJHyUVOPXtCixcQ?pwd=8888 (pincode:8888)
- Google Drive: https://drive.google.com/drive/folders/18ZvhcAMIOWyAZxHcxNGJmKVjZidYqGtW?usp=sharing
- 2023-12-12 Bpi-m4zero_1.0.0_ubuntu_jammy_minimal_linux6.1.31
- Baidu Cloud: https://pan.baidu.com/s/1GCfkl6nNP3aBZytS8G909g?pwd=8888 (pincode:8888)
- Google Drive: https://drive.google.com/file/d/1qNRjN5O5oOoYPXy0efrTPVZkE8KjbH5K/view?usp=sharing
- 2023-12-12 Bpi-m4zero_1.0.0_ubuntu_jammy_desktop_xfce_linux6.1.31
- Baidu Cloud: https://pan.baidu.com/s/1DsKB_bOdcKrHSI5pmZV6bg?pwd=8888 (pincode:8888)
- Google Drive: https://drive.google.com/file/d/1yRkGWEd2uLsXu1WPgBG-FUhDICgte_90/view?usp=sharing
购买
- SINOVOIP Aliexpress shop: https://www.aliexpress.us/item/1005006325178305.html
- Bipai Aliexpress shop: https://www.aliexpress.us/item/1005006325280213.html
- 淘宝店铺: https://item.taobao.com/item.htm?spm=a21dvs.23580594.0.0.4fee3d0dOP5VBH&ft=t&id=754939469582
