Banana Pi BPI-CM2
Revision as of 04:33, 27 July 2023 by Sinovoip (talk | contribs) (Created page with "zh:香蕉派 BPI-CM2 =BPI-CM2 Introduction= thumb|[[Banana Pi BPI-CM5 with A311D2 design]] File:Banana_Pi_BPI-CM5_5.jpg|thumb|[[Banana P...")
Banana Pi BPI-CM5 with BPI-CM4 base board
Banana Pi BPI-CM4 with A311D design
BPI-CM4 Computer module and development Kit with base board
Banana Pi BPI-CM5 is a computer module with Amlogic A311D2 quad-core Cortex-A73 and quad-core Cortex-A53 SOC, Mali-G52 GPU MP8 GPU,4GB LPDDR4/LPDDR4x (Max 8G),16G eMMC flash (Max 128G),Designed with Board to Board connectors for enhanced stability same as Raspberry Pi CM4 , which means that it should work with carrier boards designed for the Raspberry Pi CM4.
  • 1. Amlogic A311D2,quad-core Cortex-A73 and quad-core Cortex-A53 SOC
  • 2. Mali-G52 GPU MP8 GPU
  • 3. 4GB LPDDR4/LPDDR4x (Max 8G)
  • 4. 16G eMMC flash (Max 128G)
  • 5. Designed with Board to Board connectors for enhanced stability same as RasPi CM4
  • 6. One on-board Gigabit Ethernet
  • 7. One PCIe2.0 interface expansion, can flexibly add related modules
  • 8. One USB3.0 port up to 5Gbps
  • 9. One USB2.0 high-speed USB/IO witch support USB OTG
  • 10. Three HDMI2.1 receiver ports
  • 11. one HDMI2.1 transmitter port with CEC
  • 12. two 8-lane V-by-One output can support up to 4Kx2K resolution(Multiplexing with MIPI-DSI/eDP/LVDS)
  • 13. two 4-lane MIPI-CSI camera interface with 16Mp ISP
  • 14. support Android and Linux system.
  • 15. Size: 55x40mm
Getting Started with CM5
BPI-CM5 Module Hardware interface
BPI-CM5 Module PIN Out define
BPI-CM5 moudule base board interface
Banana Pi BPI-CM5 SBC specifications
Same size as RPI CM4
Third part image
